07-04-2008, 09:20 PM
#1 |
BurnsMoto.com
Oddometer: 1,241
FuzeBlock Install on a R12GS
Last year I installed a Blue Seas fuse box into the tail of my GS and a few of you guys said it was a stupid idea and "you'll end up moving it some day." Well that day has come. I was looking for a smaller size fuse block that would fit under the seat where I wanted it. I saw the 'behind the tank fuse block' install on 1150GS and thought it could be done on the 1200, but a smaller fuse box would be needed. Along comes the www.fuzeblocks.com.
I first tested with a vertical install of the box but it hit the inside of the top of the seat. First, I cut a mounting plate out out aluminum. ![]() Then I mounted to the bracket with 3m 2 way tape and the mounting screw. I removed the zip tie as it was not needed. ![]() The only con of the fuzeblock is that the conacts on the back are exposed and short circuits are possible. So, I covered the solders with electric tape. \![]() ![]() ![]() ![]() ![]() ![]()
Stephen -- 2007 R1200GS & 2002 XR650R BurnsMoto.com ZootFresh SAE to USB Chargers BMW Fuel Pump Bypass Cables - Powerlet Products - Weatherproof USB Chargers - Waterproof Panel Mount USB Chargers Burnszilla screwed with this post 07-07-2008 at 03:03 PM |
07-05-2008, 06:28 AM
#2 |
Oddometer: 23,806
That's a slick looking unit. Thanks for the pics - looks like a good improvement to you set-up.
07-07-2008, 02:07 PM
#3 |
More wag; less bark
Oddometer: 11,800
Very cool. My only comment would be that using a piece of old innertube might be better than the tape--at least it would take longer to wear through
P.S. it's www.fuzeblocks.com ian408 screwed with this post 07-07-2008 at 02:15 PM |
02-14-2011, 05:38 PM
#4 |
anatra di seduta
Oddometer: 4,349
Hey Burnszilla and/or ian408, have we determinated that the fuzeblocks.com device is the current state of the art in aftermarket fuse blocks for BMW motos?
I ask coz I just found this ![]() In my garage and it needs electrical farkles. Thanks, guys. |
02-14-2011, 07:24 PM
#5 |
Explorer
Oddometer: 118
+1 for Fuze Block
There is another thread here talking about fuse blocks for R1200's.
I went with the Fuze Block and would do it again tomorrow. Scott. PS Congrats on the new addition.
Scott 06 - BMW R1200GS 07 - BMW G650X Challenge - Gone 36 - BMW R12 |
02-14-2011, 08:15 PM
#6 |
Oddometer: 266
Are you not concerned with water rolling running right through that thing? I just installed the Eastern Beaver unit and I avoided that mounting location for that reason. I ended up installing mine in the tool tray like many others. I couldn't fit my tool roll in there anyway, so it was empty.
02-15-2011, 01:43 AM
#7 |
ekki-ekki-pitang
Oddometer: 200
Just about to install mine this weekend. Seems like a great piece of kit
02-15-2011, 05:18 AM
#8 | |
"Cool" Aid!
Oddometer: 41,488
The only thing I would do different is use liquid rubber tape on the back of the fuzebox instead of regular electrical tape. The regular electrical tape will peal off leaving a sticky mess when it gets hot. Jim
02-15-2011, 10:11 AM
#9 |
Beaver hunter
Oddometer: 36
Nice install. I have a low seat on my GS so not sure it would go there. Also good idea to have that there with the rain? Have mine under the tool box. I dremeled out the top part of the tool box and much more room. Very clean.
02-15-2011, 10:19 AM
#10 |
Oddometer: 2,426
I voted with my wallet for:
Your's was a nice install...but this guy also has a nice solution.
http://www.excelcyclewerkes.com/index_files/Page672.htm http://www.excelcyclewerkes.com/imag..._GSCentech.pdf |
02-15-2011, 12:49 PM
#11 | |
Oddometer: 40
02-16-2011, 12:56 AM
#12 |
Oddometer: 1,223
Yes, a nice install but I prefer mine away from the elements.
Doesnt get wet, plenty of room to play and proper tools go in a tooltube where they belong
02-16-2011, 01:54 AM
#13 |
Oddometer: 333
Better protection on the back.
Looks like a clean install.
Not to criticize, but I would be very concerned about the electrical tape wearing thru. If it does, you could have big problems and not likely at a convenient time/place. I recommend insulating it from shorting with something more durable than electrical tape. The inner tube idea isn't bad. Perhaps cutting a piece of flexible teflon cutting board. Cheap and easy to find and holds up well to cutting with a knife, so should be quite resistant for your purpose.
"Sometimes, it's hard to look cool..." _______________________________________________ Current bikes: 2009 R1200GS 2009 Buell 1125CR 2002 HD Heritage Springer 2004 ZX-10R 2003 SV650 1988 Sporty 883 (cafe project) Next Bike: Hmmmm.... |
02-16-2011, 08:04 AM
#14 |
BMW K12S rider
Oddometer: 124
You know they have a back plate available now from Fuzeblocks?
New units come with a spacer and a plastic back plate. |
08-29-2011, 07:04 AM
#15 |
Oddometer: 363
fuze bloc
Are these units holding up well?
solder joints ? connection points ? any gotchas ? tips ? i am going to install one like the authors install on the back side of the tank shortly and thought I would ask. Thanks Bruce
HB 05 R12GS,and a few airhead machines |
