Old 07-17-2012, 06:26 AM   #3406
LukasM
Oddometer: 5,426
Originally Posted by DRjoe View Post
sounds like the old 520exc
my bike head shook like a mofo with the only fix being setting the rear sag way over spec untill i fitted some new tripples with less offset.
good thing about ktm is they did crap loads of diferent offset clamps that fit smaller bikes with 48mm wp forks.
i wonder if they fit the 690's
The billet clamps should fit, you would just have to reuse the 690 stem as it's a bit longer than <690 KTMs.
Originally Posted by Cruz View Post
A bit like the 2009 Bergs were twitchy at speed so they changed the triples in 2010.
Husaberg actually went to more offset (from 19 to 22mm) which makes them better turning but more twitchy. Barton, Walter and I all felt that the Bergs are very unstable above 100-120 kmh. They shake around a lot even with stabilizers installed.
Safariberg and the rally guys are using clamps with less offset for high speed stability. Got myself some factory 19/22s to try, hope that solves it!
Old 07-17-2012, 03:01 PM   #3407
DRjoe
DRjoe's Avatar
Oddometer: 5,218
The other option would be the E axle.
Not sure if it's a direct fit for the 690 but it wouldn't be hard to have one made.
Old 07-17-2012, 03:12 PM   #3408
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,246
What's this you speak of ? Is it an offset axle?
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 07-18-2012, 12:27 AM   #3409
DRjoe
DRjoe's Avatar
Oddometer: 5,218
Yep thats correct ya big dick http://www.rekluse.com/E-axles.html
Old 07-18-2012, 12:30 AM   #3410
LukasM
Oddometer: 5,426
The fork bottoms are the same width and diameter as the 125-530 bikes, and the wheel spacers will also interchange.
So it should work.
Old 07-18-2012, 01:28 AM   #3411
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,246
Looks like you can only get 2mm negative out of it...ya reckon you could notice that?
On another note, I started taking the shock out today so as to adjust the spring tension. One bottom bolt came out of the tank but the other just spun. Was thinking that there was a little nut turning in the plastic so drilled the head off the bolt and had to take the whole tank out instead of just hinging it up.
Luckily it turns out that there is a threaded sleeve to goes right through the bottom of the tank...was able to get the vice grips on the remainder of the bolt and get it out.
The manual recommends loctite on these bolts so gonna have to devise a way of holding the sleeve in future to get the second bolt out, prolly just a bolt with a locknut on the opposite side might do...
Old 07-18-2012, 01:32 AM   #3412
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,763
Should be looking at the RR replacement maybe -alot better system-
Beer'o'clock Baz is offline   Reply With Quote
Old 07-18-2012, 01:33 AM   #3413
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,246
Anyone had their linkages off to regrease?
The sleeve that goes through the linkage to the swingarm on mine was so tight in the bearing, that I had to knock it out with a hammer and the needle rollers scored it on the way out.
Old 07-18-2012, 01:35 AM   #3414
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,111
Yes I did mine when I bought it and there was f***k all grease in there from brand new and there was already surface corrosion.
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 07-18-2012, 01:37 AM   #3415
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,111
Stupid design one bolt will always come out and other will always spin, Rally Raid version is a through bolt with a stiffnut on the end, piece of piss and common sense.
Old 07-18-2012, 01:53 AM   #3416
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,246
There wasn't any corrosion in mine, but sfa grease like you say.
I reckon they've fecked up the machining of the linkage where the needle roller bearing fits into.
Old 07-18-2012, 01:58 AM   #3417
DRjoe
DRjoe's Avatar
Oddometer: 5,218
Yes because by decreasing your offset by a few mm you increases your trail by about the same which is what gives you more stability same thing happens when you increase the rake but if you rake the front end out you'll have a more terrain afected steering than if you decrease you offset.
But you new that already didnt you huge night tool
Old 07-18-2012, 01:59 AM   #3418
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,246
What were they thinking?
Have you checked your spring adjusters Andy? Mine were barely tight (went to undo the outer locking one, and they both easily turned together) and I have read that they can damage the thread on the shockie
Old 07-18-2012, 02:03 AM   #3419
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,246
Interesting,,,no I didn't know that you young geriatric
Old 07-18-2012, 02:14 AM   #3420
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,111
Yeh did mine, Rally Raid sell steel ones as the piss poor ones on there chew out real easy, I haven't changed mine yet. When I bought my bike I stripped it and rebuilt it properly dealing with most of the reported issues as I went.
Andy
Times are GMT -7.   It's 05:50 PM.
