Old 03-09-2011, 11:20 PM   #9601
VEEEE
Oddometer: 22
Need a wiring diagram for dr 750 '88 please!!
Stripped and painted bike and now everything dead.
Also going alu dash way with trailtec digital clock. Think im gona use screen for support.
VEEEE is offline   Reply With Quote
Old 03-10-2011, 07:34 AM   #9602
spen
on my arse
spen's Avatar
Oddometer: 344
heers a few from my early 800 hopefully will get you started . Have you no power at all ? Is the battery flat ? fuse blowen? ignition switch broken ? tell us more !
spen is offline   Reply With Quote
Old 03-10-2011, 07:52 AM   #9603
bluesman
Oddometer: 3,303
Get the manual :) all is there, all years and models
http://www.timguy.net/sites/drbiginfo/DrBIGmanuals/
bluesman is offline   Reply With Quote
Old 03-10-2011, 04:29 PM   #9604
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,959
Received my eBay parts from Germany.
Got a set of SR42 carbs. They have removable pilot jets....YAY !!
Took them all apart and there is very little wear in the needles and needle jets. They are also pretty clean.
Here's the question.
Will the SR42 carbs run on an SR41. I wouldn't think that there would be too much difference in fueling between the 750 and the 800
Your opinions are welcome.
Ladder106 is offline   Reply With Quote
Old 03-11-2011, 01:11 AM   #9605
bluesman
Oddometer: 3,303
They will run. SR43 on SR41 will be too much. SR42 on SR41 will run.
Worst case scenario - slightly lean, very little.
SR42 standard main is 117.5 (thou total majority I seen had 120), main air 0.6, needle jet o-5, pilot #40, pilot air 1.1, throttle valve #100
SR41 standard main 120, main air 0.6, needle jet o-4, pilot 17.5, pilot air 1.3, throttle valve #115
Needles are same, bypasses same etc. etc.
As you can see there is just not enough difference to cause it not to run. Worst case - you will have to take mains from your carbs and put them into new. But in case you will be doing filter-exhaust update you will have to change mains anyway.
You can also see why I do not like SR42 - it's really "restricted" comparing to SR43 because of less airbox volume and filter surface.
SR43 runs stock 130 mains, #45 pilots, 1.35 pilot air and o-3 needle jet
Old 03-11-2011, 04:29 PM   #9606
Simon M
Simon M's Avatar
Oddometer: 87
Starter solenoid relay
Hi Guys,
I've just found some cheap starter solenoids on ebay (item number 390288430709) located in the US. It's not listed as being for a DR750, but I took my Katana relay and fitted it to my Big when my Big relay failed and it looks exactly the same part to me. Works like a treat. I've ordered a couple and will post a review when they arrive.
Cheers,
Simon.
Simon M
82 Husky AE420 85 Suzuki Katana 1100 88 Suzuki DR750
07 Triumph Speed Triple 08 Yamaha WR250F
12 Moto Guzzi Stelvio NTX
Simon M is offline   Reply With Quote
Old 03-13-2011, 03:58 AM   #9607
ausibatla
ausibatla's Avatar
Oddometer: 445
Muffler
Can anybody tell me if a 2008 - 2009 Suzuki GSXR 750 muffler will be ok on my 750 or 800.
Cheers.
Youth's a mask but it don't last
Live it long and live it fast
'88 Harley Davidson Springer '91 DR 800 '95 Yamaha XV1100
ausibatla is offline   Reply With Quote
Old 03-13-2011, 06:31 AM   #9608
robmoto
robmoto's Avatar
Oddometer: 3,835
High everyone, I went to our high country again to the Cold Flame Rally, I left a bit late last Friday because of that wet stuff that falls out of the sky.
I ended up in Tumit and decided a cabin for the night would be good its a beautifull caravan park and the ride the next day should only take 4 hours or so with stops.
robmoto is offline   Reply With Quote
Old 03-13-2011, 06:34 AM   #9609
robmoto
robmoto's Avatar
Oddometer: 3,835
About 40mts from the cabin.
Old 03-13-2011, 06:38 AM   #9610
robmoto
robmoto's Avatar
Oddometer: 3,835
And looking towards the cabin.
Old 03-13-2011, 06:41 AM   #9611
robmoto
robmoto's Avatar
Oddometer: 3,835
A snow plain on the way at Kiandra.
Old 03-13-2011, 06:43 AM   #9612
robmoto
robmoto's Avatar
Oddometer: 3,835
A few pic,s of the rally.
Old 03-13-2011, 06:45 AM   #9613
robmoto
robmoto's Avatar
Oddometer: 3,835
and more,
Old 03-13-2011, 06:46 AM   #9614
robmoto
robmoto's Avatar
Oddometer: 3,835
and a bit to the right,
Old 03-13-2011, 07:08 AM   #9615
robmoto
robmoto's Avatar
Oddometer: 3,835
Well this morning, hung over and all I had to pack up and be on the dirt, the first bit was for 35klm,s and all hair pin corners with rain starting to fall it was good fun anyway, and then 605 klm,s black top to home.
Roughly after 250klm there was a accident and the road was blocked, a chopper had flown in to take a motor cyclist that was coming the other way and looks like slid into the armco railing.
Hope he is OK .
Fuel the 95 or 98 ron over here at one garage was 1.59.9 a litre, I road most of the time at 4800rpm and at my last fill up it worked out at 17.18kpl which is not to bad being loaded up.
Times are GMT -7.   It's 05:59 PM.
