Old 07-13-2008, 12:04 AM   #1
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,492
Back Ordered Stator - Advice or Spare?
So my bike quit charging and the shop diagnosed it as a bad stator. The really bad part is that the stator is backordered until the end of August and I've been planning on leaving for a cross country trip with my girl friend in less than two weeks. I've just ordered panniers and new tires and now it all seems up in the air.
Munn is looking for a stator for me but isn't hopeful. If anyone has a spare they can spare or knows of a place that has rewound a 950 stator please share some knowledge.
Many thanks in advance.
Gregor
sakurama is offline   Reply With Quote
Old 07-13-2008, 05:55 AM   #2
thetoecutter
Cutter of Toes
thetoecutter's Avatar
Oddometer: 1,814
Baja Designs or Trail Tech maybe?
* neither of their sites list anything but I'd still give them a call if you haven't.
450 sx street V4.3
05 950
thetoecutter screwed with this post 07-13-2008 at 06:03 AM
thetoecutter is offline   Reply With Quote
Old 07-13-2008, 08:54 AM   #3
woodchuckexc
Oddometer: 801
Check with KTMtwins or their sister shop Scuderia west in S.F. Ca.
They sell more KTM twins than anyone else in the US. Scuderia West's phone # is(415) 621-7223. Good Luck brother!
woodchuckexc is offline   Reply With Quote
Old 07-13-2008, 01:40 PM   #4
lc8john
lc8john's Avatar
Oddometer: 535
If its really urgent, give this guys a call: http://ktm-sommer.de/
Ask them to "ups" it to you, it could be a bit expensive but, as i said if it is urgent....
Husaberg FS 570
lc8john is offline   Reply With Quote
Old 07-13-2008, 01:44 PM   #5
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,492
Thanks, I'll check these options out tomorrow.
Gregor
Old 07-13-2008, 01:52 PM   #6
LKN4DRT
Mended
LKN4DRT's Avatar
Oddometer: 714
Could you pull it out and inspect it? It could just be a broken/shorted wire that's easy to repair?
Nine five O A
Six nine O E
Five three O
Four five O
Five O O
LKN4DRT is offline   Reply With Quote
Old 07-13-2008, 04:55 PM   #7
Monty_Burns
Excellent.
Monty_Burns's Avatar
Oddometer: 1,297
There is nothing magic about the 950's stator. If it is something as simple as a short on one of the phases, a good motor shop should be able to rewind it.
You could even do it yourself if you have some time to learn how and are moderately confident with mechanical stuff. The F650GS forum (not ADVRIDER) has the best write-up I've found on the subject.
If there is physical damage, then you are probably screwed unless you can find a stator somewhere at a KTM dealer.
Monty_Burns is offline   Reply With Quote
Old 07-13-2008, 06:31 PM   #8
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,492
I was sorta thinking that myself but searching the subject here I found that no one has successfully had one rewound. I guess because it's in an oil bath? I don't know why that would make a difference and I'm with you: it should be a simple affair to have it rewound since it's just a matter of the correct wire and the right number of turns. Still I haven't done one yet and don't want to start now so I was hoping that someone knew a person who had done one since that would make it easier.
Tomorrow I'm taking the bike to a track day and I'll just keep it on a charger between sessions but that won't work on the way to Portland.
Old 07-15-2008, 08:33 AM   #9
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,492
No Rewind options
So Baja and Trail Tech can't rewind the stator - they do it on a machine that is specialized to the bikes they build them for. I asked if it could be done by hand and they said no because you couldn't get it tight enough. Hmm. I might look around some more but it seems no one has ever had one rewound so maybe there's a reason. Munn can't find one after looking for two days and I'll try the CA shops once they wake up.
Any other suggestions? I've emailed Sommer but haven't heard from them yet.
Old 07-15-2008, 09:26 AM   #10
thetoecutter
Cutter of Toes
Oddometer: 1,814
Matto Cycles maybe.
450 sx street V4.3
05 950
Old 07-15-2008, 10:06 AM   #11
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,492
Sommer had one - well, they said it was in stock in the EU and they'd have it in two days and could ship to me. Expensive but then it's a matter of having a bike to ride or not. I guess I'll take ride. Now I hope the oil pressure switch is in stock as that seems to be failing...
Gregor
Old 07-15-2008, 10:11 AM   #12
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,413
http://www.rickystator.com/index.html
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 07-15-2008, 10:14 AM   #13
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,413
And Baja Designs...
Please call our tech support department at 760.560.2252 to discuss the rewind specifics/options for your bike before sending in your stator.
~ Ken
Old 07-15-2008, 10:42 AM   #14
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,492
Baja can't and Ricky's asked for a photo of the stator and will get back to me. They might be able to so I might take one for the team and get a rewind to see.
Old 07-15-2008, 04:45 PM   #15
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,602
does it have the white or brown connector? Idea of which phase is damaged (there are three)? Easy to check with a meter, either Digital or Analog. the reason I ask is that it might not need to be rewound, it might be a poor connection/solder joint or a bad wire in the loom coming from the stator itself.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Times are GMT -7.   It's 07:46 PM.
