Old 07-17-2008, 03:53 PM   #1
firebladejr OP
Oddometer: 14
KTM LC4 640 - window on engine case is leaking..
Hi,
After some longer rides on the bike I've noticed some oil sweating out of the inspection glass on the engine case. Also, the sump plug has tiny bit of oil on it after a long ride as well. I was thinking of replacing the glass/O-Ring and the sump plug and washer with the next oil change. Problem is, I can't seem to find the part numbers for the inspection glass or the O-Ring? All I can find is the inspection glass for the clutch cover.
Anyone know the part numbers? Do you think I should replace the glass and O-Ring, or just the O-Ring?
firebladejr is offline   Reply With Quote
Old 07-17-2008, 04:00 PM   #2
crazybrit
crazybrit's Avatar
Oddometer: 8,555
Same question asked last week.
http://www.advrider.com/forums/showthread.php?t=361393
crazybrit is offline   Reply With Quote
Old 07-17-2008, 04:10 PM   #3
firebladejr OP
Oddometer: 14
Originally Posted by crazybrit
excellent, thanks.
Times are GMT -7.   It's 06:39 PM.
