Old 06-25-2013, 07:09 AM   #14716
p3dro
Oddometer: 30
Originally Posted by ausibatla View Post
p3dro, did you get your bike out of that place and get your electrics sorted?
Cheers.
No such luck!
I'm ready to throw the towel in, the garage have had it for 2 months now and they are out of ideas. I went to see them yesterday and they said they were going to give the 'readings' from the multimeter to the company that re-wound the generator to see if they have any idea, but they can't work out why it won't start...
Anyone in/around London looking for a project bike?
p3dro is offline   Reply With Quote
Old 06-26-2013, 06:35 PM   #14717
guzzirelic
guzzirelic's Avatar
Oddometer: 200
Hi to all.
Some may recall that I popped in on your thread a few months back to post a couple of photos of Canadian DR Bigs, (post number 14304)
Well I'm back now with photos of my very own recently acquired 1989 DR750. I didn't think I would ever find one close enough to home and at a price I could afford but this bike showed up a few weeks ago on a Canadian classified website. The seller was located about 550 kilometers from me and what sealed the deal was the fact he was looking for some wood working equipment. I had several pieces of equipment that I haven't used in five years and was anxious to see them go to a good home. We worked out the details and on Monday I made the trip.
As you can see, she is pretty rough. But runs ok. I'm making a list and starting to order some of the most needed items. My plan is to get the bike into good mechanical condition including ready for our required safety inspection. The cosmetics will have to wait for now.
Today I ordered a new Avon Gripster rear tire, (to match the front) as well as the stock throttle assembly and some rear brake pads. The seller provided new front pads. I need to remove, clean and paint the exhaust system as well as make up something to replace the missing heat shield. I have the missing side cover to install once the heat shield is on.
The seller only had the bike a short time and never rode it. He has little knowledge of the history. The odometer shows 47000 kilometers so I'll go through everything before riding too far.
The good news is with the seat rubber dampers removed I can touch the ground, (barely) so I've managed a little ride around my back yard but no further yet.
First question I have --- should I be checking the balancer chain adjustment at this age?
I'll have many more questions for you I'm sure and will keep you updated with any progress or problems.
thanks for an excellent thread and I look forward to learning more about my new bike.
Relic
I wonder where this goes...
1989 DR750 Doctor BIG
1974 MotoGuzzi Eldorado/sidecar outfit
1976 Yamaha DT400C;1960 Panther M120
1970 Yamaha 100 L5TA Trailmaster; 1983 Italjet 250T
guzzirelic is offline   Reply With Quote
Old 06-26-2013, 06:56 PM   #14718
Old Fart At Play
Mad about thumpers
Oddometer: 168
Relic's new bike
Congratulations Relic on the new-to-you DR BIG. Between you, North Rider and Finndian there is now a complete set of Canadian-spec BIGs in Northern Ontario. Maybe all 3 will make it to next year's NOFAR rally! If I hadn't sold my 800 we would have 13% of all the BIGs ever sold in Canada in our little group.
Steve
Old Fart At Play is offline   Reply With Quote
Old 06-26-2013, 07:30 PM   #14719
guzzirelic
guzzirelic's Avatar
Oddometer: 200
Thanks Steve. I wasn't sure if you had sold yours or not.
So 13 % eh? My math is not that good...you know how many Bigs were sold in Canada? 54? Is that all?
Nearly as rare as my Panther!
Old 06-27-2013, 09:37 AM   #14720
Old Fart At Play
Mad about thumpers
Oddometer: 168
I've read 30 to 32 in total over the 3 years.
Old 06-29-2013, 11:19 AM   #14721
Geo-Nemesis
Oddometer: 37
Hi mates, I have recently bought on ebay a full set of Givi side panniers with frames without mounting hardware.
I can't figure out how to mount the frames, can someone with those show me a picture? I suspect they are slightly bent
thanks!
Geo-Nemesis is offline   Reply With Quote
Old 06-29-2013, 01:12 PM   #14722
Megamoto
Yes, I do look like this.
Megamoto's Avatar
Oddometer: 3,000
thanks!
I've got a set on Daisy, I'll post some pictures, won't be till Monday, have to work tomorrow.
Guerrilla Moto diplomacy.
Higher level simians as ambassadors of vroom to skewer ignorance and amalgamate ideas globally.
I'm so happy I could whistle through my willie. (Dan Walsh)
Unum bonum Centurio
Megamoto is offline   Reply With Quote
Old 06-29-2013, 04:13 PM   #14723
Geo-Nemesis
Oddometer: 37
Thanj you, I'll wait!!
Old 06-30-2013, 08:55 AM   #14724
spen
on my arse
spen's Avatar
Oddometer: 346
Don"t over tighten the balancer chain or you will f..k it up ,there are two different methods for adjusting it ,do a bit of reading before adjusting it ,you may want to check out another DR site we use http://www.drbig.info/forum/
spen is offline   Reply With Quote
Old 07-01-2013, 04:16 AM   #14725
stefan rb
stefan rb's Avatar
Oddometer: 133
Originally Posted by robmoto View Post
The DR750/800 front sprocket is the same as a early 90,s 650 sprocket, 520 chain size.
A DR 650 late model runs a 525 chain and the sprocket base where it fits on to the counter shaft is about 2mm wider and where the chain runs also, so you could get the outer part machined down to suit a 520 if neaded.
sorry the battery in my callipers is flat, just found this site with measurements,
http://stores.ebay.com/Motorcycle-Pa...sid=1067012968
try Metalgear Queensland.
the sprocket is in wrong position - the flat side must be in front!!!
www.hessler-motorsport.de
and the home of DR BIG:
www.dr-big-shop.de
stefan rb is offline   Reply With Quote
Old 07-01-2013, 04:19 AM   #14726
stefan rb
stefan rb's Avatar
Oddometer: 133
[QUOTE=mait;21705830]Have you tried asking GPR?
Originally Posted by Silent Hunter View Post
Hi people,
I am looking for a table like this, with the DR800 loudness in it after fitting in a GPR pipe.
Does anyone know where to get one?
we sell the GPR for the DR BIG
but not all versions (GPR offer a lot of shit)
we developed the GPR exhaust for the dr big
but in last time dealer and gpr itself combiened our tube with a lot of bad damoers
so you loose power or the exhaust will burn after a full throttle tour....
www.dr-big-shop.de
Old 07-01-2013, 04:22 AM   #14727
stefan rb
stefan rb's Avatar
Oddometer: 133
only a picture ... :-)
second overall on the rally croatia
dr big for ever
www.dr-big-shop.de
Old 07-01-2013, 04:40 AM   #14728
robmoto
robmoto's Avatar
Oddometer: 3,861
Stefen yes I know you like it the other way remember we talked about it before .
Congradulations with the 2nd place win . .
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 07-01-2013, 04:44 AM   #14729
BRUNO BOTELHO
BRUNO BOTELHO's Avatar
Oddometer: 447
Congradulations for your 2nd place
Ride Safe
Bruno Botelho
KTM LC8 950 ADVENTURE & KTM EXC 400 - "Ready to Race"
www.motoazores.com
BRUNO BOTELHO is offline   Reply With Quote
Old 07-03-2013, 01:53 PM   #14730
aapo
aapo
aapo's Avatar
Oddometer: 161
There is only one problem with this piston, it's too pretty.
Sorry, wife took DSLR so only this nokia e5 photo available for now...
107mm from Hessler, nice.
-aapo
-aapo
DR 750S 1989
http://picasaweb.google.com/aapo.saari
aapo is offline   Reply With Quote
Times are GMT -7.   It's 08:51 PM.
