Old 04-05-2014, 08:33 PM   #4861
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,017
Originally Posted by creedyflyr View Post
Does any one else get wear marks on their tanks like this? Mine only wears on the right side. Left is not marked at all. I assumed its because the exhaust heat shield keeps your left leg away from the left side. Looking at some Techspec grippers http://techspec-usa.com/magento/inde...2-0006-c3.html to protect those areas. Any one used it?
Creedy.
Sorry I don't have a great picture, but you can see that I used the same tecspec as in your link on my tank here:
I noticed similar wear marks on my tank in just a few hundred miles, so the tecspec was one of the first things I did to my 690. 5 years and ~14,000 miles later and it still looks good!
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Old 04-06-2014, 03:58 AM   #4862
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,104
I have rear racks and they stop that happening.
Maybe steg pegs would be the go.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 04-07-2014, 01:11 AM   #4863
PilbaraGoat
PilbaraGoat's Avatar
Oddometer: 218
I didn't think they made steg pegz to suit the 690..but I asked in 2010.
Difficulties be Damned
PilbaraGoat is offline   Reply With Quote
Old 04-07-2014, 01:36 AM   #4864
creedyflyr
creedyflyr's Avatar
Oddometer: 237
Yeh, I already looked at the Stegz Pegs but none for the 690 unless you make them yourself.
Thanks J thats what I wanted to hear. I'll order some Tech spec pads.
Creedy.
creedyflyr is offline   Reply With Quote
Old 04-07-2014, 02:53 AM   #4865
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,876
Creedy.
When mine was brand new I had noticed others that had wear from inside legs on tank, so I bought some cheap clear vinyl sheet off eBay, cut to shape and hair dryer applied, worked like a treat. You could do same with black or carbon vinyl sheet
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is online now   Reply With Quote
Old 05-01-2014, 10:46 PM   #4866
PilbaraGoat
Oddometer: 218
I need one more quick fix for APC prep.
I've added three led spotlights to my handlebars - wired in with high beam only.
I would like to change the original headlight globes for some leds because I'm concerned (and a little bit ignorant) about the total draw.
I've got oxford heated grips
I've got an exo2 thermal vest
Can I get some led globes that I can just swap straight in?
The bike has been shipped already and I'll only have a morning in Melbourne to swap them over.
Any ideas?
Old 05-01-2014, 10:53 PM   #4867
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 768
From what I have read, LED headlight globes are not legal as a swap. I reckon you will be OK with the std bulb
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 05-01-2014, 10:55 PM   #4868
AusGoFar
get back on that horse
AusGoFar's Avatar
Oddometer: 924
i recently 'dropped' in a HID globe and ballast for mine. I can take some photos if required
AusGoFar is offline   Reply With Quote
Old 05-02-2014, 03:44 AM   #4869
PilbaraGoat
Oddometer: 218
legal schmeagal.....oh wait, it has to be roadworthy for the rally.
Thanks for the tip.
Is HID something I could do with minimal tools in an hour by the side of the road?
Old 05-02-2014, 04:01 AM   #4870
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,301
Any ideas?
APC dont go at night so you dont need lights mate.
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 05-02-2014, 04:07 AM   #4871
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,239
You're not just saying that?
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 05-03-2014, 12:55 AM   #4872
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,123
Nothing like a cold wet Saturday to do some maintenance
New front tyre
New rear tyre
New chain
New front & rear sprockets
New oil & filter
New oil screens
New brake fluid ( but I bought 5.1 should have been 3 or 4 )
New brake pad front & rear
New spark plug
Cleaned air filter & MAF sensor
Mount up new 690 rally vacuum pump and bracket
Fixed a couple little issues , just got to replace a fork seal while I'm in there I'll
Replace all the seals and bushes for SKF low friction seals scrapers and try the new SKF mud scrapers
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 05-03-2014, 01:29 AM   #4873
D-Rally
D-Rally's Avatar
Oddometer: 50
Brake fluid.
Hey Mudguts,
You can go ahead and use that Dot 5.1 brake fluid as it is only a temperature rating. It will still be synthetic and will mix with your original brake fluid no dramas.
You are actually using a better quality brake fluid.
Dot 3 = Boiling point of 300 degrees F
Dot 4 = Boiling point of 400 degrees F
Dot 5.1 = Boiling point of 510 degrees F
Motul even sells a product called RBF660 which obviously has a 660 degree F boiling point. We mostly sell this to guys doing Safari, Condo etc where high temperatures and excessive high speed braking is common.
The only brake fluid you cant use is Dot 5 which is silicon based and designed for old Harleys. They use this because they had such crappy rubbers in their master cylinders and would leak on the fuel tanks. Silicon brake fluid doesn't mark paint work like standard synthetic stuff does.
Have fun :)
New front tyre
New rear tyre
New chain
New oil & filter
New oil screens
New spark plug
Finding Time To Ride
D-Rally is offline   Reply With Quote
Old 05-03-2014, 01:44 AM   #4874
Mudguts
Mudguts's Avatar
Oddometer: 2,123
Thanks I remembered something about 5.1 silicon and rubber degrading
But must of had my wires crossed .
Something to do in the morning now the fluid is 5 years old and I boiled it last ride .
Once I drop in the stroker crank and the 104mm piston I'll need all the braking power I can get
Old 05-03-2014, 09:26 AM   #4875
PilbaraGoat
Oddometer: 218
Geeez Mudders you're a glutton for punishment!
That much maintenance would take me 5 years of motivation.
Hey Podge.....I just know I'll be the bloke who gets lost and breaks down at the end of the day. and I've got a little bit of riding to do either side of the apc.
I just realised the finke is a week after the apc and I've got to get my bike back to the west somehow........
and the lights are cool
Times are GMT -7.   It's 02:37 AM.
