Old 10-30-2010, 10:54 PM   #31
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,447
re-doing hp-2 sidestand
we should have no problem converting this to an adjustable version,,,just send it in and share the information you want to have it end up,,just like you did below,,,
ie i wan the finished stand to adjust from BWOE 13-14'' and we'll git er done
woody
Originally Posted by space
Hey Woody,
You still doing this adjustable sidestand deal? I've got an HP2 Enduro sidestand that you lengthened a couple years ago by 2". Worked great, but I replaced the OEM sidestand block with your steel one, and now it's too long. Here are some pics:
I'd like it shortened by 1" and then a +/- 1" adjustment on top of that since I run 21/18 and 19/17 wheels. Can you do that on this stand? My guess is it's got some steel rod already welded inside it from the last work....
Thanks.
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 10-31-2010, 10:13 PM   #32
scottdc
Oddometer: 296
Dr650?
This is timely as I was just looking for an adjustable sidestand solution for my DR650 a couple days ago with no luck and just ran across this. When loaded with luggage my DR tends to sit horizontal and if I don't park it on a perfectly level surface it feels like it'll go over if someone looks at it funny. Can this mod be done to a DR sidestand if I send one in?
scottdc is offline   Reply With Quote
Old 11-01-2010, 09:05 AM   #33
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,692
Would love an adjustable stand (a la DR650) for my TE610.
Old 11-01-2010, 10:03 AM   #34
HunSolo
Mad Monk
Oddometer: 396
Bigfoot
Hey Woody,
Certainly the big bikes benefit from a larger footprint. How about adding a larger asymmetric plate at the bottom of the stand? The aftermarket add-on plates (at least on the GS) interfere with big boots while riding, or occasionally while coasting until you get your heel off the plate and close the side stand switch.
HunSolo is offline   Reply With Quote
Old 11-02-2010, 11:56 AM   #35
Built to Last
Oddometer: 3,447
big foot addition to sidestand..
Originally Posted by HunSolo
Hey Woody,
we usually do that at the same time...i've got a pic somewhere on this thread...
w
Old 11-02-2010, 12:01 PM   #36
Built to Last
Oddometer: 3,447
yes we can,,,
yes,,as wella s making the foot bigger...
Yossarian™ Would love an adjustable stand (a la DR650) for my TE610.
same as above,,yes we can send old one in and we'll create the range you need
w
Old 11-13-2010, 04:17 PM   #37
dc4stroke
dc4stroke's Avatar
Oddometer: 102
bump
What're we talkin bout?
dc4stroke is offline   Reply With Quote
Old 11-14-2010, 08:32 AM   #38
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,169
Originally Posted by woody's wheel works
the problem: we've all been thru this before,,,the bike feels too vertical and tippy when parked using your sidestand,,,,a case encountered by '08 KLR owners and folks who sumo their bike ie putting smaller wheels than the bike originally came with,,,,or the other way,,ie having a bike that leans too far over and feels like it'll fall down,,which my R1100GS has done on numerous occasions,,especially with a full tank of gas and lots of gear,,,or we have the folks that put larger wheels going from 19'' fronts to 21'' BWOE
Rx:solution #1... for those who will PERMANENTLY keep the new/current configuration the solution is straight forward straight forward,,,we measure what is and what we'd like and modify the sidestand by lengthening/shortening it,,real simple,,,unless of course you are the frustrated owner of a HP-2 and the factory sidestand bracket is the problem from being too weak as well as having too great an outward angle to the bracket
solution #2,,,for those that switch back n forth between several scenarios of ridung using different diameter wheelsets and/or suspension settings,,we can solve that problem by :
A,,buying an extra sidestand and modifying them to fit each particular need,,,downside of course swapping you now need to swap sidetands in addition to your wheels,,,or ,,,
B..modifying you existing sidestand so that it would be adjustable to fine tune over a desired range,,,,below is one of my current ones,,,this one has a large nylock that allows the side stand to be adjusted by just twisting the foot-plate..the pics are self explanatory,,it works well and is speedy,,,my other version is similar only has a regular nut instead of the nylock. it uses a jam nut that needs a wrench or possible wings to be weldedon to lock the lower sidestand in place.
Below are some pics of an adjustable sidestand i created for my R1100GSwhich was tilted some 18 degrees,,,it's oem length is 13'' from the bottom of pad to the center of the pivot bolt,,,i cut a section out and welded it back together as you see,,, The sidestand can now go between 12.5" and 14.5". ,,,,currently at 14'' it straightened the bike to nice lean angle of 10 degrees,,,,,it is an adjustable sidestand with great strength.
How did you manage not melting the nylon in the nut when welding it?
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 11-14-2010, 08:51 PM   #39
Built to Last
Oddometer: 3,447
a better way to lock the side stand in the right place...
well we had plenty of wet rags around the bolt
FYI,,,i solved the problem by making two very thin jam nuts by cutting a std nut in half....so i use it to jam the side stand in it's proper place
woody
Old 11-14-2010, 09:01 PM   #40
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,169
woody
Ah! and I thought you were chilling it with liquid nitrogen
The jam nut thing is far superior IMHO
Old 11-14-2010, 09:41 PM   #41
Built to Last
Oddometer: 3,447
10-4 on that....OBTW even with the slightly melted Nylock i used on that prototype,,,,amazingly the lower half stays in place and hasn't rotated
w
Old 11-25-2010, 08:49 PM   #42
Swampy
Mayor of Swampyville
Swampy's Avatar
Oddometer: 707
Any plans for one for a Kawasaki KLX250? My wifes is 2" lower and we need to do something with the stand!
- Swampy
Riding Since 1978!
Pasco County Cemetery Tour
Swampy is offline   Reply With Quote
Old 11-25-2010, 09:18 PM   #43
Built to Last
Oddometer: 3,447
we do em all..
justtell me how much ya want off and we'll re-do em...woody
Old 09-21-2011, 09:29 PM   #44
mark sumner
Oddometer: 164
HP2 Side stand Bracket
Hi Woody, I replaced my bracket with the oem BMW bracket under warranty. Now it's getting sloppy. Are you planning another batch. I would be a buyer for either model. Regards, Mark
Love the 19" wheel you built for me.
mark sumner is offline   Reply With Quote
Old 09-22-2011, 08:19 AM   #45
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,291
Husky
I could use one for my '09 TE610. When I use my 17" sumo wheels, my stand sits the bike straight up, almost to the point of tipping over on the right side.
It's fine with the dirt wheels.
JustRon is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
