Old 07-15-2008, 09:47 PM   #1
Maddy OP
Maddy's Avatar
Oddometer: 29
What is the loudest motorcycle horn I can get?
I want to install a loud horn on my bike. Something that can wake up the dead 5 miles away.
Thank you for your input
Maddy
Currently bikeless and bored
'08 BMW R1200GS Adventure 'Madalena' (sold)
'08 BMW K1200S 'Meggy' (sold)
'07 Triumph Tiger 1050 'Soffia' - sold
Maddy is offline   Reply With Quote
Old 07-15-2008, 10:06 PM   #2
lymanwhite
Monkee Bidness
Oddometer: 307
A good set of open pipes! Saves your horn finger too.
lymanwhite is offline   Reply With Quote
Old 07-15-2008, 10:23 PM   #3
Slayer
Vier Japanische Kolben
Slayer's Avatar
Oddometer: 203
I went camping for the first time (on a bike) last weekend. Here's a pic of my Nighthawk loaded. I purchased the tent at a local store for like $29. It's supposed to sleep 3 but probably 2 normal size humans would be better. It's only about 2 feet long and fit quite nicely. I took way too much crap for a 1 nighter but had everything I needed. The tent actually ended up packing back up a little smaller going home than it did going because everything was in a box originally and that got burned since I no longer needed it. I did wish for some sort of a pad though.
"Don't come here and grumble about goin' too fast... tie a kerosene rag around your ankles so the ants won't climb up there and eat that candy ass!" Dale Earnhardt
'03 Honda Nighthawk 750
'05 Honda Goldwing GL1800
Slayer is offline   Reply With Quote
Old 07-15-2008, 10:26 PM   #4
decodent
CyberGypsy
decodent's Avatar
Oddometer: 1,420
This ought to do 'er ...
Linky:
http://www.aerostich.com/catalog/US/...n-p-19550.html
Ear Cannon Air Horn #3837
Detailed Images
This is a full-power railroad locomotive/ocean liner type compressed air horn squeezed into a bike-mountable package. Totally overkill, until you need to wake up some lethal driver.
It’s got both the high and low ear-splitting tones of the individually sold Fiamm Freeway Blaster Horns, plus a little more oomph. The 139dB high and low tone blasters combine via air induction to cut through the din and make the most distracted of drivers drop their cell phones and pay attention.
Installs easily on all bikes with a 4.5"×3"×4.5" space for mounting.
The loudest motorcycle horn available. If Ethel Merman, Sam Kinison and John Philip Sousa ever had a band, and played through a wall-of-sound amp rack, it would sound like this. 12V. 1 lb 4 oz.
Currently no bikes. ;-(
decodent is offline   Reply With Quote
Old 07-15-2008, 10:43 PM   #5
AKStrom
Just call me 'Magellan'
AKStrom's Avatar
Oddometer: 1,234
Sheesh, more of that obnoxious Goldfine habit of anonymizing the brand and products names of the stuff he peddles.
That horn below is a Stebel Nautilus. You'll need a relay for that bad boy cuz it peaks around 18 Amps.
http://www.twistedthrottle.com/trade/productview/2137/
Go ahead and buy the Stebel. It's as loud as you should reasonably use on the road and it's more portable and responsive than a remote reservoir horn.
Originally Posted by decodent
Motorcycle Roads Northwest: http://www.roadsnw.com
AKStrom is offline   Reply With Quote
Old 07-16-2008, 04:47 AM   #6
NoDirt4Me
NoDirt4Me's Avatar
Oddometer: 278
A Stebel by another name would be the Wolo Bad Boy from Harbor Freight
NoDirt4Me is offline   Reply With Quote
Old 07-16-2008, 04:54 AM   #7
CycoMike
Ride on!
CycoMike's Avatar
Oddometer: 23
Stebel
Save yourself the install hassle and get the horn + mounting kit from Excel Cycle Werkes.
http://www.excelcyclewerkes.com/index_files/Page318.htm
Just bought one; install was <2 hours and had everything I needed (mount, relay, wiring) except some wire to connect the relay + fuse to the battery.
Well worth the $30 for the mount kit.
Ride on!
Mike
CycoMike is offline   Reply With Quote
Old 07-16-2008, 05:33 AM   #8
VStromTom
Oddometer: 1,579
Great - open pipes, just what makes everyone welcome us to their neighborhood. Stick with the air horn.
VStromTom is offline   Reply With Quote
Old 07-16-2008, 07:00 AM   #9
AKStrom
AKStrom's Avatar
Oddometer: 1,234
Decently priced too. I've seen some kits that cost 2x what the horn does.
Old 07-16-2008, 07:32 AM   #10
mditt8671
Oddometer: 127
Slayer,
How loud IS that tent, exactly?
mditt8671 is offline   Reply With Quote
Old 07-16-2008, 07:44 AM   #11
monkeyfez
Enabler....
monkeyfez's Avatar
Oddometer: 5,000
I have the stebel too. I also bought a mike walsh mount and an eastern Beaver wiring harness. The whole install took less than an hour. It is very loud.
some of the best $$ I've ever spent on my bike.
"When the monkey tells you to give it up, give it up." ~ Bubba Satori
monkeyfez is offline   Reply With Quote
Old 07-16-2008, 07:52 AM   #12
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,906
Stebel on my 1050 Tiger. Its loud!!!!!!
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 07-16-2008, 08:52 AM   #13
Lujo
Oddometer: 1,000
I'm not sure if loudest is best.
I used to have a Wolo Airsplitter (similar to this one) on my Kawi Vulcan. It was beautifully loud, which frequently had some unexpected side effects. For example,
  • a friend almost dropped my bike in surprise when he tried honking at someone;
  • instead of moving out of the way, old ladies clutch their chests and start swaying;
  • cage drivers sometimes freeze and start looking for the truck.
'05 R12ST, '08 F800ST [ex: '04 GS Adv, '99 KLR 650, '88 Vulcan 750]
Lujo is offline   Reply With Quote
Old 07-16-2008, 11:55 AM   #14
TheDuke
Oddometer: 216
Switch
I know we can use the horn button on the bike but I would like to install a separate button. Does anyone know who sells a waterproof momentary button that can be mounted on the handlebar or something with double sided tape so it can stick to the handguards.
Bob
TheDuke is offline   Reply With Quote
Old 07-16-2008, 12:04 PM   #15
AKStrom
AKStrom's Avatar
Oddometer: 1,234
I'd love to see photos that setup. Might even be worth wiring that in place of the 'flash to pass' that is so ineffective in Seattle traffic.
Times are GMT -7.   It's 03:51 AM.
