Go Back   ADVrider > Riding > Regional Forums > Australia
Old 01-06-2014, 01:50 AM   #4756
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,308
Originally Posted by Big Willy View Post
I cut part of the red plastic cover away on the positive battery terminal so's I could attach a 900ma charger and have done so with no ill effects.
Don't know how the bike's electronics would react to any more amps than that though.
Just be sure your charger doesn't supply more than your alternator and you should have no problem. And make sure you have good connection to the battery before turning battery charger on.
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 01-06-2014, 02:34 AM   #4757
Eagle`02
Eagle`02's Avatar
Oddometer: 229
Originally Posted by Oz-Strom View Post
Had a search but didn't come up with anything specific.
Any ideas on whether it is OK to connect a battery charger to the 690? Do I need to disconnect the battery from the bike? Or can I leave it all wired up?
I have a C Tek 7 phase trickle charger which has a small lead with plug supplied that attaches permanently to the battery terminals, simply flip the seat and plug in the charger to use it overnight or for longer term use if not riding the bike.
Have used it for 3 years and never a prob,,,, never a battery drama either
Eagle`02 is offline   Reply With Quote
Old 01-06-2014, 06:41 PM   #4758
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 782
thanks for all the replies
OK I will check the charger amperage and give it a short burst.
cheers
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 01-07-2014, 03:07 PM   #4759
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 782
Charged up in 20 min no problems - thanks for the advice
Cheers
Graham
Old 01-09-2014, 02:52 AM   #4760
LukasM
Oddometer: 5,427
Originally Posted by shaun66 View Post
New uni filter
This looks much better than the old pod style.
Is there any spring wire in there or is it easy to clean? Could it be packed flat (e.g. in a vacuum sealed bag) so you can carry a spare that's not too bulky?
Cheers,
Lukas
Old 01-09-2014, 03:16 AM   #4761
shaun66
Oddometer: 169
No spring. Foam is pretty thick on the base so i dont think you would get it much smaller. As far as washing it goes, i have no idea. Its only done one ride & i haven't washed it as yet.
shaun66 is offline   Reply With Quote
Old 01-09-2014, 08:32 AM   #4762
gen
gen's Avatar
Oddometer: 804
Nice! Where and when can we order one?
DoD#1458
gen is offline   Reply With Quote
Old 01-09-2014, 09:33 PM   #4763
shaun66
Oddometer: 169
http://www.uniflow.com.au/contents/en-us/d321.html
Old 01-10-2014, 04:33 AM   #4764
shaun66
Oddometer: 169
Good question, waiting for KTM Austria to get back to KTM Australia so i have been told. I was the head Mechanic at one of australia's leading Polaris dealerships for 10 years, I could get a response from the states in 48hrs.
Old 01-10-2014, 12:46 PM   #4765
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 2,068
It's all part of the KTM experience, the reason you pay extra
Then when you need the parts you can wait for those too.
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 01-10-2014, 09:35 PM   #4766
shaun66
Oddometer: 169
4th KTM, first thing to go wrong with any of them.
Old 01-11-2014, 02:10 AM   #4767
pete40
Life Behind Bars
pete40's Avatar
Oddometer: 1,313
Air Filter sealing
Yeah - ever since they sent out the K&N replacement foam filters I noticed that it doesn't want to sit properly exactly like yours. I have always been worried about dusting mine too. It's a shabby fit basically.
pete40 is offline   Reply With Quote
Old 01-11-2014, 03:06 PM   #4768
fearless phill 1
Oddometer: 9
when i bought my 2010 model i grabbed two uni filters [pod style] straight away
fitted them up the same way i have always done on my bikes with a bit of light grease around the base of the filter then fit it up.
For my long trip across oz i bought a sheet of thin filter foam and cut out pre-filters to fit in the top of the pod filter had about 10 made all oiled up and in a clip lock bag.
I could pull up pop the seat undo the top of the box and just replace the pre-filter it was quick and easy and did a really good job very little dust on the filter
These were a throw away item and cost bugger all
fearless phill 1 is offline   Reply With Quote
Old 01-11-2014, 03:10 PM   #4769
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,137
Nice one Phil
I've used chucks wipes as a pre filter a few times on multiway rides works a treat and cheap
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 01-12-2014, 02:42 AM   #4770
shaun66
Oddometer: 169
Not being rude here, but have you read the last few pages. The dusting of the engine has nothing to do with the airfilter fitment.
Times are GMT -7.   It's 09:15 AM.
