Old 11-20-2013, 02:35 AM   #4681
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
Here's a few links I have Hdog
Ponkins 690 Fuel filter
KTM690 Fuel Filter Fitting
KTM690 Fuel filter
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 11-20-2013, 04:01 AM   #4682
hdog
hdog's Avatar
Oddometer: 556
Thanks big willy, that's what I'm looking for...do you know if el ponkins set up was successfull . I like the idea of doing away with the internal filter and replacing with an external ..cheers
I only need 14 hp to ride around oz ...the rest is wheelspin
KTM 1190 R
KTM 690 R
hdog is offline   Reply With Quote
Old 11-20-2013, 04:16 AM   #4683
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
He'll either be along at some stage or per'aps pm him .
I haven't gotten around to doing anything about the filter myself so can't comment sorry
Old 11-20-2013, 04:41 AM   #4684
shaun66
Oddometer: 149
Hdog, There is better places to place a filter than where EL Plonko has his. A metal bodied filter right next to the exhaust pipe is just asking for a fuel vapor lock.
Just my 2c worth.
shaun66 is offline   Reply With Quote
Old 11-20-2013, 05:09 AM   #4685
hdog
hdog's Avatar
Oddometer: 556
Yeh thanks for the input guys. It's got RR tanks on it so there are fuel lines already running along the frame. I may be able to find a spot for an external filter. If not what do you think of a profill pump sock and a filter back inside the tank. Will the sock lengthen the filter life or is its purpose just to stop debri from getting to the pump. I've been stranded on my previous bike , husky 610 which runs the same pump as the 690 ,so I'd like to try for a preventative fix....
KTM 1190 R
KTM 690 R
hdog screwed with this post 11-20-2013 at 05:16 AM
Old 11-20-2013, 12:44 PM   #4686
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,052
Yeh mine has been successful, I did think I had vapourlock issues at one stage but it turned out not to be the cause.
I have rotated the filter bracket slightly inwards since the photo so there is quite some air between it and the exhaust. I like it there for ease of replacement. EFI systems running at 50 PSI shouldn't get vapour lock according to cyberspace.
I have the profill filter on my pump inlet and I always refuel through a Mr Funnel Filter which prevents water and dirt getting in the tanks. I change both the Profill filter and Canam external filter every service and also now have the injector professionally cleaned every 15000km.
I PM'd you my complete build thread and EFI Idiots guide details.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 11-20-2013, 01:35 PM   #4687
Jawk
Im lost again.
Jawk's Avatar
Oddometer: 225
just changed my inline filter (standard factory one) in the tank and fitted a profill on the end of the pump - the amount of black monkey shyte in the filter was amazing (I cut it open for a look).
KTM250exc- for sale, KTM690e
Jawk is offline   Reply With Quote
Old 11-21-2013, 12:18 AM   #4688
dewe74
dewe74's Avatar
Oddometer: 110
I have the exact filter setup as El Ponkin and have never had an issue. Can't recommend to remove the internal one or leave it the same but i'm happy with how mine has worked out.
dewe74 is offline   Reply With Quote
Old 11-21-2013, 12:13 PM   #4689
hdog
hdog's Avatar
Oddometer: 556
Thanks guys for all your advise, I can sort this now I am clearer...
Off topic. I was having a chat with Craig Hartley at the Sydney bike show, whilst looking at his 700 adv. I really like the tanks on it. Very well made out of thick thick plastic ... I asked if they would be available as a seperate purchase...he said quite possible in the near future..so another fuel tank option ,,,soon..
KTM 1190 R
KTM 690 R
Old 11-22-2013, 11:02 PM   #4690
mezcal
mezcal's Avatar
Oddometer: 435
Good news on the tanks hdog, I like the RR ones and the Safari but another option is always good.
Hoots I will check out the cafe, cheers. 2 day trip from here so I will find a pub or motel for a night. I am looking forward to seeing Terrys workshop
2011 Berg 570
mezcal is offline   Reply With Quote
Old 11-23-2013, 04:31 AM   #4691
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,052
The set up with their tanks is really clever as the mount points allow for expansion, something that always was a pain on the safari tanks on the 950/990. The 700RR is certainly well thought out and put together very well indeed.
Andy
Old 11-23-2013, 08:41 PM   #4692
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,106
For those whom want more filtration here's my solution
It is an Aeroflow 30micron FI filter
It will replace the quick disconnect
I'll have to hunt around but should be able to get 10micron but 30 ,60,&100 are standard
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 11-28-2013, 12:59 AM   #4693
shaun66
Oddometer: 149
Rally Raid
Anyone know if Rally Raid has a distributer in Aust. Interested in the bash plate with the water container because of the ability to mount their centre stand.
Old 11-28-2013, 01:01 AM   #4694
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,052
I don't know of one, always bought direct.
Andy
Old 11-28-2013, 12:33 PM   #4695
Hoots
Hoots's Avatar
Oddometer: 1,419
I'd buy direct ...
RR have unbeatable customer service ...
Hoots is offline   Reply With Quote
Times are GMT -7.   It's 10:52 AM.
