Old 08-31-2009, 06:15 AM   #76
Hytram
crash test dummy
Hytram's Avatar
Oddometer: 716
know any details of that KLE650?
Marty
bikeless 2 days and counting
Hytram is online now   Reply With Quote
Old 08-31-2009, 05:24 PM   #77
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,030
I dont know a lot more, I havent seen it in the flesh, a friend of a friend built it. A few more pics & a few details in this thread
http://www.advrider.com/forums/showthread.php?t=501343
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 09-06-2009, 11:53 PM   #78
MadGalah OP
Lovin the riders life!
MadGalah's Avatar
Oddometer: 90
H&B pannier racks arrived today...fit them on the weekend, then I might give them a try the following weekend.
It's not how quick you get there, it's the destination, I spose that depends who your with. Sometimes it can be a little too slow!
MadGalah is offline   Reply With Quote
Old 09-12-2009, 12:31 AM   #79
MadGalah OP
MadGalah's Avatar
Oddometer: 90
Fitted the racks, probably not as per the manufacturer had intended. Never the less they are on and sturdy.
Also upgraded the Garmin bracket tothe RAM bracket.
So now the list is pretty much complete to be self sufficient on weekends away and longer.
DriRider soft panniers'
H&B pannier rack,
50ltr rear bag,
DriRider tank bag,
Ram GPS bracket to go with the 60Cx (just need to insatll a 12v socket)
Old 09-13-2009, 05:06 AM   #80
KLEaner
Oddometer: 607
OK KLE Blokes,
Have just come up for the 48,000km service - which is a pretty major one for all concerned. Basically it is time to tear everything (except the very reliable motor!) down.
I have just done mine and found the rear suspension linkages (rocker arm etc.) in dire need of lube; So bad in fact that I installed grease nipples to all the bits that need grease and I could not be shagged pullling off again until there is no other option...
My findings were less than impressive - SFA grease in any rear suspension componentry that I could find - you have been warned...
Regards
... just took the valve cover off the KLE500 to check the valves @ 76,000km - exhaust 0.001" tighter than spec; inlets just fine.... now that'd be a bee's dick???
... was expecting 100K from this bike; now aiming for 150K ...
KLEaner is offline   Reply With Quote
Old 09-13-2009, 05:37 AM   #81
Oaka
Oaka's Avatar
Oddometer: 32
Question Lube it
Hey doesn't sound good KLEarner, but I thought the suspension linkages should have been regreased in the first major service around 24 thousand Km. Was yours done and the grease has washed out?
From little acorns grow big OAKAS!
Oaka is offline   Reply With Quote
Old 09-13-2009, 03:55 PM   #82
KLEaner
Oddometer: 607
Apparently mine were "checked" at around 24,000km, however , the lower shock mount point was the worst. That may be because it is exposed to more water/grime from the rear wheel; or it was just poorly greased from the factory. There was barely any grease on all other bearings in the rear suspension. Wheel bearings were ok - but I have a set of sealed units to go in down the track (when the originals give up the ghost.
Regards
Old 09-13-2009, 05:47 PM   #83
tksmith
Another GS Freak
tksmith's Avatar
Oddometer: 1,069
Good Thread on a nice bike
Hey guys, see your list of mods and not many putting on engine/crash bars. We use a few of these as they are great learners and now LAMS approved. We fit the SW-Motech bars first thing and they are fantastic. You can really get enthusiastic out in the bush with them, no fear of major engin/radiator damage.
We source them from
Motorrad Garage
www.motorradgarage.com.au
$300 delivered to your door, (might be more now, did the last one a few months ago)
A good set of Fastways is a must too. FYI BMW GS pegs are fitable with a little massaging if you come across a set from someone upgrading theirs.
Anyone from SEQ interested in checking out the Glasshouse area, give me a PM happy to show you around.
"Anything different is good"
Adventure On!!
tksmith is offline   Reply With Quote
Old 09-13-2009, 05:50 PM   #84
tksmith
Another GS Freak
tksmith's Avatar
Oddometer: 1,069
NICE Versys
Originally Posted by atgreg
woohoo, built in vic !!!!!
Man that's what Kawasaki should have done. Can't believe the direction the Manufacturers are going with Dualy's 17" wide rims ARE USELESS. Can't they see the error of their ways.
People are spending big money on a dysfunctional bike and ending up with bad taste in their mouth as a result (It's not always dirt either!!)
What was done and how much?
Adventure On!!
Old 01-04-2010, 03:25 AM   #85
trokel
trokel's Avatar
Oddometer: 1,030
Stalling Problem
Hi to all the KLE owners
I have a mate with an 07 KLE which seems to play up in the hot weather. We did a ride on the weekend and it kept stalling when he backed off or pulled up and then he would have trouble starting it. It only seems to happen in the hot weather.
Have any of you had a similar problem and if so how did you fix it?
trokel is offline   Reply With Quote
Old 01-05-2010, 12:28 AM   #86
tksmith
Another GS Freak
tksmith's Avatar
Oddometer: 1,069
Next time it happens open the filler cap and close it. See if it starts easier then. If so might be the tank breather line.
Have not had that problem with ours but they get ridden pretty often, wasps and bugs like to build nests in all sorts of places.
Have you got any mods? Pipe, jetting etc?
Adventure On!!
Old 01-05-2010, 01:30 AM   #87
trokel
trokel's Avatar
Oddometer: 1,030
Thanks for the reply
The bike is completely stock.
We didn't try it at the time but I reckon that could be a possibility because I am sure I saw a puddle of fuel under it at one stage when it was playing up as if the tank had pressurized and was forcing fuel out somewhere. I spoke to my mate this afternoon and he is going to try some new spark plugs but I think we need to take it out again in the hot weather and see if we can get it to play up.
Old 01-05-2010, 11:44 AM   #88
KLEaner
Oddometer: 607
There are 2 breather tubes that lurk underneath the seat that can cause these symptoms, as well as a possible small vacuum leak in the small hose connected to the fuel tap on the tank.
If the fuel tap vacuum line has a small split, slight perish, or pinched it can reduce the flow of fuel from the tap to the carbies. It is also very easy to pinch either of the other hoses when reinstalling the tank after service if they are not routed correctly. One hose comes from the tank and the other from the carb area IIRC. It should be plainly obvious after the seat is removed anyways.
Cheers
Ian
Old 01-05-2010, 10:18 PM   #89
trokel
trokel's Avatar
Oddometer: 1,030
Thanks I will pass the info on
Old 01-07-2010, 02:19 PM   #90
jimmy101
jimmy101's Avatar
Oddometer: 53
See my post:
http://www.advrider.com/forums/showthread.php?t=463467
Slowly doing more work to the kle.
jimmy101 is offline   Reply With Quote
Times are GMT -7.   It's 04:44 AM.
