Old 10-01-2013, 02:46 AM   #4516
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,106
Bottom of the stroke is the bottom of the stoke, your extending the shaft at the top so bottom out is not and issue the bike is taller , you could modify the bump stop that would give you and An. issue
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 10-01-2013, 03:13 AM   #4517
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
Can you measure the alloy cup on the bottom of the shock for me, the thing with two small holes in it for knocking it off to get to the dust seal?
I've shown 2 in my second photo...just wondered what the pre 2012 R models had
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 10-01-2013, 03:24 AM   #4518
cheekorollo
cheekorollo's Avatar
Oddometer: 74
Quick question. Are all the feet on the set base supposed to have the rubber stand offs? The middle two feet on my '12 seat don't have em... Have I lost them or were they never there in the 1st place?
Sent from my Galaxy Nexus using Tapatalk 2
2012 KTM 690 Enduro R. Only broken down twice!
2004 KLR650. Was tired, but trusted. Now retired.
cheekorollo is offline   Reply With Quote
Old 10-01-2013, 03:32 AM   #4519
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
Mine has them Cheeko
Old 10-01-2013, 04:45 AM   #4520
Mudguts
Mudguts's Avatar
Oddometer: 2,106
If you need spare rubbers check the standard plastic plate if not in use
Old 10-01-2013, 07:25 AM   #4521
cheekorollo
Oddometer: 74
Thanks Gents. Looks like 5 bucks a pop from KTM. I think I might just cut down a cork from a bottle of wine...
Old 10-01-2013, 02:59 PM   #4522
Baric
Oddometer: 138
You might want to re consider the $10 investment as my seat cracked were your rubbers are missing mine had the rubbers
Had it plastic welded all OK
Baric is offline   Reply With Quote
Old 10-01-2013, 06:14 PM   #4523
Sol Erzenberg
Lost somewhere
Sol Erzenberg's Avatar
Oddometer: 1,445
My seat has cracked through the plastic opening under the front of the seat where it inserts into the metal screw that holds it in place to the bike. This was my KTM comfort Gel Seat - not happy at all..
2009 KTM 690 R
"Thats A Sweet Noise You Got There Man, I Had You Picked Clear Across The Mallee"
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1979 Honda CR125R Elsinore.
1978 Suzuki RM 100.
ARIEL MCC
Sol Erzenberg is offline   Reply With Quote
Old 10-01-2013, 06:26 PM   #4524
Sol Erzenberg
Lost somewhere
Oddometer: 1,445
Originally Posted by shaun66 View Post
Safari tank turned up (white ), Fairing ( Alberto ), wings Muffler, uni filter, led blinkers. Looks like i get to spend the weekend in the shed.
Post up a photo or two when you are finished..
2009 KTM 690 R
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1978 Suzuki RM 100.
ARIEL MCC
Old 10-01-2013, 06:46 PM   #4525
mrwocky117
Oddometer: 163
Safari tank
I'm interested as well. Safari tank on my '09 R fitted like a dream. New tank on my '13 not such a good fit. Need to go to the left about 15mm on the seat mount. The spacing at the forks was in consistent, too close one side.
mrwocky117 is offline   Reply With Quote
Old 10-01-2013, 10:59 PM   #4526
chrisamberely
USMC. (retired).
chrisamberely's Avatar
Oddometer: 138
I have cracked the seat pan on pretty much every dirt bike I ever had, apart from the early bikes with metal bases. Hondas were the worst. U can get a half decent plastic repair kit from auto outlets that last as good as plastic welding.
The harder u go, the quicker they crack.
Off to bed now, it's about 11.15 over here.
chrisamberely is offline   Reply With Quote
Old 10-02-2013, 01:30 AM   #4527
Sol Erzenberg
Lost somewhere
Oddometer: 1,445
It's only 5:00pm here in South Australia, hell of a time difference between here & Western Australia it seems ?
2009 KTM 690 R
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1978 Suzuki RM 100.
ARIEL MCC
Old 10-02-2013, 06:12 AM   #4528
chrisamberely
USMC. (retired).
Oddometer: 138
I work in West Oz but I'm back in Colorado for a friends wedding, plus to catch up with daughter number 1 who just gave us grandchild number 3.
Old 10-04-2013, 02:30 AM   #4529
Sol Erzenberg
Lost somewhere
Oddometer: 1,445
Congratulations mate..
2009 KTM 690 R
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1978 Suzuki RM 100.
ARIEL MCC
Old 10-05-2013, 02:41 AM   #4530
shaun66
Oddometer: 149
You would think those wankers at KTM would fix known problems by now. No wonder they have fuel pump problems.
Thought i would have a look inside while fitting the Safari tank adapter
i removed the filter
& fitted it here.
shaun66 is offline   Reply With Quote
Times are GMT -7.   It's 08:56 AM.
