Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 03-25-2012, 06:40 AM   #181
merc16
Oddometer: 303
Thumb
Great thread vtwin !! You are documenting your rebuild very well !! Thank you !!
merc16 is offline   Reply With Quote
Old 03-25-2012, 09:38 AM   #182
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,373
Originally Posted by Rider_Rob View Post
The heat blanket idea works great! it was one of the first things I did, as well as heat wrapping my exhaust. Quick question though, I have roughly 55k on my 07, should I be worried about this happening to me, or would it have happened already?
I think you've got a good one if it hadn't happened by now. On Badweb, of the 33 or so that have posted on the "Bad Crank" thread, I believe there were 8 of us on it with bad cranks. Pretty high percentage, but doesn't really indicate a true number. They made alot of Ulysses so we don't know how many were fixed at dealers that are not counted and how many are happily riding down the street.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-25-2012, 09:40 AM   #183
vtwin OP
vtwin's Avatar
Oddometer: 7,373
I have been thinking of letting people take my crank, get it rebuilt and using it in their bike and they can do the same for their bad crank for the next guy. That way, they can reuse their old primary etc and cut the costs way down. Problem is that they have to find a shop that will replace the pin and bearings reasonably. All I'd need from the next guy is for them to pay the shipping to them. But they won't end up with the larger crank.
Monroe.
unknown
Old 03-25-2012, 09:42 AM   #184
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Thanks Merc, hope everyone learns from my bumbling around this.
Monroe.
unknown
Old 03-25-2012, 11:59 AM   #185
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,520
Really enjoying the thread.
Did you post pictures of the damage to the original crank? I saw the picture of the crank in the bucket but would like too see the damage.
Sent from my SGH-T959P using Tapatalk
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 03-25-2012, 04:07 PM   #186
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Nope, just the video of the noise while moving it. I believe you need a press to split the crank and remove the rods. I'm curious as well.
Monroe.
unknown
Old 03-25-2012, 07:34 PM   #187
Benjava
Benjava's Avatar
Oddometer: 1,920
Originally Posted by argentcorvid View Post
i did my Sportster without the plug. some oil did come out, but it wasn't too bad.
Just to reiterate, you have to static time the Uly
"Limbautomy" what's the Rush?
Benjava is offline   Reply With Quote
Old 03-25-2012, 08:03 PM   #188
argentcorvid
Some Guy
Oddometer: 481
oh, gotcha. my uly is a 2009 and the engine is quite a bit different than the older ones. I didn't know if the hole was there on the older ones.
argentcorvid is offline   Reply With Quote
Old 03-25-2012, 09:51 PM   #189
Benjava
Benjava's Avatar
Oddometer: 1,920
I should have been specific, the early ones do have the timing hole. But you still have to static time it.
Old 03-26-2012, 08:43 PM   #190
Rider_Rob
Oddometer: 9
Hey thanks! I have been pretty lucky with this bike, and I didn't really ever hear about this problem until just recently. Hope that everything goes good with your project!
Rider_Rob is offline   Reply With Quote
Old 03-26-2012, 09:25 PM   #191
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Thanks, so far so good.
Monroe.
unknown
Old 04-05-2012, 08:35 PM   #192
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Finally got my oil pump. I was a little worried as this is what was ordered...
But I recall seeing a different number, like -07 due to the scavenging change. I was relieved when I opened the box and saw this.
Oiled up and installed.
So now I can pour some oil down the rockers and let it lube the lifters, push rods and cam gears some more.
Time to put on the valve covers, but the seals are different from the ones that were replaced by the dealer when I had the oil leak. The new ones aren't orange and are a bit stiffer, but that's what I got. So I'm assuming these are the latest style.
Monroe.
unknown
Old 04-05-2012, 08:41 PM   #193
vtwin OP
vtwin's Avatar
Oddometer: 7,373
May as well replace the exhaust donuts.
Old ones took some prying out.
New ones in..
Had to tap them in place.
Hmm, I need that hoist to lift the engine. The manual says to strap the swingarm to the frame and then set the bike aside, so I do.
Looking good.
A little Mule Tape, rated at 1800lbs, should do it.
Monroe.
unknown
Old 04-05-2012, 08:46 PM   #194
vtwin OP
vtwin's Avatar
Oddometer: 7,373
On to the jack. I really recommend getting a bike jack for this operation, or at least a floor transmission jack.
Pretty sketchy..
It actually tipped over off the jack and I couldn't get it back on. So I improvished and lifted one side and slid 4 x 4 s under and then lifted the other side and shoved more 4 x 4s.
Monroe.
unknown
Old 04-05-2012, 08:52 PM   #195
vtwin OP
vtwin's Avatar
Oddometer: 7,373
It's finally back in with the rear and front mount supporting it. Not pretty, but at least it's come this far.
I did have a causalty, the front breather broke, so I need something else now.
Really is a tight fit in there.
Monroe.
unknown
Times are GMT -7.   It's 01:44 PM.
