06-28-2008, 10:17 PM
#1 |
Hopefully Riding
Oddometer: 3,801
KLX300 thread
I bought a KLX300r a month ago and the poor little beast doesn't have a thread of its own so I figured I'ld start one.
Here is mine: ![]() ![]() This is its big brother in my garage: ![]() When I got mine it had about 500 miles on it and was completely stock. I have started moding it. Bash plate lever guards Crankcase breather Dynojet stage 2 kit ACR mod Renthal bars took top off airbox Exhaust tip removed Tail bag fender bag T-mod for carb vents Acerbis headlight In the future I'ld like to add Bigger stator Heated grips Acerbis tank Fourstroke works header I know there has to be other KLX300 riders on the board. Happy Riding
"All the problems we face in the United States today can be traced to an unenlightened immigration policy on the part of the American Indian." Pat Paulsen ironbrewer screwed with this post 06-28-2008 at 10:25 PM |
06-29-2008, 02:12 AM
#2 |
tEAM iDIOT
Oddometer: 5,510
Funny you should start this thread today.
I just got back from the first shake down run on mine. Although mines not a true 300, it's an 04 250 with a 97 300 motor in it... But here is a pic of the donor bike... ![]() And in action. ![]() (Before anyone asks I put the 300 in because I blew the 250 up, and yes I had a 300 kit in it anyway...)
tEAM iDIOT... tHE oRIGINAL. Hard Core Dirt Touring. tHEtREV screwed with this post 06-29-2008 at 02:19 AM |
06-29-2008, 06:02 AM
#3 |
Hopefully Riding
Oddometer: 3,801
Excellent any other modifications??
"All the problems we face in the United States today can be traced to an unenlightened immigration policy on the part of the American Indian." Pat Paulsen |
06-29-2008, 08:23 AM
#4 |
Oddometer: 1,137
I have a KLX300 with the 331 BBK (compliments of PO) from Jerry at FSW. Came with Renthal bars. I've added '95 KX250 forks and raising links for the rear to maintain geometry. I also procured an FCR35 - ebay seller didn't know what he was selling (thought it was a 39) which I'm presently tidying up. I need to freshen it up with rings and valve guide seals cause it smokes for about a minute after startup. Also added aftermarket footpegs, fender bag, and a new cap for the stock exhaust. Getting ready to add a dualsport kit and change the granny gear 13T IIRC front sprocket for something more roadable. Starts 1st or second kick and easy-peezy to ride anywhere. I'm paring down the stable but the KLX stays. That's right - my LC4e goes before the KLX. Gotta love the simplicity.
Dean |
06-29-2008, 08:35 AM
#5 |
Hopefully Riding
Oddometer: 3,801
What other mods did you have to do to add the 95 kx forks? Did the stock triples and wheel work??
06-29-2008, 12:02 PM
#6 |
Oddometer: 1,137
Ironbrewer - If you use 94 or 95 KX125/250 forks you can use the stock KLX triples, wheel, calipers, rotor, etc but need a spacer to line it all up. A gentleman on thumpertalk used to make the spacers. I had to change the front brakeline cause the KLX has a lug built into the fork lower end for the brakeline. Used a piece of hardware to attach it to the upper end of the KX fork guard like most modern dirtbikes. The KX forks are completely adjustable (compression and rebound) with a longer travel. They are about 1.5 inches longer though - so I raised them up in the triple - 3/4" - and used the raising links to raise the rear. It's a taller bike now but has a leaner, rangy look to it. Much safer on the side-stand as well. No longer wants to dig in and fall over since it's more upright.
06-29-2008, 02:14 PM
#7 |
I have no soul
Oddometer: 5,583
Here's my 2003..Bought it new in 02' and it's still kickin. Not much done to it power wise; Free mods, a re-jet and a Twin air filter .Other parts are Moose hand guards,ProTaper CR high bars, Baja Designs DS kit,Trail tech vapor,UFO kx250 fork guards, Kenda 760s f & r . Soon it's getting a new exhaust ,wide foot peds and a larger tank
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~ My HD Scram-ster build Help Save a Pit-Bull Ginger Beard screwed with this post 06-30-2008 at 07:43 AM |
06-29-2008, 06:30 PM
#8 |
Oddometer: 1,137
Wishin4woods - I see your KLX is streeterized. What's your gearing and how is it onroad?
06-29-2008, 07:41 PM
#9 |
Follow me
Before and After
1998 KLX300R Before on 5-28-08
![]() AFTER on 6-28-08 it became a 2007 KLX300RS 4.6 racetech springs, Ohlins rear, New bottom end with electric start, taller/straighter bars, 240 watt stator, REAL Headlight, MX rear fender with LED Stop/Tail light, Hydraulic Clutch, New Frame and Suspension linkage, New swing arm, New Clark Gastank on order, New Seat, New wheels, New Chain,new lugage rack with chain saw plate. TO do: Install old 300 Kickstart gears and lever Install Clark Tank Install power port for GPS ![]() Go work on new trails,,,,,,,,,,,, Follow Me!
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE Robert rwamf homepage rwamf screwed with this post 08-16-2008 at 01:29 PM |
06-29-2008, 07:47 PM
#10 |
Hopefully Riding
Oddometer: 3,801
rwamf,
Why do you like the clarke tank over the Acerbis. I would think the radiator protection afforded by the Acerbis would make it the choice tank. Jim
06-29-2008, 09:01 PM
#11 | |
Follow me
I want to keep this a small bike for gnarley single track, that is where I will ride it so I don't need the extra bulk.
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE Robert rwamf homepage |
06-29-2008, 11:05 PM
#12 | |
KL"X" not "R"
Oddometer: 884
Mine and My chica shortly before removing another turn signal.
06-30-2008, 05:57 AM
#13 |
Oddometer: 1,137
rwamf - you're the guy to answer this for me. I'd love to add a light rack on the back of my KLX300. I'm wondering if the frames are the same between the 330 and 250s - the rear half that is. Would the KLX250 rack work for me?
Thanks Dean |
06-30-2008, 07:50 AM
#14 | |
I have no soul
Oddometer: 5,583
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~ My HD Scram-ster build Help Save a Pit-Bull Ginger Beard screwed with this post 06-30-2008 at 08:15 AM |
06-30-2008, 08:48 AM
#15 | |
Follow me
