Old 08-11-2013, 05:34 PM   #8281
Old Zipper
Old Zipper's Avatar
Oddometer: 14
Just signing in for a little FYI...
Well, I'm a sad former owner of a 2007 KTM 640 Adventure. My son and I "shared" two bikes (an '03 Aprilia Caponord and the 640 Adv.) and we had to sell both to get him through school. As big, powerful and gnarly as the Capo was, we both agree that the 640 was one of the most versatile and well-designed/well-built machines that we may ever come across. Nothing could stop it, except high university tuition fees
Anyway, the good news for one of you happy owners of a beat-up 640 Adv is this:
2007 KTM 640 ADVENTURE PARTS: http://www.advrider.com/forums/showt...ight=adventure
My misfortune could very well be your lucky day!
To everyone else.....see you on the backroads when KTM smartens up and releases their next generation LC4 Adventure
Old Zipper screwed with this post 08-15-2013 at 03:33 PM
Old Zipper is offline   Reply With Quote
Old 08-11-2013, 05:42 PM   #8282
rtwpaul
out riding...
rtwpaul's Avatar
Oddometer: 2,115
just posted loads of parts for sale in the flea market
click this link
RTW ride report
www.ridingrtw.com
rtwpaul is offline   Reply With Quote
Old 08-12-2013, 05:47 AM   #8283
wvrocks
wvrocks's Avatar
Oddometer: 615
Originally Posted by singletrak View Post
My Hi Beam headlight does not work even after replacing the bulb. The Low Beam works, the running light works .. but the Hi beam does not work. I suppose I could have gotten a bad bulb? Anything else I may be missing?
Singletrak
My low beam wasn't working when I got the bike. Turned out to be a broken wire inside the sheath going to the blub. It had been stretched and broken at some point.
I fixed it by replacing all the wiring to the bulb and wiring them both directly to the battery with fuses and relays. Relays were fired off the old wiring. The lights are brighter now and I don't have to worry too much about the old wiring.
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 08-12-2013, 11:54 AM   #8284
in-trim
Finding my Way
in-trim's Avatar
Oddometer: 26
Trying again for some pointers
*** Issue was solved and bike is roaring again... ***
Got some questions about issues I'm having with my manual and auto decomp,,, which don't seem to be working. I've spent many nights reading lots of threads on here, but none specifically answer my problem. I started a thread on here, which has pics and a lame vid,,, so if you've got any thoughts, please let me know. http://advrider.com/forums/showthrea...1#post22084621
I took the day off work to try and get this fixed today,,, since I'm tired of having a new ride that isn't running,,, it's dragging on my mind all the time!
in-trim screwed with this post 08-13-2013 at 11:04 AM Reason: Solved issue,,, folks commented on my thread
in-trim is offline   Reply With Quote
Old 08-14-2013, 09:32 AM   #8285
Nokmuay
Plan B Specialist
Nokmuay's Avatar
Oddometer: 532
Follower bearings
hey guys... My bikes in the shop, for valve adjustment, leak down , cam chain and rollers. I asked him to do the follower bearings and he said its the same thing as rollers. I read that the follower bearing are something to do around my mileage (36K kms) and wanna make sure they are getting done. Can anyone confirm or deny if the rollers are in fact the same thing as the follower bearings? Thanks
NokMuay!
Current ride is
08 CBR1000RR
05 KTM 640 Adventure R
Nokmuay is offline   Reply With Quote
Old 08-14-2013, 01:55 PM   #8286
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,499
The cam follower roller bearings on the rockers are indeed the ones you need to do.
Why the camchain? I got one to go in at 50K km when doing my follower bearings, as some bikes do wear them out, but it seems the LC4 one is a pretty durable part as the old one had no discernable wear, that replacement one had no wear 45K km later either.
I would put in new cam bearings too as they are common sizes & quite cheap, also rebuild the water pump. Then you should be set for another 40K km of fun at least.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 08-14-2013, 03:20 PM   #8287
Nokmuay
Plan B Specialist
Nokmuay's Avatar
Oddometer: 532
Cheers
Clint
Im not sure why but he ordered the chain and believe he said it was needing it due to wear. Unsure though, as it was supposed to be ready last monday and when I called today he said he hadnt touched it yet, but ordered the parts Hope he wont change if its not needed. Didnt think about the water pump. thats a good idea, thanks, Ill gert that done if he can as well. Ordering parts seems to be the PITA part. I shoulda probably found a KTM dealership, so parts were there.
NokMuay!
Current ride is
08 CBR1000RR
Old 08-14-2013, 04:43 PM   #8288
clintnz
clintnz's Avatar
Oddometer: 3,499
The water pump shaft & seal* you need to get from KTM, but the 2 bearings are a common size, get them from the local bearing shop along with the main cam bearings.
Dunno about where you are but KTM shops here don't stock bugger all for the LC4, so it's probably not making much difference.
*some have sourced the seal elsewhere but my local engineering supplies/bearing shop couldn't do them & they are usually fairly good at finding stuff like that.
Cheers
Clint
Old 08-14-2013, 04:54 PM   #8289
Nokmuay
Plan B Specialist
Nokmuay's Avatar
Oddometer: 532
Cheers
Clint
good stuff, thansk Clint...
NokMuay!
Current ride is
08 CBR1000RR
Old 08-15-2013, 05:46 PM   #8290
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,516
you definitely want to do them, the parts list was a grand when mine blew up last year
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 08-16-2013, 03:22 PM   #8291
makazica
makazica's Avatar
Oddometer: 749
Just dropping in to say hello to the asylum.....
Haven't gone far, still thumpers, still "Austrian", still wrenchin'....
http://www.advrider.com/forums/showt...0#post22116880
Cheers!
M.
makazica is offline   Reply With Quote
Old 09-05-2013, 03:52 PM   #8292
tuningmeisterjj
Vagabond
Oddometer: 10
Wicked
So was riding this for 3 years while in NZ....
Now I have come back to the UK to tour around Europe and just purchased this... Orange crush set in and first KTM..
Thanks,
JJ
tuningmeisterjj is offline   Reply With Quote
Old 09-06-2013, 06:03 PM   #8293
jrozar
jrozar's Avatar
Oddometer: 627
Jrozar in vegas signing in ...this is my 640 Adventure project, just getting ready to finish it up.......
http://advrider.com/forums/showthread.php?t=888604
jrozar
Las Vegas NV
www.my2wheels.com
jrozar is offline   Reply With Quote
Old 09-06-2013, 09:56 PM   #8294
bmwktmbill
Traveler
Oddometer: 5,194
Jrozar,
What lights are you using?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 09-06-2013, 10:06 PM   #8295
jrozar
jrozar's Avatar
Oddometer: 627
We fabricated a custom bracket and mounted two Vision X Optimus primes, the low beam is a 60 degree and the high a 10 degree, then tied the the low in to come on with the high. If you need some let me know...
Originally Posted by bmwktmbill View Post
Jrozar,
bill
jrozar
Las Vegas NV
www.my2wheels.com
Times are GMT -7.   It's 03:28 AM.
