Old 10-15-2012, 03:31 AM   #3886
podge NT
Podge NT
podge NT's Avatar
Oddometer: 1,619
Originally Posted by Big Willy View Post
Done a bit of reading and it turns out that this is a very good oil... a group IV which basically means that it contains no Viscosity Improvers (the chemicals that get broken down and turn to sludge)
Probably not as good as the Penrite 10 tenths Racing 15w/50 that is made up of group IV and group V oils from what I've read, but both should be quite ok...not that I'm recommending them as KTM specifically recommend the Motorex voodoo
Here's an interesting article which helps clarify a few things...
Motor Oil Viscosity Grades Explained in Layman's Terms
The best oil for a 690 is Motorex 10w60. Do you have a problem with using the right oil just to save a buck?
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 10-15-2012, 03:40 PM   #3887
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 653
Yeah Podge, I do use the Moterex oil. But was wondering if there was an equivalent that is readily available. It is not always easy to get the Motorex in my area. End of oil discussion
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 10-15-2012, 04:33 PM   #3888
Big Willy
Loaded and ready
Big Willy's Avatar
Oddometer: 1,713
Not so fast there Graham...
I don't enjoy being reamed
If there is a cheaper altrrnative, I'm all for it.
I'll personally be trying the Castrol next oil change.
The main killers of bikers are Alcohol, Speed and Fatigut
'08 Transalp 700
'12 KTM 690R
Big Willy is offline   Reply With Quote
Old 10-15-2012, 05:08 PM   #3889
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,739
motorex is in most bike shops in brisbane
You suck. And your mother dresses you funny.
Life is one lap with no restarts and the Finnish line is unknown......keep going!
mickd is online now   Reply With Quote
Old 10-15-2012, 05:11 PM   #3890
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,338
hmmm
I used a car oil years ago as I was low on oil and it was all I could get, I fried a clutch in a few hundred K's. It had a friction modifier in the car oil.. turns out the friction plates in a clutch didn't like being modified...
I have run Dello 400 in a few bikes and like it, it does seem to go off quicker than a full synth motorbike oil... with super slick gear changes to start with, turning into a bit notchy after a while.. change the oil and the slick changes are back...
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is online now   Reply With Quote
Old 10-16-2012, 01:53 AM   #3891
Big Willy
Loaded and ready
Big Willy's Avatar
Oddometer: 1,713
Hey Joe...yep I've heard a few stories like that and don't doubt it but I've tried plenty with no ill effects.
The 0w/30's are a definite no no as are the cheap car oils like GTX and GTX2.
I've used plenty of Delo and still do but really it's not all it's cracked up to be (no pun intended you oil boffins). Best thing about it is the price for the quality you get so you can afford to drop it more often and purge your motor of all the debris
'08 Transalp 700
'12 KTM 690R
Old 10-16-2012, 09:38 AM   #3892
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,199
The supposed reason for the motorex in the 690 had to do with a high silver content in the bearings...or something along those lines. I have stuck with the motorex given the oil change intervals and I don't think its that expensive...in my end of the world. That said there are people running different oil with no ill effects so far.
Seth S
Husaberg tank for sale: HERE
Seth S is offline   Reply With Quote
Old 10-16-2012, 01:33 PM   #3893
Big Willy
Loaded and ready
Big Willy's Avatar
Oddometer: 1,713
13 litres going cheap in WA if you're quick...
Motorex oil cross power 4T 10w/60 KTM HUSABERG | Parts | Gumtree Australia Rockingham Area - Baldivis
'08 Transalp 700
'12 KTM 690R
Old 10-16-2012, 02:00 PM   #3894
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
I will grab it but can you pick it up 4 me biggus '-] good buy considering its $100 plus for a 4 ltr bottle
B2 screwed with this post 10-16-2012 at 02:14 PM
B2 is offline   Reply With Quote
Old 10-16-2012, 08:25 PM   #3895
fearless phill
Oddometer: 21
Wink
Originally Posted by johnno950 View Post
hi joe,another local cq gent.He bought this one a few months ago and just got it on the road rego/etc.Its a very tidy bike and super strong engine....great day!
hey johnno 3 weeks off for me over christmas should try to get out for a ride
fearless phill is offline   Reply With Quote
Old 10-16-2012, 11:18 PM   #3896
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 1,406
Big Wills,
This is my attempt at making the evo airbox cover sit better to make a more even seal with the filter and prevent dust ingress.
I made up an endplate out of ally with a slot to take the new retaining plate. The endplate is bolted through the flat part of the airbox and lots of silastic to seal.
Also put bolts and spacers through the top flange.
Little spreader plates for the screws to bear down on just araldited on.
Retainer plate made out of 2mm ally with reinforcing angles to stop any bowing. Lip at the front to engage in the cut out in the front plate. Drilled and tapped for the allen headed bolts which will be the adjustable bearers, each with a lock nut to retain the preset position. Filed cutouts to allow for the reinforcing fins on the evo cover.
Locate the filter, cover and retaining plate in position and locate / tighten rear screws.
Screw down bearer allen screws to press on the cover and set to the appropriate amount of squeeze. Lock up the locknuts.
All fits in and no problems with seat, just had to shuffle the wiring near the radiator and reroute the overflow to make room for the additional front plate on the airbox.
It was a pigs arse to make and I trimmed some of the big plastic web which is part of the evo cover in order to get the retaining plate into position. Hopefully should be still OK to remove and clean the filter in situ with the airbox fitted but I haven’t tried yet. And before you ask no, make your own, it took ages to get it right, hopefully you can figure it out from the piccies.
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690R 2011
http://www.jet-metal.com
El Ponkin is offline   Reply With Quote
Old 10-16-2012, 11:23 PM   #3897
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,661
I just use grease it works well and easy and cheap
Mudguts is offline   Reply With Quote
Old 10-16-2012, 11:35 PM   #3898
ADV-Wes
I'm not lost....yet.
ADV-Wes's Avatar
Oddometer: 176
Works for me. I run a foam filter and Marine Grease around the seal. Always have on all my bikes going back to the MX days. Makes for a good seal if you use just the right amount, and sticky as shit to a blanket.
'10 KTM 250 sxf '10 KTM 690 Enduro R
'98 Ducati 916 sps '01 Ducati 748 s (the Track weapon!)
Project '97 XR250R
ADV-Wes is online now   Reply With Quote
Old 10-16-2012, 11:40 PM   #3899
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 653
That is quite the engineering effort Andy. I do wonder if it is all really worth it performance wise over the std foam filter and drilled snorkel cover, but maybe it is? Does that mean lots of screws to remove to get the airfilter out? Mine just has 2 self tappers to remove and it's out.
Like your work though!
Cheers
Graham
Old 10-17-2012, 12:01 AM   #3900
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 1,406
As Big Willy previously mentioned the evo cover bows in the middle and even with my foam filter and tons of sticky grease i still got a fine dust inside on a particularly dusty ride. I like the evo lid as it gives extra airflow but without the induction noise of something like the rally raid filter. In theory once the bearer screws are set I should just be able to undo the two rear screws and it will all lift out and refit as normal.
Its one of those things, I chose the evo cover and didn't want to spend more money on another option and apart from labour the mod didn't cost me anything really just left over scraps in the shed.
Andy
KTM 690R 2011
Times are GMT -7.   It's 04:31 PM.
