Old 07-23-2008, 08:25 AM   #1
atk_nut OP
and atk_nut_wife
atk_nut's Avatar
Oddometer: 595
Tire plugging 101 - GS plug?
OK, I just got screwed for the first time. (not what you're thinking.)
Took a 3" wood screw in the front tire.....never done a plug before.
Do you guys use the GSA plugs that came in the tool kit? Or is there something else you can recommend?
Any special techniques?
atk_nut is offline   Reply With Quote
Old 07-23-2008, 09:01 AM   #2
DrPig
DrPig's Avatar
Oddometer: 320
Check this... should help...
http://www.advrider.com/forums/showt...uncture+repair
DrPig
'It will take some time to restore Kaos.'
DrPig is offline   Reply With Quote
Old 07-23-2008, 10:32 AM   #3
pgods
Godspeed rider
pgods's Avatar
Oddometer: 752
My local BMW dealer held an evening tire repair clinic, which I found very helpful. They demonstrated with the BMW kit on a few bikes, drilling holes and having us repair them under supervision.
A few tips:
Really get at it and bore the crap out of the hole with the hand tool. You want to scruff the hell out of the hole...more the better. "If you don't break a sweat, it ain't enough"!
Lube the hole with the glue, then lube the plug tip when it's mounted on the hand tool thing. Lube is good
Important: when inserting the plug push hard STRAIGHT in, then pull back STRAIGHT out in one movement. DO NOT twist the hand tool! Helge Pedersen demonstarted this in his DVD, Globe Trotters, and messed up the patch because he was twisting the damn thing.
Lastly: do not trim the patch flush to the tire. Leave a small section protruding after you trim with the supplied razor.
Sorry, but get a new tire as soon as possible. These patches are meant for emergencies only according to BMW (and the tire sales dept).
pgods is offline   Reply With Quote
Old 07-23-2008, 03:29 PM   #4
BobFV1
BobFV1's Avatar
Oddometer: 23,806
Originally Posted by pgods
Sorry, but get a new tire as soon as possible. .
BobFV1 is offline   Reply With Quote
Old 07-23-2008, 04:04 PM   #5
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,913
Originally Posted by BobFV1
A string plug repair will last the life of the tire. Absolutely no need to replace the tire.
bemiiten is online now   Reply With Quote
Old 07-23-2008, 04:24 PM   #6
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,755
I have had to plug every tire (save the recently installed rear) I have had on my GS (2001 model...5 sets of tires including OE T66s). I have had only one plug leak after several 1000 miles. So, I am a believer that plugs, properly installed work. I heat the tire in the sun before beginning the repair. I caution against being too agressive with the hole file...just enough to expose new, clean rubber. File the hole in the same orientation as the object removed.
Careful not to sever any steel or fabric cords.
Use plenty of glue and allow the plug to cure before riding...30 minutes in the hot sun is about right.
I overinflate to 50 PSI during the plug cure if I am near compressed air.
def is offline   Reply With Quote
Old 07-23-2008, 04:28 PM   #7
Bender
I can pass this guy.
Bender's Avatar
Oddometer: 34,933
That's pretty much been my experience.
Bender™
Bender is offline   Reply With Quote
Old 07-23-2008, 05:33 PM   #8
tmex
tmex's Avatar
Oddometer: 2,039
Mine too.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 07-23-2008, 05:36 PM   #9
native
You got to hold on
native's Avatar
Oddometer: 1,836
Plugging a rear tire is ok in my book, plugging a front is a no-no. Too much risk.
"Son, there's a sandwich in every beer."
"When the going gets weird, the weird turn pro." HST
"Soccer moms will be the death of us all."
native is offline   Reply With Quote
Old 07-23-2008, 05:53 PM   #10
nr552
nr552's Avatar
Oddometer: 301
+1 on that.
Had 3 nails in my tire last year. Used a $8 string plug kit from Autozone, and never looked back. The tire wore out before the plug let go. If the plug lets go-- put another one in. Simple.
Just make sure you don't go crazy with the bore/rough tool and make the hole too big.
06DL650
nr552 is offline   Reply With Quote
Old 07-23-2008, 07:16 PM   #11
matkal
Assault Commuter
matkal's Avatar
Oddometer: 1,651
Originally Posted by tmex
Mine too.
Me three
String plugs.
'09 R1200GS
Helmet laws suck. They interfere with natural selection.
ATGATT 35:12-14
"And Atgatt courted Motgatt, and took her for a wife.
And lo, he compromised with Atgmott, and verily she conceived,
and did bear a son, Notgatt. And Notgatt roamed naked,
and did bequeath his skin to the roads. And he was a wild ass and an outcast,
and was hated through all the land. And his forehead was branded, and he did be
come a sign and a warning to all the people."
matkal is offline   Reply With Quote
Old 07-23-2008, 09:28 PM   #12
kodiakfrank
Gloria's Cheerleader
kodiakfrank's Avatar
Oddometer: 9,622
String Plugs.
Stay away from rubber plugs.
kodiakfrank is offline   Reply With Quote
Old 07-23-2008, 10:30 PM   #13
GSbiker
new and un-improved
GSbiker's Avatar
Oddometer: 11,738
Originally Posted by kodiakfrank
String Plugs.
String plugs...the only way to go. A few years ago I installed a new rear tire and it collected a nail less than a mile after installation. Plugged it with a string and rode it for 9000 miles.
TRLcam
GSbiker is offline   Reply With Quote
Old 07-24-2008, 01:15 AM   #14
seanred
seanred's Avatar
Oddometer: 122
Originally Posted by matkal
Me three
String plugs.
Me four.
R1200GS 2007
seanred is offline   Reply With Quote
Old 07-24-2008, 07:14 AM   #15
Sam Buca
a.k.a. Daniel
Sam Buca's Avatar
Oddometer: 2,898
...and what are the risks? Please do tell.
My experience with string plugs on a bike or a car, front or rear, is that they work.
Sam Buca is offline   Reply With Quote
Times are GMT -7.   It's 03:25 PM.
