Old 11-16-2013, 05:52 PM   #1456
HEKOT
HEKOT's Avatar
Oddometer: 115
Hi KLRers,
I have a pair of unwanted Kyoto S1352 brake pads. I bought them from ebay, and after I tried to fit them, I found, there was a mistake in description. Looks like they fit KLR. If you want them for $15, please PM.
Local pickup or I can deliver in Adelaide metro area for free. No postage.
HEKOT is offline   Reply With Quote
Old 11-16-2013, 07:09 PM   #1457
Wanted Man
Oddometer: 3
Originally Posted by berty View Post
bet it looks just like a 2012 model they don't change much
haha - you are right.
Wanted Man is offline   Reply With Quote
Old 11-16-2013, 07:16 PM   #1458
Wanted Man
Oddometer: 3
Originally Posted by dazza67 View Post
Good on ya wanted man
So why did you chose the klr?
cheers.
Hi Dazza,
Wanted good value and easy to fix , low maintenance costs and decent range. I read reviews and just like the simplicity. It was a handful to ride at first but now getting more comfortable riding it. When I went to do the MOST at Clyde I got a lot more confidence in my ability. Still a lot to learn of course but now actually really enjoying riding.
John
Old 11-16-2013, 10:07 PM   #1459
johnboyklr
johnboyklr's Avatar
Oddometer: 20
welcome
hey wanted man welcome to the klr club have 43000klm on mine and still going strong,with a little oil consumption.
johnboyklr is offline   Reply With Quote
Old 11-17-2013, 01:26 PM   #1460
berty
the new guy
Oddometer: 360
Originally Posted by Wanted Man View Post
Hi Dazza,
John
low maintenance yes radiator $675 carefull changing wheel bearings hub is soft $975 for front hub and this was done by a mechanic could'nt send him the bill did'nt find the damage till i got home 3,000 ks later
berty is offline   Reply With Quote
Old 11-18-2013, 04:53 PM   #1461
craig hudson
Oddometer: 15
speedo drive reinstallation
Hello to all
be careful to check the speedo drive is properly angled when refitting front wheel esp if someone else does it (new tyre). I didnt, chewed out the drive and the lugs on the hub Could not prove it was fault of w/shop It was cheaper to buy a second hand wheel and drive
Regards Craig Hudson
craig hudson is offline   Reply With Quote
Old 12-12-2013, 01:54 AM   #1462
Hugheytj
headin out
Hugheytj's Avatar
Oddometer: 63
KLR lights
Evening,
Went for a rego check this afternoon thinking I needed to replace the rear tailight.
Brake light working, no tailight, then found that low beam is not working, high beam is ok.
All blinkers and dash lights are ok.
Pulled the bike down at the mechanics checking every fuse I could find and pulling apart every junction I could find. No luck still no tailight and no low beam.
Passing comments from the mechanics ranged from blown fuse to bad earth to does your light stay on all the time?
Any ideas, something familiar to KLR, a fuse I haven't yet found? All .
Thanks Hughey
Hugheytj is offline   Reply With Quote
Old 12-12-2013, 04:01 AM   #1463
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,213
Originally Posted by Hugheytj View Post
Evening,
Thanks Hughey
Dumb question, but did you check the bulbs? With the low beam and tail light being on permanently the heat makes the filaments brittle, combine this with the vibes the big single puts out and it is a perfect combination for bulb failure - happened to me within 6 months of ownership of my new KLR.
farqhuar is offline   Reply With Quote
Old 12-12-2013, 11:25 AM   #1464
Hugheytj
headin out
Hugheytj's Avatar
Oddometer: 63
Yes swapped the rear one out, even though it looked OK. Haven't looked at the front one, but if the low beam was out would it affect the rear taillight?
Old 12-12-2013, 11:32 AM   #1465
bigdon
Oddometer: 2,643
The rear tail light may have burned out also.
Check the easy stuff first!
Fuses
Bulbs
Wires
then to Shop!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 12-12-2013, 09:45 PM   #1466
Muruk59
Muruk59's Avatar
Oddometer: 88
Yearly event!!
On mine I seem to blow both the tail light and low beam once a year. Pain in the butt to replace the main bulb the first couple of times but I am getting quicker at it now!!
Muruk59 is offline   Reply With Quote
Old 12-13-2013, 12:58 PM   #1467
craig hudson
Oddometer: 15
blown bulbs
Hello Hughey
Make sure the number plate light (which is also on all the time) is not the source of the problem with the tailight issue its prone to go on my 2012 model
Old 12-14-2013, 02:13 AM   #1468
Neonasty
Oddometer: 148
Ive got an '08. I started blowing tail lights too. I replaced it with an LED one from Jaycar. It was about $20 I think, plugs straight in. Same brightness maybe a little brighter. Zero problems since.
If you keep blowing low beams, an HID kit should fix that too. They dont have a filament as such so it makes them resistant to vibrations.
-Shaun
Neonasty is offline   Reply With Quote
Old 12-14-2013, 03:22 AM   #1469
mky
Oddometer: 4
Hi all, I just picked up a 2011 klr650 and hope to have some fun on it. I am in mackay
Sent from my GT-N8010 using Tapatalk
mky is offline   Reply With Quote
Old 12-14-2013, 03:23 AM   #1470
willows
Oddometer: 299
I'm presuming this "globe blowing" thing is just a Gen 2 phenomenon?
Sell it and buy a Gen !! hahahahaha!
2005 KLR650
willows is offline   Reply With Quote
Times are GMT -7.   It's 06:15 PM.
