Old 02-23-2011, 02:39 PM   #496
fra88mi
Oddometer: 6
Cool2
Hello guys,
I just got a 690 enduro and I want to change the exhaust system.
I'm looking the new model Leovince.
Costs 280 €, and is also CE approved.
What do you think about it??
I can not find a pic with the exhaust fitted on a 690 enduro.
I find the old model a bit 'out of proportion ...
I'll have to remap the ECU?
thanks for the tips
fra88mi is offline   Reply With Quote
Old 02-24-2011, 01:19 AM   #497
bob66
bob66's Avatar
Oddometer: 134
Originally Posted by fra88mi View Post
Hello guys,
Costs 280 , and is also CE approved.
thanks for the tips
Hi
I have the old model. After installing and 15 min idling procedure, I put it on the setting nr 2 (advanced). It ran very nice for 200 km. It was a dream. After that, I don't know what happend, the bike became very aggressive (like on/off) and I had to do the remap. After remap is better. I use it on setting nr 3 (normal). I find it too on/off on setting 2.
Bob
bob66 is offline   Reply With Quote
Old 02-24-2011, 07:31 AM   #498
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,742
thanks for the tips
You only have to remap if you do not use the 5 hole disc, this should be included when you order the pipe.
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 02-28-2011, 01:59 PM   #499
fra88mi
Oddometer: 6
i've order the new model of leovince. it will available from 7-10 days.
when I'll have it in my hands, i will post some pics!
Old 03-05-2011, 08:59 PM   #500
NDTransplant
Oddometer: 358
James- Do you know if the X3 LeoVince will fit on a 2010 690R? I see you have one listed for some older 640 bikes....
NDTransplant is offline   Reply With Quote
Old 03-06-2011, 09:44 AM   #501
Renazco
Renazco's Avatar
Oddometer: 4,742
We've made just about everything work around here.
Picture below shows an SBK Ti to a 690 but I've also mounted an X3 Ti and Alu X3 to 690's. You'll need to make an adapter as shown in the photos below.
Couple of reducers from 54mm to 50mm and a couple are just extension pieces for better fit,
Old 03-06-2011, 11:17 AM   #502
JNRobert
Breaking Wind
JNRobert's Avatar
Oddometer: 9,732
Originally Posted by bob66 View Post
Hi
Bob
I thought the remaps wiped away the switch settings?
Crusader of Slack
JNRobert is offline   Reply With Quote
Old 03-06-2011, 03:21 PM   #503
NDTransplant
Oddometer: 358
Wow! Thanks for all that info/pictures, James- more than I expected!!
By the way, the seat you and Sonia made for my 690.....unbelievable. Never thought the bike could be that comfortable!!!
Old 03-07-2011, 01:17 AM   #504
bob66
bob66's Avatar
Oddometer: 134
No.. after remap you can still use the switch settings..
Bob
Old 03-07-2011, 07:54 AM   #505
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
The mapping is for FI control, the switches controls the ignition timing.
Old 03-07-2011, 09:12 AM   #506
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
Hey James, have you heard of anyone burning up one of the discs? I took my can off the other day and mine was just gone. The funny thing is I haven't had any issues with stalling now, which before I put the disc in I did. I wonder if it burned off around the edges and then shot out through the end, which would explain what happened to my spark arrestor.
Old 03-07-2011, 08:09 PM   #507
Renazco
Renazco's Avatar
Oddometer: 4,742
Can't say I have, I can't imagine how hot it would need to get to blow that thing through the spark arrestor but then again anything is possible.
So your SA is got a hole in it, got any pics so we can see what's going on.
If your SA is shot due to an LV issue LV will take care of that no problem.
Old 03-08-2011, 09:41 AM   #508
refokus
Just Learning
refokus's Avatar
Oddometer: 2,383
R & SE Models
What is the difference between the "R" and the "SE" models?
I rode one of these 690's this weekend and it was a pretty sweat ride.
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 03-08-2011, 08:47 PM   #509
Renazco
Renazco's Avatar
Oddometer: 4,742
SE is a V-twin, 690R is a single..
Old 03-09-2011, 08:24 AM   #510
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
I'll ry to remember to post up some pics tonight.
Times are GMT -7.   It's 03:00 AM.
