Old 07-20-2008, 06:22 PM   #16
Justinmarque
Thumper>Airhead
Justinmarque's Avatar
Oddometer: 105
Could be worse right? Looks like it's coming along...
'75 BMW 75/6
'04 Honda XR650L - Stolen!!!
http://justinmarque.blogspot.com/
Justinmarque is offline   Reply With Quote
Old 07-20-2008, 06:27 PM   #17
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Surprises are, well, surprises! As we stripped down, I pulled the rear wheel and found absolutely no lube. Nada. Dry as a bone, rusty even. So... given that the rear wheel splines are the easy ones.... I best get into them all. And who knows what the bearing inspections will bring.
Splines showing some wear, but certainly useable with lots of life. I WILL grease these puppies when they go back!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 07-20-2008, 06:33 PM   #18
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Pulling it all apart, now....
Headstock came apart hard. I think that the upper bearing must be an interference fit, cuz every time I would re-set it I would have to "press" it back out (bigger hammer + 2x4). Anyway, bearings were dried grease and dirt, but upon cleaning up (lotso solvent, grease, etc) they're in decent shape. No notchiness, smooth as can be.
Photo is of the lower bearing "as found" and the upper bearing after solvent wash and before grease.
PS Cleaning is good for the soul. Something about putting it back together nice and clean with gobs of fresh grease.... oohh la la!
Loving the 80ST
Old 07-20-2008, 06:36 PM   #19
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Re: cleaning.......
For example, the bar mounts, before and after a little time on the wire wheel. Gotta love that wire wheel with these old bikes.
Loving the 80ST
Old 07-20-2008, 07:42 PM   #20
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Well lubed tranny splines
The dreaded "oil on the shelf" makes itself known.....
Yes, there was oil on the shelf. Matter of fact, there was oil on the shelf, oil around the pan, oil around the shifter, oil around engine, the back of the tranny and the shiftrod actuator were covered in oil..............
So, we decided to pull the tranny. No problem with lack of lube here, no sireee...........! Lotsa lube, lotsa lube everywhere.....
Another photo of "what you best hope not to find"......the tranny face:
PS So the question was: is this from the tranny input seal, or from the rear main seal, or???
Loving the 80ST
Old 07-20-2008, 07:45 PM   #21
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
This is the engine side of the deal:
.... black fingernails that week......
Loving the 80ST
Old 07-20-2008, 07:47 PM   #22
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
The shelf, in all its lubed-up glory....
Loving the 80ST
Old 07-21-2008, 09:35 AM   #23
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Just another "hope you don't find this"..............
Pic of a new throwout bearing, and of a nfg bearing. By the way, this needle bearing was supposed to be an improvement over the ballbearing used in the /6, but word has it that they needles don't last long either: think about the difference in radius of a radially-placed needle: the outside wants to go faster than the inside, so there is constant scrubbing going on, somewhere.... not a great solution
Loving the 80ST
Old 07-21-2008, 09:49 AM   #24
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,895
great work so far.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 07-21-2008, 09:56 AM   #25
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Wire wheel
Someone asked a question about the wire wheel... don't have a picture of mine, but it looks pretty much like this. I bought a cheapo Delta at Lowe's for maybe $50, took off the grinding wheels and the safety shit, and put on a brass-coated wire wheel on one side, and a buffing wheel on the other.
By the way, bufffing and polishing supplies can be found at jeweler supply houses. Lowe's and HD have the very basic stuff only.
PS ALWAYS wear safety glasses when working with wire wheels, ALWAYS. I had a wire come off when I was getting pretty aggressive, and it stuck in my cheek... hate to think of what it would do to the eyes.........
Loving the 80ST
bpeckm screwed with this post 07-21-2008 at 10:28 AM
Old 07-21-2008, 10:09 AM   #26
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,895
What was your question?
Old 07-21-2008, 10:28 AM   #27
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
Well, at least I know someone reads that stuff........
I guess I shoulda been "more clearer". Someone asked ME a question with a PM, I told him I would post a pitcher...will edit, to make it better!
Loving the 80ST
Old 07-21-2008, 10:33 AM   #28
dragoon
I'm the REAL Dingo Joe
dragoon's Avatar
Oddometer: 23,182
Slow down, you're making us look bad!
Lookin' good!
Everyone should be so lucky as to be able to ride a motorbike through the Himalayas.
- Misery Goat
daveology rule #143 - never ever pass up a chance to hear a band that has a stand up bass -Mutineer
dragoon is offline   Reply With Quote
Old 07-21-2008, 10:39 AM   #29
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,852
The project has been slow, the posting has been fast.... I actually started the project back in May. I worked on getting the seat pan away from the seat this weekend......aarrghgh.
Wait til I have to post "real time"......
Loving the 80ST
Old 07-21-2008, 05:02 PM   #30
Putts
Gettin' there.
Putts's Avatar
Oddometer: 11,390
Originally Posted by dragoon
Slow down, you're making me look bad!
ficst
That's okay, wire brushing bits is cake, sooner or later he'll find he's polishing turds that have to be replaced. Then the cursing and tool flinging will begin.
He had a fire though, that's a good start.
Fugit ... I'm in.
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is offline   Reply With Quote
Times are GMT -7.   It's 03:48 PM.
