Old 10-26-2012, 04:26 PM   #376
lukeinlondon
lukeinlondon's Avatar
Oddometer: 431
http://losangeles.craigslist.org/sfv...309284556.html
thoughts?
lukeinlondon is offline   Reply With Quote
Old 10-26-2012, 04:32 PM   #377
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,308
I bet it has alot of $$ in it. Just check its condition over real well.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 11-24-2012, 05:49 PM   #378
Bogiewan
Not So Gnarly Adventurer
Bogiewan's Avatar
Oddometer: 135
Oil Filter spring
I just recently traded my DRZ for a 97 KLX300.
When I started to change the oil, I found a spring in the oil filter compartment, just laying there. I don't see any indication in the service manual that there is supposed to be a spring in there.
It does have a K&N filter.
Anyone know where that spring goes ?
Nothing is impossible for the man who doesn't have to do it himself - Disciples of the Luftkopf
Inspirational Poster: "It may be that the purpose of your life is just to serve as a warning to others."
Bogiewan is offline   Reply With Quote
Old 11-24-2012, 06:07 PM   #379
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,308
Do you mean it was lying in the oil filter area? If so it goes in the middle of the tongs to put pressure out against the oil filter.
Old 12-16-2012, 10:21 AM   #380
djchan
djchan's Avatar
Oddometer: 1,173
300R float height
Anyone know the measurement for float height on my 2004 KLX300R with stock CVK carb?
My bike starts and runs extremely well - yes, I've hand-started it. Unfortunately it's puking gas on my barn floor when I leave it unattended for a bit and the petcock on.
Odd thing is it's puking through the bowl drain hose - not an overflow. May just need to loosen and reseat the drain screw. Anyway, the carbs coming off because I don't know what the jetting is - and I may want to ante up for a pumper, but in the meantime - I don't want gas on my floor.
used to have - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Bandit 1200S, 2007 KLX-250, 2004 KLX-300R and a 2002 KTM 400EXC.
Now own - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 CRF250X.
djchan is offline   Reply With Quote
Old 12-29-2012, 09:41 AM   #381
djchan
djchan's Avatar
Oddometer: 1,173
Never mind on that previous post - float height.
I have a TM36-68 enroute.
Old 02-16-2013, 05:55 PM   #382
craydds
craydds's Avatar
Oddometer: 1,164
desert tire recommendation?
I am looking for new tires for my 2003 KLX. I ride in the desert around Las Cruces, Nuevo Mexico. It is a lot of hard, rocky riding. I want tires that can withstand the rocks and not get torn up in a few miles. Sorry if this has already been addressed, I did not do a search. I appreciate hearing about your recommendations and experiences. Thanks!
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 02-16-2013, 06:17 PM   #383
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
Kenda Parker Desert or Maxxis Desert IT. I think the Parker front tire may be one of the best desert tires I've tried. It's the most resistant to side knob ripping that I've used.
TNC is offline   Reply With Quote
Old 02-16-2013, 07:56 PM   #384
craydds
craydds's Avatar
Oddometer: 1,164
Thanks, TNC! I will get some NEW TIRES.
ABC #12947
'75 R90S
Old 02-17-2013, 06:06 AM   #385
craydds
craydds's Avatar
Oddometer: 1,164
80/90-21 vs. 90/90/21 ???
For the 2003 KLX300 - I think the front tire size is 80/90-21, is this correct? I find a limited choice of tires in the 80/90-21 size, but more tires in the 90/90-21 size. How critical is the size? Does it matter that much? I do not know. Also, the rear tire is 100/100-18, right? I find a good number of tire choices in this size. Thanks for any help!
ABC #12947
'75 R90S
Old 02-17-2013, 06:26 AM   #386
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,308
Its not critical
Old 02-18-2013, 06:52 AM   #387
craydds
craydds's Avatar
Oddometer: 1,164
Originally Posted by Yokomo View Post
Its not critical
Then, it looks like I have lots of good choices. Thanks, Yokomo!
ABC #12947
'75 R90S
Old 02-18-2013, 07:20 AM   #388
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
Its not critical
Ditto..not an issue.
Old 02-18-2013, 05:59 PM   #389
craydds
craydds's Avatar
Oddometer: 1,164
Found some tires at Chaparral in the right sizes.
ABC #12947
'75 R90S
Old 02-19-2013, 08:10 PM   #390
EnduroTom
Oddometer: 39
How to Prevent Kick Starter from Getting Stuck
I'm a new owner for a 2001 KLX300. After riding on some rough stuff this weekend, I hear a whirring noise coming from the engine. Looking down, I noticed the kick starter was stuck behind the aluminum guard that protects the brake hose (going from the brake reservoir to the master cylinder). I was able to get the kick starter unstuck, but during the day it got stuck 2 or 3 more times. I got a bit paranoid and was looking down periodically, but never figured out how it gets stuck.
Looking at some photos on the web, I noticed on my bike the wire tab that is suppose to keep the kick starter in place has been broken off. I've also read this can cause major damage to the transmission, so I'd like to find some way to prevent this. Any ideas? Maybe a Works Connection frame guard will prevent the kick starter getting stuck?
Thanks,
Tom
EnduroTom is offline   Reply With Quote
Times are GMT -7.   It's 04:36 PM.
