Old 04-27-2009, 06:25 AM   #2071
bluesman
Oddometer: 3,343
I am just getting old and not really pro but will try my best
What are symptoms? What did you check already (spark, fuel, carbs, pump?)
How does it look, it does not "catch" at all, like no even spark or it just wouldnt start despte spark is there and spark plug is "wet" after few cranck turns, e.g. fuel getting to engine?
bluesman is offline   Reply With Quote
Old 04-27-2009, 06:50 AM   #2072
morse
Oddometer: 237
Anyone seen a Fuel Pump membrane for sale. As I thougth it's hard to find. Suzu dealer in Estonia can't provide me with that. BUT they have a whole pump on the shelf for 90 Euros.
I have a deadline end of june. Because in July I need the whole of my tanks.
Cheaper pumps are easy to find but "A MEMBRANE SHOP's" address would be highly appriciated.
morse is offline   Reply With Quote
Old 04-27-2009, 06:51 AM   #2073
dannydoy 750
Oddometer: 40
got spark and fuel(even tried quickstart)
not even a hint of starting.
maybe valve timing?
dannydoy 750 is offline   Reply With Quote
Old 04-27-2009, 06:52 AM   #2074
dannydoy 750
Oddometer: 40
also the deco swith has been taken off and bypassed(is that even possible)
Old 04-27-2009, 06:59 AM   #2075
DrBigEd
DrBigEd's Avatar
Oddometer: 695
Originally Posted by dannydoy 750
hi there all.i have recently bought my first dr 750 and am having problems getting it to start.i have hooked up with drbiged and we have discusses the problem(thanks ed)was wondering if any of you old pro,s could help me out.any advise would be appreciated.
Hey hey! Good to see you here. Its funny, SA is a multi language country but most people speak Afrikaans or English. When Dannydoy (you have to explain this one) chatted to me on Saturday we started off in English and ended up speaking Afrikaans. I am too much of a ding-dong and suggested he joined up here and speak to you guys with all the knowledge.
PS. Welcome!
"For long you live and high you fly
And smiles you'll give and tears you'll cry
And all you touch and all you see
Is all your life will ever be"
BREATHE
Dark side of the moon
Pink Floyd 1973
DrBigEd is offline   Reply With Quote
Old 04-27-2009, 07:03 AM   #2076
morse
Oddometer: 237
maybe valve timing?
You probably heard that already, but is the battery ok? It won't start if it's a little ok.
And the Idle screw. If you have turned it on too much, then the starter won't be able to turn the engine round. I turn it out so that it doesen't toutch the valve and then turn it in about one round. Point is that it's easier to turn engine round when the throttle valve is closed, but it has to be a little bit opened to start the engine.
As for the battery. I have used a charger that has the start function. Just don't boil your battery. The electrics is so simple that you can't harm it with the start-charger.
Old 04-27-2009, 07:08 AM   #2077
dannydoy 750
Oddometer: 40
yip battery seems fine .i could prob swing the motor for a minute before it starts running down.something tells me it must be something to do with valve timing.also,a friend who has a xr500 said that i must check the key on the magneto.maybe its sheared off and advanced or retarded the spark timing???
Old 04-27-2009, 07:11 AM   #2078
dannydoy 750
Oddometer: 40
Pissed
hey ed.enjoying the public holiday?i got roped into working.would rather be working on the dr .
Old 04-27-2009, 07:12 AM   #2079
ppe172
Oddometer: 169
Try checking your compression, and/or the valve adjustment.
ppe172 is offline   Reply With Quote
Old 04-27-2009, 07:14 AM   #2080
dannydoy 750
Oddometer: 40
ya i dont know bout the doy in dannyboy.must be a type o.HAhaHA.was very eager to sign up.
Old 04-27-2009, 07:16 AM   #2081
dannydoy 750
Oddometer: 40
when i pull in the deco lever there is almost no compression and the motor swings very easily,is this normal?also what exactly does the deco switch do and can i start the bike without it?
Old 04-27-2009, 07:18 AM   #2082
ppe172
Oddometer: 169
I thought you said the decompression had been disabled?
Old 04-27-2009, 07:20 AM   #2083
morse
Oddometer: 237
If all seems ok, but the bike doesn't start, then it could be the timing (or sparkplug wire's alignment incase of more than one cylinder).
But you wouldn't believe how well the rotor is installed on the cranckshaft. I would believe more that someone has installed the camchain wrong and since then the engine hasn't starter... Is it possible? To check it you have to remove the top cover of the engine unfortunately.
Have you tried just changing the sparkplugs, maybe they are really old.
Also!!! We have a tradition, whenever a bike doesen't start we take a fun ride with a car infront and a bike toed in the back. 90 percent of the times the bikes start. 10 percent of the times the bikes fall. Once even a bike with the camchain installed two teeth wrong started behind a car - it didn't run too good though
Old 04-27-2009, 07:20 AM   #2084
dannydoy 750
Oddometer: 40
sorry i meant the switch not the lever
Old 04-27-2009, 07:22 AM   #2085
morse
Oddometer: 237
I think he means the switch of the deco lever has been bypassed not to interfere starting.
Times are GMT -7.   It's 11:25 AM.
