Old 07-13-2013, 07:58 PM   #46
JM
JM's Avatar
Oddometer: 781
Originally Posted by VietHorse View Post
Hi guys,
Someone pls tell me what is the name of the red device on above photo which take the power from the green wire without tearing the wire?? And link to where selling it? Or we can have an alternative stuff to do the same function?
Thanks.
It's called a Posi Tap made by Posi Lock Connectors.
http://www.posi-lock.com/posiplug.html
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Old 07-13-2013, 08:15 PM   #47
VietHorse
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,406
Thank you John,
Start searching in Vietnam market.
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse is offline   Reply With Quote
Old 07-14-2013, 09:00 PM   #48
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 210
Posi-tap
Posi-Tap Connector
Careful about calling parts stores and asking for posi-tap. Most likely, they will think you mean the blade-connector.
Hope this helps!
R4C
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee is offline   Reply With Quote
Old 07-14-2013, 09:21 PM   #49
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,740
I get mine from www.cyclenutz.com
Tony is also an inmate here.
Jim
Old 07-14-2013, 09:54 PM   #50
VietHorse
VietHorse's Avatar
Oddometer: 1,406
Thank you Sirs.
Lucky me, a friend of mine has a spare connector from his PC-5 installation and he will give it to me today. I just need one.
Old 07-20-2013, 01:07 AM   #51
VietHorse
VietHorse's Avatar
Oddometer: 1,406
Thank you Sirs.
Got it in hand:
Old 07-20-2013, 10:06 AM   #52
VietHorse
VietHorse's Avatar
Oddometer: 1,406
Look at this! He's got a bunch of relays...
Original thread: http://advrider.com/forums/showthread.php?t=537579
Old 07-20-2013, 10:44 AM   #53
Thunder Pig
Thunder Pig's Avatar
Oddometer: 251
Just for fun take that bike to a dealer and say your having an intermittent electrical problem and ask if someone could have a look at it. Watching the mechanic look at it and watching his head expand then listening to him mumble under his breath before he says "no, I don't think I can help you" would be great entertainment! Maybe a hidden camera video from several dealers would be even better!
Ted VanR
12 R1200GS Rallye
06 KTM 525EXC
98 KTM 200EXC
99 Speed Triple, etc...
Thunder Pig is offline   Reply With Quote
Old 07-20-2013, 06:32 PM   #54
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,342
A fuzeblock install on a wethead: http://www.snafu.org/pics/r1200gsw/2013/0718-fuzeblock/
Not quite as pretty.
marchyman is offline   Reply With Quote
Old 07-28-2013, 09:42 AM   #55
VietHorse
VietHorse's Avatar
Oddometer: 1,406
A friend gave me his surplus tap connector. It's really great one, compact and really easy to install.
Bought a 30Amps relay, fror approx $1.6.
Get the stuff toghether:
I removed the connector for relay to make more room under seat.
And also installed the combined switches:
Thanks guys for your info and guidance.
Old 08-02-2013, 02:43 PM   #56
V@lentino
Inspektor
V@lentino's Avatar
Oddometer: 817
Wink same-same
I also used that panel and tapped the diagnostic tool, set up has been flawless for over 20k km.
FEAR ===> False Expectation About Reality. GSA08
Work is just the time you have to spend between rides.
The motorcycle chronicles of Jackie & Valentino
The Southern Episode
V@lentino is offline   Reply With Quote
Old 08-02-2013, 05:01 PM   #57
JM
JM's Avatar
Oddometer: 781
This is how I set up my '13GSA
Right now I'm only using one of the two relays at the top of the picture. I will be hooking up the second one next week when I add a Baja Designs 8" OnX light bar to the bike.
John
Old 08-03-2013, 02:54 PM   #58
JimVonBaden
"Cool" Aid!
Oddometer: 51,740
Very clean!
Jim
Old 08-03-2013, 09:24 PM   #59
JM
JM's Avatar
Oddometer: 781
Originally Posted by JimVonBaden View Post
Very clean!
Jim
Thanks, I probably walked away from that wiring job at least a dozen times because I didn't like the way it was coming together. After spending some time away from the bike I'd come back, stare at it for a while and try a different wire routing solution. I worked on that wiring job for about a week and a half. Most of that was waiting for parts but it was nice to have the extra time so I didn't feel rushed to get 'er done.
John
Old 09-21-2013, 02:49 PM   #60
alaninsea
Oddometer: 122
GSW Install
Marchyman,
Looking at installing my Fuzebock on my GSW. What did you tap into for key power?
Thanks/Alan
2014 R1200GSW
alaninsea is offline   Reply With Quote
Times are GMT -7.   It's 01:10 PM.
