Old 04-17-2013, 01:38 PM   #661
fluff34567
fluff34567's Avatar
Oddometer: 1,104
heat shield touching plastic
heatshield close to tank
correct mounting ?
sent using my fingers and voodoo magic.
fluff34567 is offline   Reply With Quote
Old 04-17-2013, 02:00 PM   #662
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
Just bend the heat shield mount down. I have the same problem everytime I drop mine on that side.
Old 04-17-2013, 02:20 PM   #663
fluff34567
fluff34567's Avatar
Oddometer: 1,104
yep i thought about doing that but it should fit properly in first place. the stand off for the plate is HUGE ! can easily be half the length !
Old 04-18-2013, 06:38 AM   #664
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,693
Try mounting the exahuast with the tabs on the inside of the bracket vs the outside as shown in your pictures.
CanadianX is offline   Reply With Quote
Old 04-18-2013, 08:09 AM   #665
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
It could have been bent in shipping. It obviously isn't positioned right so bend it to where it should be.
Old 04-18-2013, 08:26 AM   #666
Ranies
Oddometer: 38
I used the rear hole when mounting the pipe.
When I try to shake the pipe sideways I think it sits very loose, what to you think?
Ranies is offline   Reply With Quote
Old 04-18-2013, 08:29 AM   #667
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
It sits very loose because KTM in their infinite stupidity didn't bother to create a mid mounting point on a very long exhaust system. That's what I think.
Old 04-18-2013, 08:35 AM   #668
wsmc831
wsmc831's Avatar
Oddometer: 799
Sure. Couldn't have anything to do with the factory can having fixed mount points on the can vs some aftermarket having straps. Clearly they need to design things with all possibilities considered.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 04-18-2013, 08:37 AM   #669
Ranies
Oddometer: 38
So maybe I should try the front hole to get it more stable..
Old 04-18-2013, 08:43 AM   #670
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
Well, if you think a 1/2 inch will make much difference on a 4ft long exhaust system......... FWIW, I've used both mount holes and it didn't make any difference. All that flexing eventually trashed my OEM header.
Old 04-18-2013, 08:46 AM   #671
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
And yet every other DS bike I've owned including my 450 EXC has a mid mounting point on the exhaust. Gee I wonder why.
Old 04-18-2013, 08:48 AM   #672
Ranies
Oddometer: 38
Aha, you're probably right.
What about using two mounting "bends" in each hole?
It should help a little..
Old 04-18-2013, 10:22 AM   #673
fluff34567
fluff34567's Avatar
Oddometer: 1,104
no its not bent.
if its mounted on the inside the bracket rubs against the tank, i would rather have a bit of melted plastic than a gouged tank
Old 04-18-2013, 11:55 AM   #674
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
Might, I've been kicking around fabbing a mount somewhere mid way to give it the support it needs.
Old 04-18-2013, 12:00 PM   #675
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
no its not bent.
Or, you could spend 2 seconds and bend it out of the way so it doesn't do either. Sheesh.
Times are GMT -7.   It's 05:50 PM.
