Old 06-15-2012, 03:40 PM   #3226
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,763
Originally Posted by Oz-Strom View Post
I have wired mine the other way around. Gps to unswitched so it stays on when stopped, and accessory socket to switched wires so less chance of a flat batt. Gps always comes off the bike when parked for security anyway.
I have the montana and apparently it draws power even when unit not in cradle
Beer'o'clock Baz is offline   Reply With Quote
Old 06-15-2012, 07:42 PM   #3227
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 770
I have the Montana also. Wasn't aware the cradle draws power when nothing init to draw. Where does other current go I wonder? Seems at odds with my meager understanding of electrical stuff.
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 06-15-2012, 08:02 PM   #3228
minusone
minusone's Avatar
Oddometer: 1,295
It is probably has built in a 5V stepdown circuit with the input side of the electronics constantly connected will have some leakage.
Not a problem over a few days but in the garage maybe.
With my garmin cradle I just plug it into the dash socket and remove it when in storage.
This socket is also used to charge the battery
minusone is offline   Reply With Quote
Old 06-15-2012, 08:55 PM   #3229
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 770
Thanks minus one for that info. Mine has sat in the garage for weeks and no flat batt yet thankfully. I thought it was fairly common to have the cradle wired unswitched, but I have not heard of issues with battery drain. But......
Cheers
Graham
Old 06-15-2012, 11:49 PM   #3230
Beer'o'clock Baz
Oddometer: 1,763
Read about it on the montana thread ages ago
Old 06-16-2012, 12:39 AM   #3231
Wilmo
Orange Fever
Wilmo's Avatar
Oddometer: 1,275
A few questions for owners:
If you have a Safari tank fitted, do you still need to fill the standard tank from the rear filler on the guard, or does it fill from the Safari tank like a Berg 390,450,570 will?
If you have to fill it from the rear guard - how do you manage this when the bike is loaded? Isn't it a PITA to remove your gear to fill up?
Which racks work best with Andy's panniers? Alternately, does a Giant Loop Great Basin work with the 690 exhaust where it is - looks like its quite prominent and heat might be a problem?
Is the shorter suspension on the new 2012 the same as the original 2008/9 Enduro standard 250mm suspension or has it been revalved?
Rudall River Ride 2011 Kimberley Ride 2012
Australasian Safari 2012 Gascoyne Dash Racer 2012
Take risks and live an extraordinary life!
Wilmo is offline   Reply With Quote
Old 06-16-2012, 12:40 AM   #3232
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,202
Can't be too many 690's left for sale after seeing how many showed up this morning on the TM ADV ride. Used to be 950's and 990's everywhere, and most of the 690 riders said they came from the bigger oranges.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-16-2012, 12:50 AM   #3233
minusone
minusone's Avatar
Oddometer: 1,295
The keylock is also a pain so I ordered one of these which uses a standard screw cap.
Tool tube is secured with one strap and quickly removed for refuel or transfer to another bike.
Old 06-16-2012, 12:54 AM   #3234
Beer'o'clock Baz
Oddometer: 1,763
Mate i had to work this morning that ride looked great
Old 06-16-2012, 01:15 AM   #3235
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,202
Yeah, every one seemed to be enjoying themselves and there were no injuries or drops when we left them, but they hadn't been on the beach yet. Will be interesting to see how all the big bikes go tomorrow.
xronly
Old 06-16-2012, 02:10 AM   #3236
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,308
10 grand cheaper for the small ones, pays for a few parts.
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 06-16-2012, 02:13 AM   #3237
rosscoact OP
need constant supervision
rosscoact's Avatar
Oddometer: 5,503
If you have a Safari tank fitted, do you still need to fill the standard tank from the rear filler on the guard, or does it fill from the Safari tank like a Berg 390,450,570 will? If filling both tanks you need to turn off the connection between the two tanks then use the rear first for at least 100k. The front is higher than the rear. So yes, fill separately.
If you have to fill it from the rear guard - how do you manage this when the bike is loaded? Isn't it a PITA to remove your gear to fill up? ]Using a Coyote it's simple but otherwise, yes a PITA but you only have to do it once a day.
Which racks work best with Andy's panniers? Alternately, does a Giant Loop Great Basin work with the 690 exhaust where it is - looks like its quite prominent and heat might be a problem? Best rack and panniers IMHO is the wolfman, will work with Andys
Dunno, I revalved my E anyway.
Stupidity got us into this mess, then why can't it get us out? Will Rogers
www.transaustraliatrail.com.au
rosscoact is offline   Reply With Quote
Old 06-16-2012, 02:21 AM   #3238
TEZZA
ADV B4 DEM/TED
TEZZA's Avatar
Oddometer: 302
Thumb Scotts Steering Damper Mount
Hi all in 690 land . I have a Scotts steering damper mount left over from my 690e , if anyone needs to buy one mine is up for sale a t $130 plus postage . P.M . me if you want to buy the moont???
I also found a Brand New chain guard at $30 plus postage.
Tezza
Tezza.
KTM 990 ADVENTURE.
KTM 520 EXE.
Now the Perfect pair!!!!
TEZZA is offline   Reply With Quote
Old 06-16-2012, 02:22 AM   #3239
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,057
The fuel will drain through but very slowly . I often just fill the Safari tank knowing I have more than 14 litres . If it`s a long stretch I fill both tanks .
Brute is offline   Reply With Quote
Old 06-16-2012, 04:41 AM   #3240
excTC
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 166
Question Fuel Filters to fit screw cap (Acerbis)
Does anyone know what fuel filter will fit in the screw cap. I have replaced the standard key lock one with the Rally Raid screw cap and want to buy filters. I went to order SpltStream units from Cyclebuy and got the response below.
SplitStream lists these filters as fitting only the stock tanks with the 1/4 turn caps.* We have never had the opportunity to fit the filter to a Rally Raid tank, but we are fairly certain that they will not work with the Acerbis screw-on cap.* Should you choose to proceed with the filters on your order, please understand that we cannot accept returns on any open packages.* You would be responsible for the cost of shipping the returned filters to us.* Please let me know how you would like to proceed and if you have any other questions!
KTM 530 EXC Royal Enfield Bullet 500 KTM 690R. Spot link The Land of Pickled Fish and Beyond
Team690 on the APC
excTC is offline   Reply With Quote
Times are GMT -7.   It's 01:42 PM.
