Old 08-27-2013, 01:09 PM   #4441
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,441
Originally Posted by Big Willy View Post
G'day Seth. I know you have the black frame bike but I was under the impression that the 690 orange frame bike had the same forks as the EXC's according to part no.s on the fiche?
I have the gray frame:
EXC forks will slide right into the 690 triples. my suspension was reworked and lengthened to R height but I would like to go for the full 300mm setup. Its possible the forks are at the same as the EXC's but I know the rotors and brake masters are different. The caliper and caliper mount are different to accommodate the bigger rotor on the 690...but event that I would have to check. If the forks are the same then they have been reworked for significantly less travel.
Seth S
Seth S is offline   Reply With Quote
Old 08-27-2013, 01:15 PM   #4442
Seth S
Seth S's Avatar
Oddometer: 4,441
The 2009 690R is listed as having forks with part # 14187E4101 while the 2009 450 EXC is listed with fork part #14187E0601. The 2012 690R forks are listed as 14187L1001 while the 2012 500EXC is listed under 14187L6901. So they would appear to be different.
Seth S
Old 08-27-2013, 02:04 PM   #4443
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,205
Ahhh...a bit more research shows that you are correct.
Even though the outers are the same length, judging by the compression adjustment tube, the EXC is 520mm long, the earlier 690's were 495mm and the latest 690 is 470mm long...so the newer versions have lost 50mm travel.
This is part no. 30 on the microfiche.
I have an idea that the black frame models had the 470mm version forks as well and the orange had 495mm?
2012 690R Thoroughbred Racehorse
2010 700 Transalp Donkey
Big Willy is offline   Reply With Quote
Old 08-27-2013, 02:35 PM   #4444
Seth S
Seth S's Avatar
Oddometer: 4,441
The 2008's were all "E" models and all had 250mm suspension iirc. The R came out in 2009 with 275 mm travel. The newer bikes are all 250mm I think.
Seth S
Old 08-27-2013, 03:37 PM   #4445
vegemanNZ
Oddometer: 50
Originally Posted by -KATO- View Post
good stuff o'large one,
but i just don't really give a fuck an deal with it.
ha, nice and I hears ya on this one...I've read and read and read and it just hurts to read anymore. When I changed from my XR650L to the 690...the first thing I noticed was how stable and smooth the 690 was on the gravel/dirt roads. I couldn't beleive that I could continue doing the same 120kph speed from tarmac directly onto the dirt (so handling was primo in comparision)...then cracking it open to 160k and still on dirt/gravel was just a freak show.
The main complaint for me is that its the slow square edge, slow speed corrugated roads that make the front feel hard...I would love to resolve that...but cost/hassle/time etc...so I try not to go slow, and that solves the issue. This bike is fast, and is designed for it.
2008 KTM 690E - Adventurotard - forget dual sport, get triple sport!~
vegemanNZ is offline   Reply With Quote
Old 08-27-2013, 05:25 PM   #4446
Sol Erzenberg
Lost somewhere
Sol Erzenberg's Avatar
Oddometer: 1,437
100% correct..
2009 KTM 690 R
"Thats A Sweet Noise You Got There Man, I Had You Picked Clear Across The Mallee"
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1979 Honda CR125R Elsinore.
1978 Suzuki RM 100.
ARIEL MCC
Sol Erzenberg is offline   Reply With Quote
Old 08-27-2013, 09:45 PM   #4447
Seth S
Seth S's Avatar
Oddometer: 4,441
My 08's was one of the first in the USA. I never had a problem wit h the efi or fuel pump for 7000 miles. Got some dirty fuel in WA on the safari and seized the stock. Put a used pump from a berg in and that one is still in there...berg hoses and all.
Seth S
Old 08-28-2013, 06:15 AM   #4448
gen
gen's Avatar
Oddometer: 798
Do you know which one?
What I am concerned about is switching to a CA Cycleworks pump but having that one fail on me (which hasn't happened to me, but I've heard it happening.)
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 08-28-2013, 08:38 AM   #4449
Seth S
Seth S's Avatar
Oddometer: 4,441
The betgs use the same exact pump as the 690. I have a ca cyclewerks to put in but have not yet. I have not heard of a single ca pump failing yet.
Seth S
Old 08-28-2013, 09:11 AM   #4450
DirtJack
DirtJack's Avatar
Oddometer: 1,446
I posed the CA Cycleworks FI pump failure question on my my FI Thread and have heard no failure responses. I have more than 7K miles on my CA pump and it's working great. I no longer carry a spare.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 08-30-2013, 03:13 PM   #4451
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,030
I carry a CA Pump as a spare but thinking of changing over soon as my standard pump has done 23000kms.
Just maybe easier to change out during a service than piss about on a ride, I think I have had good value out the first one.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 08-30-2013, 03:14 PM   #4452
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,030
On the TK Memorial ride for the first time I had my tank bag bounce forward and turn my key off, I had read about this before but in 23000kms never had it happen. Of course once it happened it did it again 4 times, each time catching me out in the worst sections with riders right behind me, anyway time for another mod.
Put this plate in, that should stop it.
Old 08-30-2013, 03:17 PM   #4453
Seth S
Seth S's Avatar
Oddometer: 4,441
Andy
My original pump only failed because I didn't filter my fuel enough. When we got it out of the tank and tapped it with a hammer while applying power it spun back to life...though didnt sound so hot.
Seth S
Old 09-02-2013, 06:07 AM   #4454
shaun66
Oddometer: 144
Just picked up a new '13 690. Does anyone know if the Aussie '13 models need the 2nd-3rd gear mod doing.
Cheers
shaun66 is offline   Reply With Quote
Old 09-03-2013, 05:29 AM   #4455
chrisamberely
USMC. (retired).
chrisamberely's Avatar
Oddometer: 138
Rad braces
I was talking to a buddy today who has a '10 model...he has ordered a great set of radiator braces from an English shop called Rapid Moto.
4mm thick Ali, cost him about $150 including the shipping. I was trying to post things with the link but can't get it happening for some reason. Looks like a great bit of protection for the bike.
http://www.rapid-moto.com/ktm-690-en...or-braces.html
chrisamberely screwed with this post 09-03-2013 at 05:34 AM Reason: Got the link happenin
chrisamberely is offline   Reply With Quote
Times are GMT -7.   It's 03:59 AM.
