Old 01-14-2013, 02:29 AM   #1156
KLR 650 guy
UralTouristKlr650Guy
KLR 650 guy's Avatar
Oddometer: 490
Originally Posted by stuser View Post
Did you modify the originals or just build some entirely new smaller ones?
Just put a set of IMS or Pivot pegs on an it wont bend..
08 Klr650e is the starting point ..ooo kms ..Kaoko cruz control..Rekluse Clutch..Staintune pipe..
Tall Kawa screen..Cog swapin 14, 15, 16, 42, 43.. Now he has bought a URAL Tourist where to now folks ....
KLR 650 guy is offline   Reply With Quote
Old 01-14-2013, 04:47 AM   #1157
stuser
Putt putt putt
Oddometer: 385
nice try :)
has pivot pegs on it already.... bending the other direction :)
stuser is offline   Reply With Quote
Old 01-14-2013, 07:08 PM   #1158
hoyks
Tightass KLR rider
hoyks's Avatar
Oddometer: 812
I cut the peg mounts off the stock brackets and welded them onto shorter plates. I was going to make foot peg lowering brackets, but achieved the same result from cutting the pivots off and welding them onto the lowering plates. pegs are now 1" lower and fewer bolts to fail.
hoyks is offline   Reply With Quote
Old 01-14-2013, 07:25 PM   #1159
stuser
Putt putt putt
Oddometer: 385
Cool.
So, just to clarify... you cut the mount in half... throwing away the heavier bit (on right) in pic (which is the base of the original bracket, right?) , and then welded the footpeg directly to the top of the bracket, which you'd drilled new holes into?
And it had the effect of lowering your foot position a couple of inches as well? How's that feel?
Ta :)
Old 01-15-2013, 04:10 PM   #1160
hoyks
Tightass KLR rider
hoyks's Avatar
Oddometer: 812
I like it. I'm tall, so dropping the pegs a touch made it easier to standup. The pegs are a bit narrower now as my brackets don't stick out as far, but with centre stand mounts and crash bar mounts packing the foot pegs outboard, there isn't much in it over stock.
I had to modify the brake as my toe struggled to reach the lever. It used up all the threaded adjustment on the master cylinder so I dropped the toe bit on the brake down 1/2" on a bracket and riveted it into place. I'll probably weld it now I've found it works.
I've added my how to over on KLR.net.
Old 01-16-2013, 05:21 PM   #1161
stuser
Putt putt putt
Oddometer: 385
Cool. Can you post the link here so I can find it?
stuser screwed with this post 01-16-2013 at 05:45 PM
Old 01-16-2013, 06:18 PM   #1162
stuser
Putt putt putt
Oddometer: 385
Silly question, but just wanting to clarify that mixing brands of knobby tyres on your KLR isn't a problem???
I've just received a Mefo Stone Master rear, and am thinking of matching it up with a Pirelli Scorpion Rally front.
Thoughts?
Anyone had experience on these tyres?
Old 01-17-2013, 02:36 AM   #1163
Neonasty
Oddometer: 148
Originally Posted by Turborob View Post
Plenty of online tutorials, if you want to have a crack yourself. It really is quite straight forward.
If you have the tools, I'm happy to assist. I needed to buy a torque wrench and a single socket, by memory.
Thanks mate. I might give it a go myself. I wanted to do a few other things too, like head stem bearings and swing arm bearings so I might just pay for it all.
Neonasty is offline   Reply With Quote
Old 01-17-2013, 02:56 AM   #1164
ausguy
Oddometer: 58
Thoughts?
Hmmm that stonemaster should last you at least 2000 ks on the road should of gone maybe for a D606 on the back
will last longer
ausguy
ausguy is offline   Reply With Quote
Old 01-17-2013, 04:24 AM   #1165
stuser
Putt putt putt
Oddometer: 385
will last longer
ausguy
thanks... I should have mentioned I'm less interested in longevity on the road, and more interested in off-road performance....
Old 01-20-2013, 07:20 PM   #1166
stuser
Putt putt putt
Oddometer: 385
I need to change the seal around on the counter sprocket on my 08 KLR....
I have found on some sites that it is useful to change another one or two parts.... But in my parts catalogue, all I can see is a little gaskety thing that sits on top of the seal....
so that makes two bits I can see.... anything else I need to change while I'm at it???
Old 01-20-2013, 07:34 PM   #1167
Croissant Warrior
Because it's there
Croissant Warrior's Avatar
Oddometer: 187
This is for a 2000 KLR. Mine is in MPH and I get tired of doing the conversion.
Two questions:
1.Is the tach accurate enough to bother wiring it? On another bike it was useless.
2. Is it worth splicing the hose to get the temp reading, or just feed off the current circuit?
Originally Posted by willows View Post
What year KLR? I fitted one to a 2005 model.. It's good to have an accurate speedo, now I know just how slow a KLR is!
Croissant Warrior is offline   Reply With Quote
Old 01-20-2013, 07:36 PM   #1168
Croissant Warrior
Because it's there
Oddometer: 187
Originally Posted by griffo1962 View Post
It's not the gasket. It will be the oil seal between the coolant & the oil...... check your radiator for an oily film on top of the coolant.
Will check, in both radiator and overflow.
If I need to do this job, what Kawi parts do I need? About to take the whole thing apart.
Old 01-22-2013, 12:42 PM   #1169
SMIFDOG
SMIFDOG's Avatar
Oddometer: 12
Laugh Double buble screen
Hi Felow KLR brotherhood
Has anyone got a Zero gravity Double buble windcreen on a 2008+ Model (Mine is 2011) Im interested in getting one but 'wondering about any feed back over the stock screen? If you had your time again would not bother? Wish you had gone taller? Will/has the increased profile hurt fuel ecconmy?
Im fairly short and even have a step down corbin seat but find i still get buffeted a lot.
Current wishlist
1) Improve Suspension -I think front needs it first More so now with the 32L Safari tank!!!! .I have seen progressive front spring kit online which looks like what i want but not sure? Rear might have to wait for a bit $$$$$
2) Screen - Taller - dont wont it to hinder/interfere when standing on the pegs and dont want to be looking through it sitting - Am i asking a lot?
3) Doo - Does this still need doing on a 2011 Model?
Any thought/feedback / Photos of screen/Dash set up if anyone has it
Thanks in advance
SMIFDOG is offline   Reply With Quote
Old 01-22-2013, 02:14 PM   #1170
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,213
Also got a question for all 'E' model owners (2008+).
The speedo is so cluttered with numbers its hard to read your actual speed - something one needs to be very conscious of, given the cameras around Melbourne.
Has anyone created a replacement speedo dial with less info? e.g. Numbers every 20 or 30 kmh instead of every 10? Alternatively, what do you guys do.
Live with it, or paint marks on the speedo face at important speeds such as 60 and 100?
Thanks,
farqhuar is offline   Reply With Quote
Times are GMT -7.   It's 10:43 PM.
