Old 06-03-2014, 08:44 AM   #1
seatec OP
Dutch Transplant
seatec's Avatar
Oddometer: 809
Removing front Wheel
Tried search but kept getting an error.
On my previous bikes there was a proper way to remove and re install the wheels. Especially the front with the axle and the pinch bolts.
Any specific procedure for the 14 GSA?
THanks.
PS. Going to put new rubber on soon.
Got places to do and things to be.
'14 1200 GSA
seatec is offline   Reply With Quote
Old 06-03-2014, 09:08 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,371
Nothing special. Just take it off and put the new one on. The torque values are here: http://www.jimvonbaden.com/Wethead%20Torques.xlsx
JimVonBaden is online now   Reply With Quote
Old 06-03-2014, 09:17 AM   #3
seatec OP
Dutch Transplant
seatec's Avatar
Oddometer: 809
THanks.
'14 1200 GSA
Old 06-03-2014, 09:07 PM   #4
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Just make sure you tighten the pinch bolts last (after the axle nut).
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 06-04-2014, 05:39 AM   #5
seatec OP
Dutch Transplant
seatec's Avatar
Oddometer: 809
10-4
I usually bounce the front end a little before tightening the pinch bolts. Both have to be loosened to remove axle right? some bike you only loosen one side.
'14 1200 GSA
Old 06-04-2014, 12:36 PM   #6
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,428
Assuming the GSA is the same as the GS be aware that once you loosen pinch bolts and the nut on the left side of the axle and you can push the axle out. It does not unscrew from the right like the hexhead axles. That caused a few seconds of head scratching the first time I pulled mine.
There is a tiny spacer on the left side of the wheel. When you go to put the wheel back on the bike and can't find it check your tire changing stand. DAMHIK.
marchyman is offline   Reply With Quote
Old 06-04-2014, 12:41 PM   #7
seatec OP
Dutch Transplant
seatec's Avatar
Oddometer: 809
That's good stuff. Thank you very much Marchyman.
'14 1200 GSA
Old 06-04-2014, 01:00 PM   #8
Astolfo
Wicked Slow
Astolfo's Avatar
Oddometer: 808
is there a pictorial anywhere?
1995 R1000 GS 1998 R850 GS 1999 R1000Gs 2007 KTM ADV 990 2009 R1200GS
2012 F800GS White & Blue Trophy
2014 GSA
Astolfo is offline   Reply With Quote
Old 06-04-2014, 05:57 PM   #9
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,428
Not that I know of. I took a few pics when changed my tires but it certainly isn't a pictorial or tutorial. The pics will probably will lead to more questions than answers.
http://www.snafu.org/pics/r1200gsw/2014/0322-tires/
Old 06-05-2014, 12:23 AM   #10
n1tr0
Dual Sport rider
n1tr0's Avatar
Oddometer: 126
You're unbolting the calipers before you remove the front wheel ? This is my first bike w/ dual front rotors, but on all my previous bikes I've always just slid the wheel in and out leaving the caliper in place.
n1tr0 is offline   Reply With Quote
Old 06-05-2014, 10:04 AM   #11
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,023
I'll be swapping out a front wheel sometime this season and when I do, I will try to see if it is necessary to remove both calipers. Maybe it can be done with only removing one of them?
Old 06-05-2014, 10:27 AM   #12
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
or somtimes just loosening one or both...
fbj913 is offline   Reply With Quote
Old 06-05-2014, 05:23 PM   #13
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,428
Radial mounted calipers. Loosening does not let the calipers move side to side. They need to be removed to get the wheel off. Both of them. At least that was the case with spoke wheels.
Old 06-05-2014, 07:39 PM   #14
JimVonBaden
"Cool" Aid!
Oddometer: 52,371
Times are GMT -7.   It's 02:48 PM.
