Old 07-07-2008, 07:17 PM   #1
Vandergraf OP
Vandergraf's Avatar
Oddometer: 80
1973 Yamaha CT175 Enduro
Just bought a beat up, but rideable Yamaha CT175 which I plan on leaving at the cabin and using to ride easy sandy trails and plonking around the property. I can't find a manual for it and have a couple of concerns.
1. I don't know what kind of oil to put in the gear box. Any ideas?
2. It's got two broken spokes on the rear wheel right next to each other. I'm a 220 lb. old man riding easy sandy trails at slow to medium speeds. No rocks and no jumps will be attempted. Am I relatively safe riding with two broken spokes, at least until I decide to change the rear tire in a season or two?
Any thoughts or advice on this old machine would be appreciated.
Vandergraf screwed with this post 07-07-2008 at 08:00 PM
Vandergraf is offline   Reply With Quote
Old 07-07-2008, 07:34 PM   #2
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
From memory - engine oil. Note that this also lubes the clutch... it would be the same oil as in the newer bikes and the old DT250 AT125 .. 10w40 ....
I'd get some new spokes and nipples .. you don't want to have the rim warp ... easy job, don't be lazy!
Frank Warner is offline   Reply With Quote
Old 07-07-2008, 07:46 PM   #3
adaycj
Oddometer: 457
+2 Fix the spokes. Not that it has anything to do with the manual or recommendations, but I used Mobil1 15w40. Kinda wish I never sold mine.
adaycj is offline   Reply With Quote
Old 07-09-2008, 09:29 PM   #4
ADK
____
Oddometer: 8,237
www.yamahaenduro.com for vintage enduro info
ADK is offline   Reply With Quote
Old 07-10-2008, 01:11 AM   #5
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,569
I had a CT2 175 new in 1972,and also a TY175 which used the same engine this powerplant is still made today in the AG100,one of the longest production runs around.
Yamaha recommend engine oils in their 2 strokes,I'd go for a diesel oil like Delo or others as they have a higher zinc and phosphorus additive package like bike oils.Change it more often than you'd think.They are prone to getting water in the gearbox oil too - my TY175 did when ever it went in water,and every AG100 I saw had water in the gearbox oil too.Keep an eye on the oil pump cable,and if it gives trouble go premix if it doesn't worry you.
motu is online now   Reply With Quote
Old 10-06-2009, 04:45 AM   #6
scotty_rides
scotty_rides's Avatar
Oddometer: 33
Suggestions
I am about to start a CT175 rebuild as well. Some suggestions I have been given:
1. Relace the spokes - the nipples will all be rusted and prone to failure
2. Go to pre-mix instead of oil injection to reduce the risk
3. Chrome parts in poor shape could be painted black as was done on vintage Yamaha competition machines to avoid re-chrome expense
4. Crank seals are probably bad so replace those
5. Fuel tank may have rusted inside and plugged the carb. Clean out carb and tank
6. Get parts here: http://216.168.60.165/speedandsportinc/index.tpl
7. Enjoy
Here is my "before" picture:
http://www.advrider.com/forums/showp...1&postcount=18
Scotty_rides
Let's Ride!
scotty_rides is offline   Reply With Quote
Old 10-06-2009, 07:27 PM   #7
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
10-30 engine oil is what was recommended for the trans. I would NOT go for any synth. or diesel oils, clutch slippage may result. I had a 1973 CT-3 175, and a AT-1 125 and a JT-1 60. Forget the spokes, they'll get worse, eventually. Just look at them once in a while. Sounds like you'll have long periods of non-use, be sure to use Sta-Bil, put the piston up on compression before storing, put steel wool in the end of the exhaust to keep out mice. put screen over the air intake for mice too.
Old 10-07-2009, 05:00 PM   #8
eyedragaknee
McGuyver
eyedragaknee's Avatar
Oddometer: 2,319
CT175 advice
In the middle of one myself
2008 KTM250-XCFW
2013 Beta 300 Trials
1966 Honda 305 Scrambler
eyedragaknee screwed with this post 12-07-2010 at 07:30 PM
eyedragaknee is offline   Reply With Quote
Old 10-07-2009, 05:01 PM   #9
eyedragaknee
McGuyver
Oddometer: 2,319
Another
2008 KTM250-XCFW
Old 10-07-2009, 05:02 PM   #10
eyedragaknee
McGuyver
Oddometer: 2,319
another
I took it down to the crank and rods.
Should be a sweet little scoot
2008 KTM250-XCFW
Old 10-07-2009, 05:09 PM   #11
eyedragaknee
McGuyver
Oddometer: 2,319
spokes
Get a whole new set. Don't screw with them and land on yer a$$.
New crank seals for sure. It will either blow oil or burn a piston, depending on what side leaks. Maybe none will. Your call. They need crankcase pressure to run right.
The oil injection works fine if it is set up right. Premix is OK if you are nervous about it.
Rebuild the carb and clean it thoroughly. Put an inline filter in the hose then for sure or it will plug up from the crap in the gas tank.
I've done pretty much everything on this one so I can tell you some things about them.
Check the tranny too
Mine had some issues
2008 KTM250-XCFW
Old 10-10-2009, 10:34 AM   #12
eyedragaknee
McGuyver
Oddometer: 2,319
Enduro forum
Might be nice IF you could get onto the site and participate. I've been trying for about 6 weeks and no luck or response from anyone on the site.
Maybe you know somebody that can help out?
J
2008 KTM250-XCFW
Old 10-11-2009, 08:23 PM   #13
TwilightZone
Oddometer: 3,121
Had one, loved it... many fond memories and miles.
Best mod I did was lace up a 21" rim on the front. If you're going to re-spoke I'd do that on the front for sure.
TwilightZone is offline   Reply With Quote
Old 10-11-2009, 08:44 PM   #14
welder
welder's Avatar
Oddometer: 1,524
fix the spokes, use the auto lube system if it is still there, they are very reliable,you should use a two stroke transmision oil ine the cases. Its a little spendy but you should not have to change it for a few seasons.
"If you come to a fork in the road, take it." Yogi Berra.
welder is offline   Reply With Quote
Old 10-11-2009, 08:54 PM   #15
ADK
____
Oddometer: 8,237
J
They're doing some upgrades to stop spammers. try again in a week.
Times are GMT -7.   It's 03:03 AM.
