Old 06-13-2008, 02:18 PM   #1
JStancampiano OP
PhotoJoe
JStancampiano's Avatar
Oddometer: 394
Fog light switch
I ordered parts from Max BMW (great service by the way) to move the GSAdv fog light switch up to the left combination switch to get rid of that "afterthought" look. Parts are from 2008 GSAdV/M.
Model: R1200GS ADV/M Diagram #61_2327
No Part Number Description Qty Each
01 61317704617 combination switch left BUY 1 $230.65
01 61317704627 combination switch left BUY 1 $245.71
01 61317704621 combination switch left BUY 1 $230.65
01 61317704625 combination switch left BUY 1 $245.71
01 61317704575 combination switch left (INFO) BUY 1 $210.23
01 61317702723 combination switch left BUY 1 $230.65
02 61317694980 combination switch right BUY 1 $235.85
02 61317694982 combination switch right BUY 1 $253.49
03 61317670033 covering cap left BUY 1 $11.25
04 61317670034 covering cap right BUY 1 $11.25
05 61317682091 fillister head screw with collar (3X10) BUY 4 $0.87
06 61317694815 fog lamp switch BUY 1 $91.85
07 61317702063 upper section of switch housing, left BUY 1 $13.38
08 61317702067 lower section of switch housing, left BUY 1 $14.80
used parts:
plus old fog light switch.
There is plenty of wire you can reach just in front of the tank by cutting wire tie. You can cut it, solder and splice with heat shrink, or remove tank and unplug.
Joe
JStancampiano screwed with this post 08-08-2009 at 02:59 PM
JStancampiano is offline   Reply With Quote
Old 06-13-2008, 02:59 PM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 56,668
Be sure to post before and after pics in this thread
Old 06-13-2008, 05:09 PM   #3
JStancampiano OP
PhotoJoe
Oddometer: 394
Here are some photos:
It's easy to replace rear cover on left switch housing. Remove hand guard, loosen the clutch lever screws and move it over 1/2 inch, then you can get at the two small screws on the back. I cut and soldered the three wires and covered with heat shrink (inside coated with hot glue. You can get from Digikey). You can also remove the gastank and unplug the switch, but I chose not to.
You will notice that the "fog light" graphic is sideways. I didn't feel it was necessary to spend $90+ for a 2008 switch. Just read it when leaned over in a corner.
Hope this helps.
Joe
JStancampiano screwed with this post 06-13-2008 at 05:22 PM
Old 07-07-2008, 09:18 PM   #4
Donald Duck
QYYQQuacks !
Donald Duck's Avatar
Oddometer: 857
What is "/ M" standing for at GS ADV/M ?
You won't know what you can achieve until you try...
Donald Duck is offline   Reply With Quote
Old 07-08-2008, 05:32 AM   #5
JStancampiano OP
PhotoJoe
Oddometer: 394
I don't know for sure, but I think it refers to the 2008 model year as parts seem specific to 08 bikes.
Joe
2007 R1200GS ADV, 1978 R100T, 2009 FJR
Old 07-08-2008, 06:56 AM   #6
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 971
Monster. Mega. Marvellous. Majestic. Machine.
Bill
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 07-08-2008, 09:34 AM   #7
Donald Duck
QYYQQuacks !
Oddometer: 857
I found it... It is "Magnesium-Metallic" (finish). Thanks anyway.
Old 07-08-2008, 09:57 AM   #8
willcasp
willcasp's Avatar
Oddometer: 123
Thanks for the information, I am looking to do this modification to my 2006 Adventure.
One question. If you had removed the tank, and unplugged the cable, you would not have needed to do an soldering?
Is there plenty of "play" in the cable? From your description, I expect that you cut the ties, take out some slack, and then tie it back up again?
IBA #47287
AMA Lifer, BRC, NMA
2008 KTM 530 EXC-R
2008 KTM 200 XC-W
2006 BMW 1200GS Adventure
willcasp is offline   Reply With Quote
Old 07-08-2008, 10:54 AM   #9
JStancampiano OP
PhotoJoe
Oddometer: 394
In photo showing wire bundle, there was plenty of cable under the wire tie to reach. I foune it easier to cut cable, thread thru switch housing and resoilder ( I have plenty of soildering equip + hot glue coated heat shrink tubing) If you are not comfortable cutting wires, then remove tank and unplug.
Joe
Old 07-08-2008, 12:00 PM   #10
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,930
i like it....i wonered how much it would be...
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 07-08-2008, 12:22 PM   #11
turnerm
Oddometer: 207
Can this switch assembly be mounted on a 2008 GS (non-adventure)?
I'd like to have that stock look when I mount the PIAA's on mine.
2008 R1200GS Blue.
turnerm is offline   Reply With Quote
Old 07-08-2008, 01:14 PM   #12
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
That would be a good location for Push to Talk too. If they have a sprung rocker on-off version of it.
Burnszilla is offline   Reply With Quote
Old 07-08-2008, 09:57 PM   #13
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
does this work on GS?
1. would such a mod work on a regular GS ('05 in particular)?
2. assuming you got a rocker switch to fit, any reason it could not be used for other aux lights?
-ceej
Hope this helps.
Joe
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is offline   Reply With Quote
Old 07-11-2008, 09:05 AM   #14
1fastjunebug
Oddometer: 171
Pm'd you about seeing if you would be interested in getting rid of the original switch housing and mounting hardware.
1fastjunebug is offline   Reply With Quote
Old 07-11-2008, 06:31 PM   #15
Sam Buca
a.k.a. Daniel
Sam Buca's Avatar
Oddometer: 2,898
That is the designation for the MANUAL gearbox. The 2009 models have an optional automatic gearbox designated by "/ A".
Quite interesting what they did. Apparently it is quite close to the BMW manumatic gearbox, but not quite as sophisticated as the Audi S-Tronic (DSG) unit.
You should read up on it. Quite novel and it is receiving rave reviews in Europe. Not sure whether we will see it here in the USA.
Sam Buca is offline   Reply With Quote
Times are GMT -7.   It's 05:19 PM.
