Old 09-21-2013, 04:34 PM   #61
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,428
http://www.snafu.org/pics/r1200gsw/2013/0715-wiring/
marchyman is offline   Reply With Quote
Old 09-21-2013, 04:40 PM   #62
beemerphile
beemerphile's Avatar
Oddometer: 1,865
Have a look at the PDM60 by Rowe. Programmable, no fuses (circuit breakers), sealed (potted), very compact.
You can hide it deep because you never have to access it for fuse replacement.
http://www.rowe-electronics.com/modules
ΜOΛΩΝ ΛΑΒΕ - Lee
Unreconstructed Southerner living in Occupied Georgia
beemerphile screwed with this post 09-22-2013 at 05:31 AM
beemerphile is offline   Reply With Quote
Old 09-21-2013, 07:24 PM   #63
genka
SUV hater
genka's Avatar
Oddometer: 1,607
I found an unconventional spot to for the a fuse panel and a relay. After removing the charcoal canister and associated plumbing, I had a considerable space under the fuel tank and put it ot a good use. The picture id from install in progress, at the end it looked somewhat cleaner. Although Touratech panel wasn't the best choice.
I have a lot of bike powered electrics: Dimmable pair of Aux LEDs with their own on/off and dimmer switches, another 5 LEDs coming up with the high beam, LED side markers/ turn signal repeaters in the handlebars, camera, 2 USB chargers, GPS, voltmeter, garage door opener, top case brake light and heated gear outlet.
Despite so much crap on the bike, this is how my underseat space looks like:
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is online now   Reply With Quote
Old 09-21-2013, 07:53 PM   #64
VietHorse
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,432
Wow, that's really a good found.
However, it would be not really convenience for replace the burn fuses on the road side. If putting under the seat, just need the key to remove the seat.
My 2 cent.
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse is offline   Reply With Quote
Old 09-22-2013, 07:09 PM   #65
genka
SUV hater
genka's Avatar
Oddometer: 1,607
My 2 cent.
The panel is easily accessible without removal of the gas tank. Just need to take the left lateral panel off, which is easy. Anyway, the panel has only a single ingress fuse, all outputs are protected electronically and should reset automatically after a short. I hope to never test this :)
Old 09-22-2013, 09:09 PM   #66
VietHorse
VietHorse's Avatar
Oddometer: 1,432
Great, you seemed cover them all.
Old 06-04-2014, 01:35 PM   #67
tarheel rider
Tight Lines
tarheel rider's Avatar
Oddometer: 151
Fuzeblock install
This has given me a wealth of information on installing a fuze block on my 2011 BMW GSA, my challenge is my G650GS and where to put the block and what wire is the trigger. I kind of feel that a fuze block is overkill since the bike is light on excess power and I only want to add a GPS, a phone usb port, and auxiliary lights. Then the question comes up is there enough power generated while riding to run all this stuff?
The whole object of travel is not to set foot on foreign land; it is at last to set foot on one's own country as foreign land.-----G.K. Chesterton
tarheel rider is offline   Reply With Quote
Old 06-05-2014, 07:50 AM   #68
dmason
goofball
dmason's Avatar
Oddometer: 272
GPS and USB are minimal draw on any system. If the aux lights are LED they are low draw as well. Should be no problem. I like the Fuzeblock because it will let me easily assign multiple items to switched power. Keeping the battery area clean and well connected is a bonus for me.
1969 Honda CB175 * 1999 Royal Enfield Bullet 500 * 2013 Ninja 300 * 2007 BMW R1200GS * 2003 Honda XR80R * 2005 Honda CRF230F
dmason is offline   Reply With Quote
Old 06-05-2014, 03:06 PM   #69
tarheel rider
Tight Lines
Oddometer: 151
Trigger
Can anyone tell me what wire to use for the trigger wire on a 2009 G650gs? I see in the earlier posts what to use on my 2011 R1200 GSA but don't know is the same color pattern holds on the 650.
Old 06-05-2014, 06:52 PM   #70
dmason
goofball
dmason's Avatar
Oddometer: 272
I just googled "g650gs Fuzeblock" and found 4-5 threads on the subject...
Old 06-05-2014, 07:02 PM   #71
tarheel rider
Tight Lines
Oddometer: 151
Thx!
Times are GMT -7.   It's 10:40 AM.
