Old 07-15-2014, 02:58 PM   #5086
Hoots
Hoots's Avatar
Oddometer: 1,376
Originally Posted by PilbaraGoat View Post
I'm not getting the 700 this time around,
so I'm looking for a way to get a little protection and somewhere to mount
the squadron leds :
There's also the Lynx from Britannia Composites
http://www.britanniacomposites.com/i...tmenu/lynxmenu
Hoots is online now   Reply With Quote
Old 07-15-2014, 10:50 PM   #5087
PilbaraGoat
PilbaraGoat's Avatar
Oddometer: 218
Because I'm so keen on getting the baja designs squadron leds I think I'm
a bit locked in to which farings have mounts for them.
I don't think the lynx or alberto faring is set up for them
I was happy with the wind protection I got from my ktm touring screen,
so I don't think I need full faring. It's just that I busted it and want something new.
I saw this (inmate) and thought it would do
Bugger about the Wide ratio gearbox expense....how can ACT do it so much cheaper? is it volume, simplicity, materials, quality?
Difficulties be Damned
PilbaraGoat screwed with this post 07-16-2014 at 12:25 AM
PilbaraGoat is offline   Reply With Quote
Old 07-19-2014, 12:11 AM   #5088
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
Managed to do a 140k loop today in the rain with hids blazing without the battery going flat , looks like I got
Magic fingers back
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 07-19-2014, 08:20 PM   #5089
Mudguts
Mudguts's Avatar
Oddometer: 2,105
Anyone got a rally cam floating around. I'd like to see how it goes with my bike
thanks
Old 07-19-2014, 10:08 PM   #5090
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
Gears can be very expensive to make and low volumes do not help.
Seth S
Seth S is offline   Reply With Quote
Old 07-22-2014, 09:51 PM   #5091
richo360
Oddometer: 886
Mine has been stalling a bit recently, esp at idle and low throttle applications (just off the stop). Added to that, it seemed fairly doughy on roll on applications around mid range.
Took it to Dale at MotoStar in Carrum Downs, he hooked it up to the computer and cleared a couple of fault codes- intake air temps was one he mentioned. May be when I was putting it all back together after the 700rr build, I had the ignition on a few times to get the lights etc to work, may not of had all sensors etc plugged into the loom at the time and caused some EFI/ECU confusion.
Definitely all good now though.
700RR
richo360 is offline   Reply With Quote
Old 07-23-2014, 01:40 AM   #5092
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,036
Intake sensor is fairly standard as you quite often switch the ignition during servicing with the airbox removed but just storing and then clearing a stored fault code won't make any difference to running. More than likely did a "reset adaptations" and a 15 min idle run.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 07-23-2014, 05:29 AM   #5093
richo360
Oddometer: 886
Andy
Yeh said he's meant to start if from dead cold, then run it till the thermo fan kicks in to get the ECU to re learn. But it was hot when I got there, but did cool a touch whilst we stood around yakking.
Did say even though it wasn't dead cold, all the readings were within the 'green' range, so all good. He, and I, we're pressed for time a touch.
It definitely went better on the way home. The front wheel did about half the miles as the rear......
700RR
Old 07-23-2014, 05:42 AM   #5094
mrwocky117
Oddometer: 158
Wish mine was a simple fix ........
Still waiting for the throttle body replacement ....... !!
mrwocky117 is offline   Reply With Quote
Old 07-23-2014, 07:46 PM   #5095
Mudguts
Mudguts's Avatar
Oddometer: 2,105
Originally Posted by Hoots View Post
Can't help you with the fairing issue (I'm happy with the hardparts screen), but very interested in this wide-ratio gearbox ...
For those who didn't notice the link:
Just some food for thought , what if gears from a 990 fit ?
Old 07-23-2014, 08:03 PM   #5096
Hoots
Hoots's Avatar
Oddometer: 1,376
Originally Posted by Mudguts View Post
Just some food for thought , what if gears from a 990 fit?
Interesting idea - anyone able to answer this ... ?
Old 07-23-2014, 09:37 PM   #5097
Mudguts
Mudguts's Avatar
Oddometer: 2,105
I might know of a couple of ppl with spare 990 gear boxes , I'm looking to re build my bike in the next 3 months
2012 stroker crank
With hi comp piston or standard possibly going to 707cc all depends
If I can get my hands on the 990 GB I'll have a look
Old 07-23-2014, 10:25 PM   #5098
Hoots
Hoots's Avatar
Oddometer: 1,376
2012 stroker crank
I don't know anything about the specs (ratios) for the 990 gearbox
Will be good to hear how you get on re' fitment
Old 07-23-2014, 11:10 PM   #5099
Mudguts
Mudguts's Avatar
Oddometer: 2,105
690 ratio 36:79
990 ratio 35:67
Old 07-25-2014, 04:50 AM   #5100
CitrusTwin
A Better Attitude
CitrusTwin's Avatar
Oddometer: 69
Wicked Biting the orange bullet
I'm in the market for a new steed and it had to be another KTM. I've been following this thread with much interest over the last 6 months to help with the decision - a low km late (as they go) model 640Adv because FI scares me, or a shiny new 690 Enduro adventurised?
After the comments here over the last month in particular I'd decided to play it safe and find a good 'ol 640 Then today I thought fug it and ordered a shiny new 690 with fruit
Can't wait
'14 KTM690: Adventurised
7100km Central Aus Trip: - http://www.advrider.com/forums/showthread.php?t=700364
Album
- http://s1098.photobucket.com/albums/...endan_Stewart/
CitrusTwin is offline   Reply With Quote
Times are GMT -7.   It's 10:32 PM.
