Old 12-06-2012, 11:26 PM   #16
John Smallberries
John Smallberries's Avatar
Oddometer: 1,285
Great tutorial
Thanks for posting - this will be my weekend project. My RH bag (the one I use as a trunk) is getting stickier by the day.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 04-28-2013, 07:47 PM   #17
JRose
JRose's Avatar
Oddometer: 629
Question
To resurrect this post, I am having trouble with one of my Vario cases acting stuck. I took it apart, cleaned it well, lubed the gasket, and put it back together. Still feels bound up half way through the throw of the lever. So bound that it feels like I'm about to break it if I push anymore.
So I took it apart again, double checked for obstructions, cleaned it again just in case I missed something, and put it back together.
I noticed that upon reassembly, the two halfs always felt like one corner was not quite alligned when the other three were. Almost as if the bottom part was just a little swollen.
When back together, they move togehter fairly freely for the first few inches, but then gets progressively tighter as I try to push it down. Also, a small bulge starts forming on the bottom, where the two gaskets come together. I first thought that the gasket might have come off, but it is on there, I checked twice.
Any suggestions?
Also, guess I should mention that these are cases off a F800GS...
Jason
JRose is offline   Reply With Quote
Old 04-29-2013, 04:31 AM   #18
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,050
Any suggestions?
Jason
Varios suck! Plain and simple. I read this post last year and tried the cleaning method method described.
Still sticky.
Took them back apart and chamfered the sharp leading edge and sprayed a light film of dry graphite to lube.
Still sticky!
Back apart again for an in depth look and found the plastic is warped. The male frame that slides into the female reciever are both so wavy that jamming is inevitable. This same situation occurs on all 3 of my Vario boxes. Friggin' cheap junk!
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 04-29-2013, 06:19 AM   #19
LaurelPerryOnLand
Oddometer: 3,480
When you re-assemble the CASE BOTTOM...try to run a dull kitchen knife around the edge to insure that both parts are properly mating.
Also...make sure there isn't some dirt/rock/pebble in the mating part which would prevent the parts from FULLY mating...which might be affecting the gear mechanism.
Here's a link to my pictorial about 'fixing' a Vario on an R1200GS:
http://advrider.com/forums/showthread.php?t=848307
LaurelPerryOnLand is offline   Reply With Quote
Old 04-29-2013, 06:32 AM   #20
JRose
JRose's Avatar
Oddometer: 629
Mine too looks slightly warped. I've checked extensively for obstructions, none present. Even lubed all contact parts.
I'll mess with it more tomorrow and see if I can figure out a fix.
Old 04-29-2013, 10:12 AM   #21
GSgeorge
Oddometer: 24
Hey, those are my side cases? I bought them from rdwalker about two years ago, they still work great! I didn't know I was supposed to maintain them?
GSgeorge is offline   Reply With Quote
Old 02-17-2014, 06:20 AM   #22
matkal
Assault Commuter
matkal's Avatar
Oddometer: 1,648
Is it advisable to use any lube?
Such as silicone spray on the gears and other mating/sliding surfaces.
'09 R1200GS
Helmet laws suck. They interfere with natural selection.
ATGATT 35:12-14
"And Atgatt courted Motgatt, and took her for a wife.
And lo, he compromised with Atgmott, and verily she conceived,
and did bear a son, Notgatt. And Notgatt roamed naked,
and did bequeath his skin to the roads. And he was a wild ass and an outcast,
and was hated through all the land. And his forehead was branded, and he did be
come a sign and a warning to all the people."
matkal is offline   Reply With Quote
Old 02-18-2014, 09:41 AM   #23
bobbybob
Oddometer: 654
I meticulously cleaned mine and used a water based silicon spray lube, nice and slippery. Didn't help one bit! I agree with previous posters, Varios SUCK. Big time. They are crap. Mine had the buckling appearance, etc., all that weird shit you can't figure out. After using mine for 1 year I sold them (at a loss of course) and did what I shudda done in the first place. Bought Jesse's.
bobbybob is offline   Reply With Quote
Old 02-18-2014, 10:58 AM   #24
Chat Lunatique
ACK
Oddometer: 1,050
NO!!! Do not use anything that will make the dust stick and cause further jamming. The only acceptable lube is dry graphite spray, IMHO.
Times are GMT -7.   It's 09:22 AM.
