Old 07-08-2008, 06:12 AM   #1
Prothos OP
Oddometer: 29
Tire plugs
Well after only 3k miles on my 08 wee i got a flat on the front tire. I was lucky that it went flat at home. I went to the store and purchased a tire plug kit and mini slime air compressor. I was able to plug the the hole and the tire seems to be holding air. This is the first time i have plugged a bike tire. I ride the bike daily and hit speeds up to 75mph. i'm not able to purchase a tire at this time. What is everyones opions/experence with tire plugs in front tires. I will check the tire daily to insure it has proper air or looks like the plug is coming out.
Prothos is offline   Reply With Quote
Old 07-08-2008, 06:51 AM   #2
VStromTom
Oddometer: 1,579
Ride. If it doesn't leak, ride.
VStromTom is offline   Reply With Quote
Old 07-08-2008, 07:35 AM   #3
gremor
RS'er
gremor's Avatar
Oddometer: 943
If the plug doesn't hold try a patch on the inside if you have tire spoons and all.
I've done this on a newer tire and had it last the life of the tire.
"As a teen I would have fucked a snake if someone would hold it's head, drunk or not.
But I've matured. Now I'd make sure I was drunk before I tried to fuck a snake"..........Bueller
gremor is offline   Reply With Quote
Old 07-08-2008, 08:50 AM   #4
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,025
There have been lots of threads about this on the board, and many people have reported that the string plugs will last the life of the tire. I have read of several failures of the rubber mushroom plugs failing from being cut in half by the tire cords, but I don't recall reading any sticky string failures. This assumes that you are patching a small hole in the tread portion of a tubeless tire.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 07-08-2008, 12:49 PM   #5
Prothos OP
Oddometer: 29
Yep its a small hole in the tread portion and i did use the string type plug. i will buy the tire irons and such and new tire as cash permits. Thanks for the valued replies.
Old 07-08-2008, 02:29 PM   #6
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,821
Ride it till the tire is worn out. If it leaks cram two plugs in the hole. Dont spare the glue. I have been pluggen tires for years and have been amazed at how well they last
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 07-08-2008, 03:50 PM   #7
NoahDL88
Vroom Vroom
NoahDL88's Avatar
Oddometer: 928
Just to remove any ambiguity, only plug the tread portion, not the sidewall, if its close to the sidewall, i wouldn't chance it.
If you decide not to plug it, now is an excellent time to upgrade to Metezler Tourance tires.
Ride more, Type less.
NoahDL88 is offline   Reply With Quote
Old 07-08-2008, 06:32 PM   #8
yosmitetom
Oddometer: 3,354
OMG! The tire will explode when you reach 45 mph.
Actually, plugs work pretty well. I consider plugs a temporary fix. I prefer a patch on the inside for a permanent fix.
yosmitetom is offline   Reply With Quote
Old 07-09-2008, 06:23 AM   #9
Prothos OP
Oddometer: 29
Thanks for the replies. i plugged the tire after a full day it seems to be holding air.
Old 07-09-2008, 06:24 AM   #10
Prothos OP
Oddometer: 29
Thanks for the replies. i plugged the tire after a full day it seems to be holding air. I keep a eye on the plug and air pressure daily for the next week or so then go back to my weekly check.
Times are GMT -7.   It's 07:13 AM.
