Old 04-28-2009, 03:59 AM   #2146
shannonr73
DR BIG Rider 73
Oddometer: 288
/Users/shannonrose/Desktop/kaanaa_b.jpg
Has anyone seen a head light like this?? Found it on the net.. Hope the pic works..
shannonr73 is offline   Reply With Quote
Old 04-28-2009, 04:04 AM   #2147
shannonr73
DR BIG Rider 73
Oddometer: 288
OOps.. I'll add it through photobucket.. Sorry
Old 04-28-2009, 04:33 AM   #2148
snocross
carbikesledboatrockaholic
snocross's Avatar
Oddometer: 69
Could someone answer fast? Is there bearing at the upper mounting of the rear shock. Stupid question because mine is totally jammed and cant get it opened with my tools. My guess is that there is, but it is just so jammed. Want to be sure because im going right now to by all bearings to the rear part of the bike. Almost all bearings were dry, rusty and jammed. This is why i usually go bike through after i buy it....
*Always on the run*
snocross is offline   Reply With Quote
Old 04-28-2009, 04:40 AM   #2149
RaY YreKa
I Am the Mayor
RaY YreKa's Avatar
Oddometer: 16,288
Originally Posted by ztaj
OI, can you guys stop posting please
Been offline since the 4th and it's taking me a while to catch up....
We've got a high post-to-view ratio; that's committed owners for you
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 04-28-2009, 04:40 AM   #2150
bluesman
Oddometer: 3,355
it is not a roll, needle or ball bearing. It is simple bushing bearing with rubber damping that usually slides out with push of finger. At least on my DR.
bluesman is offline   Reply With Quote
Old 04-28-2009, 04:43 AM   #2151
snocross
snocross's Avatar
Oddometer: 69
Thats interesting
*Always on the run*
Old 04-28-2009, 05:04 AM   #2152
robmoto
robmoto's Avatar
Oddometer: 3,870
snocross, mine is a permanent fixture sleave held in place by rubber from memory the bottom one is a straight sleave but the top one is a swivell ball type as far as I know not replaceable
robmoto is offline   Reply With Quote
Old 04-28-2009, 05:09 AM   #2153
bluesman
Oddometer: 3,355
Just a sec, perhaps we are talking of different parts? Are you talking about bearing in lower "eye" of shock absorber itself or bushing that go inside that bearing? It is bearing, but it fixed in the shock absorber "eye" by spring ring. Upper comes with shock, fixed there by rubber spacer
Old 04-28-2009, 05:16 AM   #2154
robmoto
robmoto's Avatar
Oddometer: 3,870
Snocross, the bolt must be rusted to shock bush, the bush will be a tight fit between the frame as it is not ment to turn with shock but pivot using the flex of the rubber just looked at mine and thats the theory.
Old 04-28-2009, 05:24 AM   #2155
Chanterman
Oddometer: 299
Snocross
Go to page 1 and get the parts site and find what is in there (pics/drawings
Chanterman is offline   Reply With Quote
Old 04-28-2009, 05:58 AM   #2156
ppe172
Oddometer: 169
Parts diagram shows no bearing or bushing. Just a bolt that goes through the shock eye.
http://www.cmsnl.com/suzuki-dr750-19...st/FIG-47.html
ppe172 is offline   Reply With Quote
Old 04-28-2009, 06:00 AM   #2157
snocross
snocross's Avatar
Oddometer: 69
I mean this. Bush is totally jammed there. Actually when i had everything else ripped off but this upper mounting, shock did not move at all by hands.
*Always on the run*
Old 04-28-2009, 06:03 AM   #2158
snocross
snocross's Avatar
Oddometer: 69
By the way. Why does computers always let you down when youre in a hurry. I can tell you it is sooooo close that this F#&#ng laptop is smashed to the street thrown from third floor..
So no hurry anymore i go to bearing shop just tomorrow.
*Always on the run*
Old 04-28-2009, 06:55 AM   #2159
bluesman
Oddometer: 3,355
Can't recall for sure but I think inner bushing rotates, but it is as I said - no bearing, just bushing. And it rotates but as far as I remember not easy at all.
All thing is indeed jammed into shock eye and sitting solid in there - this is how it must be actually, but of course shock should move. Even if you disasemble it you will have to break it to get it apart. And there is no replacement part available.
Old 04-28-2009, 06:58 AM   #2160
Chanterman
Oddometer: 299
Snocross I have same problem ..... impatience. This can and will make things MORE expensive . The one pictured does not move/turn as this is a captive anchor for the shock (top), grease and bolt on .The give is in the rubber mount.
The bottom is bolted to the mmmm, looks to be a little boat. All this is movable and has needle bearings. SO the bottom part of shock has a small ball like sleeve ( can move around like a binicle (SHIPS COMPASS) ) also rubber mounted with a small spacer either side. Grease all this and bolt up. The bearings are in the wish bone and bottom frame mount. The shock doesn`t move really or so little movement it will not be noticable.
Times are GMT -7.   It's 01:37 PM.
