Old 04-27-2009, 08:55 AM   #2101
dannydoy 750
Oddometer: 40
ok,thanks guys.
my plan of action is............
check valve timing
check valve clearance
check deco setting
fix deco lever not popping back.
report back.
how does that sound?
dannydoy 750 is offline   Reply With Quote
Old 04-27-2009, 08:58 AM   #2102
dannydoy 750
Oddometer: 40
yip def getting fuel blues.can i check the timing with a timing light?
Old 04-27-2009, 09:04 AM   #2103
bluesman
Oddometer: 3,326
Well, no point in tryng (CDI - it got electronic ignition advancer controller), and you have no suitable contol opening for that. It's either works or not :)
To check valve timing it is enough to take central bolt-plug from left casing cover and rockers cover (comes out together with rockers BTW) and check marks.
For igintion best is to just follow troubleshooting of all ignition chain as per DR workshop manual. Drop me your email address I'll email it to you. I have sent it to one of DRers in the past and still have it in my mail, so can forward.
bluesman is offline   Reply With Quote
Old 04-27-2009, 09:07 AM   #2104
ppe172
Oddometer: 169
You can't check timing with a timing light. Most bikes have fixed timing, it is not adjustable (at least not in the way a car's timing is adjustable). The only way to adjust the timing on a bike is to change the relationship between the cam and the crank by moving the timing chain on the sprokets. To check the timing you need to remove the cover on the left engine case (round aluminum with slot in it) and put a socket on the nut and turn the motor (counterclockwise I believe) while looking to see the timing marks. You need to see that the piston is at TDC (on the compression stroke) when the TDC marks are aligned in the hole. You also want to have your valve inspection covers off so that you can see that the valves are closed at TDC on the compression stroke and that they open and close correctly. You'll also be able to check the functioning of the decompression mechanism through the exhaust valve inspection cover.
(Edited, I was mixing up my bikes DR has only one hole in side cover)
ppe172 screwed with this post 04-27-2009 at 09:15 AM
ppe172 is offline   Reply With Quote
Old 04-27-2009, 09:10 AM   #2105
dannydoy 750
Oddometer: 40
thanks guys.youve givin me some hope.
blues my mail is
dvermaak@visteon.com
thanks for the info.
greatly appreciated
Old 04-27-2009, 09:16 AM   #2106
dannydoy 750
Oddometer: 40
ok guys gotta go now.switch off machines and then almost home time for me.i really appreciate every one being so helpfull.
i will let you know the outcome as soon as i get time to check everything wich should be by friday or saturday(been real busy at work)luckily its all automated ,i just need to be here in case something goes wrong.
Old 04-27-2009, 09:20 AM   #2107
bluesman
Oddometer: 3,326
Email sent.
I agree with what ppe172 mentioned, but just to add - if you take off head cover you can see marks on camshaft "flange". Those supposed to line up with surface of the head when you align marks you see through that bolt/plug thingy on left case cover. So, if you want to check that your timing is PERFECT you can do it this way, if you want to be sure you just OK you can check through inspection/valve clearance adjustment opnings in head cover. If you will take head cover off you will have to use sealant to put it back (standard way for DR) and re-adjust valve clearances.
Still, I'd check fuelling and electrics first. It's way too easy even for wohever did it in the past to set valve timing right, but it is way more tricky to ensure they did not mess up electrics or that fuelling is correct.
Old 04-27-2009, 11:04 AM   #2108
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
WOW !!
We seem to have grown to some kind of "critical mass" here.
Our gravitational field has increased to the point that we're attracting orbiting bodies from far afield and at an increasing rate. 800 Rider is going to be a busy guy.
Maybe it should be the International DR Big "Blackhole" Club
Ladder106 is offline   Reply With Quote
Old 04-27-2009, 11:17 AM   #2109
jabroka
jabroka's Avatar
Oddometer: 338
Originally Posted by Ladder106
Yes, please.
Robmoto....we'll 'splane later.
here it is.. hope its helpful
http://rapidshare.com/files/22640943...Dr800.zip.html
jabroka is offline   Reply With Quote
Old 04-27-2009, 11:36 AM   #2110
MCmad OP
Oddometer: 7,842
Originally Posted by dannydoy 750
hi there all.i have recently bought my first dr 750 and am having problems getting it to start.i have hooked up with drbiged and we have discusses the problem(thanks ed)was wondering if any of you old pro,s could help me out.any advise would be appreciated.
Welcome Dannydoy, just for our files are you Irish or South African
PS, be careful about talking to Ed hes DR crazy and I bet you, he speaks with a funny accent to
Ladder, how about "Gobal World Domination DR Big International"
More pictures please, we wouldnt want people to think where boring ( nave where are you)
MCmad screwed with this post 04-27-2009 at 11:44 AM
MCmad is offline   Reply With Quote
Old 04-27-2009, 12:03 PM   #2111
nave
Nave
nave's Avatar
Oddometer: 353
I'm here, trying to make some coffee...
nave is offline   Reply With Quote
Old 04-27-2009, 12:16 PM   #2112
nave
Nave
nave's Avatar
Oddometer: 353
some view...
Same place different time
Old 04-27-2009, 12:28 PM   #2113
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,265
More pics?
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 04-27-2009, 12:28 PM   #2114
mousitsas
mousitsas's Avatar
Oddometer: 2,749
one question on the naughty side of law
I have the possibility to purchase a rolling chassis of a KTM lc4.
I also have a dr750 in pieces.
The KTM cannot be used as it has been written off.
I have also been insipred by Lukas project, in fitting an other engine to the LC4 rolling chassis.
Here comes the dodgy question
is it possible to rivet the suzuki frame vin to the KTM frame without it being too obvious?
mousitsas screwed with this post 04-27-2009 at 12:45 PM
Old 04-27-2009, 12:39 PM   #2115
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,265
Originally Posted by bigS
Hello to you all, just sold my f650 funduro to a friend and bought this one. Very nice bike, but it's taller than my old BMW. I need to lower it a little, so any suggestion would be appreciate.
thank you,
Very nice
IBA #40578
Times are GMT -7.   It's 08:21 AM.
