Old 10-10-2013, 07:07 AM   #4576
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
I went with ADV Member Rbotts set up from here:
http://www.advrider.com/forums/showt...ighlight=rbott
Beautiful machining, top job and good to deal with.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 10-10-2013, 05:23 PM   #4577
Sol Erzenberg
Lost somewhere
Sol Erzenberg's Avatar
Oddometer: 1,462
Originally Posted by BygDaddee View Post
So while I was at it I also ordered a G2 Throttle Tamer to help on the technical hill climbs especially.
Originally Posted by Hoots View Post
I'm curious to hear how the G2 Throttle Tamer pans out ...
Yeah me too ...
2009 KTM 690 R
"Thats A Sweet Noise You Got There Man, I Had You Picked Clear Across The Mallee"
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1979 Honda CR125R Elsinore.
1978 Suzuki RM 100.
ARIEL MCC
Sol Erzenberg is online now   Reply With Quote
Old 10-11-2013, 11:19 PM   #4578
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,114
FYI
Stumbled cross a new lead on fuel pumps a the mower shop today
It a kholer Kawasaki ride on FI pump so the pressure should be right just waiting for a price
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 10-12-2013, 04:54 AM   #4579
chrisamberely
USMC. (retired).
chrisamberely's Avatar
Oddometer: 140
I bought a spare fuel pump from Felco on a certain big online auction site...cost was about $40
Direct replacement for the original pump. Just gonna keep it as a standby. I got free shipping over here but to ship to my place over in Australia would only have been $15
If any1 is interested and can't find it pm for a link.
chrisamberely screwed with this post 10-12-2013 at 04:55 AM Reason: Forgot the last line.
chrisamberely is offline   Reply With Quote
Old 10-12-2013, 07:58 PM   #4580
shaun66
Oddometer: 150
Modded top tank bolt.
Anyone know what this is, no not the front guard
shaun66 is offline   Reply With Quote
Old 10-12-2013, 11:19 PM   #4581
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Air Sensor for the ECU and you must install it with the pipe facing downwards.
Andy
Old 10-12-2013, 11:21 PM   #4582
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
The bolts you put through for your tank bolts should be High Tensile, what you have done is similar to the Rally Raid set up and they are high tensile alley key head bolts.
Andy
Old 10-13-2013, 01:12 AM   #4583
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,019
Originally Posted by Sol Erzenberg View Post
Yeah me too ...
It works great with Berg 570's.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 10-13-2013, 03:45 AM   #4584
shaun66
Oddometer: 150
Getting there slowly,
Old 10-13-2013, 12:42 PM   #4585
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Looking good already Shaun
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 10-13-2013, 01:02 PM   #4586
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Big wills,
Looking at preventative measures for my latest shutdown as I am unlikely to isolate the fault.
Looking at running "Engine Ice" coolant as it looks to run the engine slightly cooler. Had considered "Liquid Intelligence" but it looks like it will just prevent boiling as it raises the boiling temp but won't necessarily run the bike cooler. Might put a switch in the fan circuit like Kato has done so I can select it on in the hard stuff.
Also looking at trying to insulate the fuel lines and remove any possible tight bends, might try and aluminium wrap to reflect any heat. I heard on the Dakar a senior Honda guy recommended larger diameter fuel pipes but I don't know if I could make that work with all the end fittings required to be standard size.
Also getting the injector cleaned and pattern checked properly.
What do you reckon.
Andy
Old 10-13-2013, 01:51 PM   #4587
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Hey El Plonker.
From what I remember, Engine Ice is a polypropylene glycol as opposed to the run of the mill ethylene glycol. I personally wouldn't bother.
What you could try is the 66/33 ratio of water to ethylene glycol, water being the best transferer of heat there is, after all we're not in Austria and we don't need an antifreeze.
The fan switch is a really good idea especially with this heat coming on.
As for the fuel pumps, I reckon they're probably all from the same factory in China whether they be the new ones or the older ones.
Most of what I've read and experienced points to the fuel pump being the problem or sometimes a clean of the injector.
Have you tried putting a pressure tester in the line somewhere? They are cheap to buy off Ebay from what I've seen.
Good luck with the fiddling. Seems to be part and parcel of owning European machinery
Old 10-13-2013, 03:00 PM   #4588
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Just had a good look around and realised when I last changed my external filter I had left it pulled out and hence was sitting about 10mm away from my exhaust, I have tucked it back in and out of the way and will see how that goes, as the canam filter is metal it may well have been enough to cause a vapour lock. I can reroute it to the other side of the bike or back up where the quick disconnect was but I will see how it goes as it is easily accessible at the moment and great for accessing to check fuel line pressure. May look at getting a fuel pressure sender but will see how the quick fix goes first.
Thanks for help big dick.
Andy
Old 10-13-2013, 04:01 PM   #4589
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
I think you might have solved it el plonko
Old 10-14-2013, 03:06 AM   #4590
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Got my injector cleaned this morning by a mobile guy Jay who has his own business "Brisbane Fuel Injection Services" 0448 500 800, decided now to do this each service. He charged me $45 as he was local, normal min charge is $60. He showed me the spray pattern before and after and the change in delivery flow timed over 30secs and it was improved so I reckon well worthwhile.
Andy
Times are GMT -7.   It's 05:52 PM.
