Old 09-27-2013, 03:48 PM   #4501
mezcal
mezcal's Avatar
Oddometer: 448
Originally Posted by Hoots View Post
Which year did the full 690 displacement / low maintenance motor come in?
Was it 2010 or 2011?
I'd go for that version if getting one with higher kms
2012 for the 690 cc engine I am almost certain, not sure on the low maintenance part. Mine is a 2009 with 5000km interval (10000km for valves) although I do change oil at 2500.
Probably unnecessary changing oil so soon but i have always changed oil on my bikes mid way through a service cycle for peace of mind.
Coming from a WR 450 the 690 is low maintenance to me what ever the year model
mezcal is offline   Reply With Quote
Old 09-27-2013, 05:48 PM   #4502
chrisamberely
USMC. (retired).
chrisamberely's Avatar
Oddometer: 140
Mine is 2010. It's not the full displacement version, and the manual quotes 7500 for its service. But I change out the oil well before that as well, and do the filter swap. Just good policy I figure.
chrisamberely is offline   Reply With Quote
Old 09-28-2013, 04:19 PM   #4503
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Would someone be able to measure the height of the dustcap on the bottom of the shock for the 2011 and earlier models.
This determines how close the rear wheel is to the tank under full compression.
I have one from an SMC and wonder if it is the same as the earlier Enduros or is shorter because the rear wheel diameter is smaller on the SMC?
Thanks for any help
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 09-28-2013, 04:25 PM   #4504
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,114
Dust cap ?? Or do you mean bump stop I have a spare shock so easy to measure
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 09-28-2013, 04:31 PM   #4505
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Stop rubbing it in
Yep sorry, the ally bumpstop cap
Old 09-28-2013, 04:32 PM   #4506
Mudguts
Mudguts's Avatar
Oddometer: 2,114
The bump stop on the enduro it 40 mm but you can get then in different heights and density , you could get a shorter and harder or taller and softer , all depend on what the RIDER wants you could even make a duel density for nice progressive bump stop it would flog out pretty quick but for racing NP
Old 09-28-2013, 04:35 PM   #4507
Mudguts
Mudguts's Avatar
Oddometer: 2,114
I,m sure the SMC has same shock different valving
What are you trying to do ? I had my shock lengthened giving me 295mm travel nice and plush 100% better then stock bone jarring teeth rattling pos
Old 09-28-2013, 04:41 PM   #4508
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
I've got both shocks apart.
The shaft is longer on the SMC and the ally dustcap is shorter. So potentially more travel than an Enduro, unless the dustcap is the same as on the earlier enduros
Old 09-28-2013, 04:42 PM   #4509
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
How did they lengthen your shock?
Old 09-28-2013, 05:07 PM   #4510
gen
gen's Avatar
Oddometer: 802
SMC shocks were always 250mm travel whereas the Enduro R came with 275mm iirc. So that may explain the difference.
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is online now   Reply With Quote
Old 09-28-2013, 05:12 PM   #4511
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Some photos...
The difference in shaft lengths. The shorter on the left is the 2012 690R and the longer on the right is the 2009 SMC
The difference in dustcap cover height. The shorter on the left is the 2009 SMC and the right is the 2012 690R.
It is about 4or 5mm shorter. This equates to about 20mm more wheel travel all other things being equal, but may lead to the 18" wheel of the R hitting the underside of the tank, I don't know
This little adjuster is prone to seizing up. Good idea to have it greased up when during next shock service.
This one was seized as was the alloy needle. The alloy needle is hollow so don't grab it too hard to pull it out as I did.
Once the chrome shaft is out, and the grub screw that secures this adjuster in place, place some oil in the lower clevis and screw the shaft back in until the hydraulic pressure pops this adjuster out
Just a shot of the SMC shimstack
Big Willy screwed with this post 10-01-2013 at 02:15 AM
Old 09-28-2013, 05:12 PM   #4512
shaun66
Oddometer: 150
I need more bench space.
shaun66 is offline   Reply With Quote
Old 09-28-2013, 11:24 PM   #4513
Mudguts
Mudguts's Avatar
Oddometer: 2,114
Hey B W I have an 09 690 so my standard length is 275mm of travel
Where the 012 is 250 mm
But I've had my shock modifided to 295mm of travel of sweet plushness
Old 09-29-2013, 03:25 AM   #4514
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Mmmmm...sweet plushness
Old 10-01-2013, 01:12 AM   #4515
LukasM
Oddometer: 5,417
Do you know what parts it took to get a longer stroke, and I assume the shock was lengthened the same amount so that the wheel still bottoms out in the same place and not against the tank?
Cheers
Times are GMT -7.   It's 10:33 PM.
