Old 09-18-2012, 04:25 PM   #1516
tdrrally OP
tdrrally's Avatar
Oddometer: 3,349
i thinking seat concepts dr350 seat
1997 DR350se
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 09-20-2012, 09:39 AM   #1517
tdrrally OP
tdrrally's Avatar
Oddometer: 3,349
i found this write up today and thought i would share
Bush bash Sunday, ride to work Monday - Suzuki's DR-Z250 is a jack-of-all-trades, and a bit of a surprise in the bush, too
A fun bike is a fun bike. It doesn't have to come in a big, flashy, expensive package, just as long as the ingredients for fun are there - in a road/trail motorcycle's case, a predictable chassis and usable engine mean the rider can get right on top of the bike's performance, and feel like a bit of a Daryl Hurley while they're at it.
In the $7990 Suzuki DR-Z250's case, it is a fun bike par excellence, with the improvements wrought over the out-going DR250 making the package even more practical, as well as better performed.
The original DR250 proved a reliable, if unspectacular, road/trail machine which did its intended job of being a dirt-capable commuter very well, even competing successfully in the Australian Safari in modified form, winning its class on occasion! A true all-rounder.
A TO Z
For 2001, the DR became the DR-Z, and with the new name came a number of updates - including new suspension - which I was keen to sample in the bush, in order to see how well the all-rounder DR-Z could cope in dirt mode.
As such, the bike was in dirt-riding trim (see separate panel) when I picked it up from Suzuki Australia's HQ.
The conventional front forks and rear monoshock have been completely over-hauled, with rebound damping adjusters to go with the compression adjustment, giving the rider more scope to set up the bike to suit his/her needs. It is still on the 'compliant' side though - I had the damping on the slowest settings five minutes into the ride in the bush.
So while the spring and damping rates are underdone compared to an out-and-out enduro weapon, the DR-Z's suspension is totally predictable. This means a rider can adapt a riding style to suit - not charging over big logs or whoops for instance, but finding a way around is a more appealing option.
Ground clearance is good, though steer clear of the deeper ruts. It took me a few minutes of pushing and pulling to retrieve the 115kg (claimed, dry) bike from the depths of one such obstacle...
At a more sedate pace, the suspension is plush and forgiving, meaning a rider out for a leisurely trail ride won't be punished, and these are the riders the DR-Z is aimed at.
BASTARD ACT
The DR-Z250 also scores a kick-starter to back-up the electric leg, a practical addition, and one which also points to Suzuki taking a more serious tilt at the 'trail' component of the road/trail all-rounder.
The kick-starter works well, though not as well as the magic button, which got the 249cc DOHC four-stroke single purring every time without fuss.
Being the sneaky bugger that I am, I didn't tell a ride companion what the little yellow button did, though he worked it out pretty quickly.
"That explains the mischievous look of mirth on your face every time I kicked it over," he laughed.
The ride position is comfortable, and I could still get well forward whilst seated without being too compromised for room. For those riders that like to stand, a change of bars may be required, as at 178cm I was forced to stoop a little when on the pegs.
When standing, the DR-Z is easy to grip with the knees despite the bike being quite slim, the extra 20mm of seat foam helping here, whilst raising the seat height by the same amount to 920mm.
The new 10.5lt plastic fuel tank (instead of metal) also assists in this department, the excellent seat/tank junction meaning my knees had plenty to grip, though lots of use and/or kneebraces will mean the tank stickers will suffer.
The plastic tank also means a low-speed oopsie won't necessarily mean forking out big bucks for tank repairs - a feature I certainly appreciated when a flat front tyre caught me by surprise, and saw me lying under the bike with my knee in between the ground and tank.
FLAT AT THE BOTTOM
Speaking of flat tyres, the DR-Z250 doesn't come equipped with rim locks (which keep the tyre locked to the rim), so the front tube was destroyed as the tyre turned on the wheel.
There are holes for rimlocks pre-drilled in both rims, however, and I would definitely fit a set before taking to the dirt if it were mine.
The tyres themselves were Dunlop's excellent 756 soft-terrain knobbies, fitted especially for the dirt by Suzuki Oz. They suited the wet, muddy conditions perfectly, and meant the conservative power output could be overcome by just keeping the throttle open, and maximising corner speed instead.
The engine itself was still in fully restricted form, as per ADR requirements. Removing the large rubber flap in the inlet manifold would certainly unleash more power (for closed circuit use only of course!).
Power from a fully restricted 250cc four-stroke is never going to be startling, and the ADR-complying DR-Z certainly feels short of breath up the top end, though it meant I could just hold the throttle open and ride it. When combined with a little imagination, this can make the pilot feel like a bit of an enduro legend. The feeling wasn't lost on me...
While imitating people who have more talent than myself, I like to have a good set of brakes on my side. The DR-Z250 has just that, with more than enough power available at the front lever, and a well-modulated rear brake set-up.
They combine to haul up the DR-Z easily, although I found the rear brake pedal itself too small, meaning I missed it a couple of times.
TIGHT GOING
The DR-Z really shone in the tight stuff, the low centre of gravity, good brakes and easy to use power making it quite nifty through the trees, enough to keep more narrow-focused bikes honest.
Once things opened out a little, the Suzuki's restricted power output capped its abilities substantially - de-restricting the engine would certainly mean the bike could hold its head higher in this type of going.
Even so, I had to keep reminding myself that this bike is designed for road use as well, such was its competence in the bush.
SEALED FATE
Being a road/trail bike, once I had finished covering the DR-Z in mud, I returned the 250 to road-spec for a week of commuting and freeway riding.
Still in restricted form (of course), the bike none-the-less performed well enough to keep me out of harm's way, and cruising at 110kmh was quite manageable. I reckon around 130kmh would be about top speed, which is plenty for this type of bike.
Saying that, at 100kmh I was doing a great impression of a wind-sock, and the wind clutching at my shoulders introduced a gentle weave at times - pretty standard for a light, wide-barred dirtbike on the road.
The brakes are still effective on the bitumen, with the Dunlop Enduro D903 F front tyre chirping a protest before the brakes have reached their full potential.
The tyres do a good job of compromising mild dirt abilities with road duties - just don't go trying to get the knee down with them. You'll probably succeed, it's just that after you got the knee to earth, it will most likely be followed by your butt, back, elbow etc.
ON A DIME
Fuel economy is good in city usage, making for a reasonable fuel range from the 10.5lt tank. The well-padded seat grows teeth after half an hour or so due to being so narrow, so only the iron-cheeked will be able to make use of this range for long periods.
In traffic is where the DR-Z excels. The seat height and upright riding position allow excellent vision all round (the mirrors are also very good), and the manoeuvrability makes traffic snarls a doddle.
If all else fails, you can always take to the median strip and roost off into the horizon.
The LED dash display is worthy of a mention, with an accurate speedo, stopwatch, two trip meters and the ability to adjust the trip meters, in case you take a wrong turn in the bush and need to reset to follow a map.
All the switchgear works well and, once adjusted correctly, the headlight does a commendable job.
Don't expect to carry a pillion passenger though - there are no pegs or grabstrap on the DR-Z.
BUDGET ALL-ROUNDER
All-in-all, the DR-Z250 does what it's designed to do very well. For somebody looking for an economical, value-for-money commuter which is equally at home on the dirt after a few mods, the DR-Z is worth a close look indeed.
Those who want a trailbike which will get them almost anywhere, in more comfort than a hard-edged enduro bike, may find the DR-Z250 is right where they want it. Useful items such as the plastic handguards and easily accessible air filter add to the value.
http://www.redbook.com.au/bike-revie...-dr-z250-13993
1997 DR350se
Old 09-20-2012, 01:28 PM   #1518
K44rll
K44rll's Avatar
Oddometer: 271
Originally Posted by bobfab View Post
does anyone have a moose skidplate on their DRZ250? I am curious what kind of coverage it yields. Any photos?
Not the best picture, the black bracket at the front is a modification to mount it on a Djebel, DRZ has a captured bolt in the frame...
Karl
www.vstromadventure.co.uk www.suzukivanvan.co.uk www.suzukiburgman.co.uk
www.flickr.com/photos/k44rll/sets/ www.klassiktrans.co.uk
Suzuki DL650A V-Strom Touring K7... Suzuki Burgman 400 K9...Suzuki Vanvan RV200 K8...Suzuki Djebel 250XC...Suzuki StreetMagic TR50S...Suzuki Choi Nori...
K44rll is offline   Reply With Quote
Old 09-22-2012, 11:57 AM   #1519
tdrrally OP
tdrrally's Avatar
Oddometer: 3,349
at long last a drz250k2 with a 4+ gallon fuel tank
it's a clark 4.? gallon tank from a friends xr650l
1997 DR350se
Old 09-27-2012, 07:00 AM   #1520
psu75
Carpe Diemer
psu75's Avatar
Oddometer: 118
Turn signals
Hey guys,
Real quick can someone give me some directions on where to find some easy to install turn signals for a DRZ 250? Some stick on ones would be nice, nothing that would take too long to mount. I'm not real electrical-saavy, so if you could point me in the direction of the wiring harness I would need also, that would be super-great as well!
Seize the frick'n day!!
psu75 is offline   Reply With Quote
Old 09-27-2012, 07:01 AM   #1521
psu75
Carpe Diemer
psu75's Avatar
Oddometer: 118
Originally Posted by fizzerfz1 View Post
Thanks guys, I need to look at what sprockets I run.
Took for a spin on Saturday after connecting the speedo cable. Seems like I max out at around 55 to 60 mph.
How long do you guys ride to and from the trails and how do you feel in the roads. If I had to do a 50 mile ride (one-way) to the trails and back, will the bike handle it.
My inspection is still on hold as the guy in one of the local inspection shop said that I needs both brake lights to work for the inspection to pass. So I need to do something before I take it for inspection .
Also one of my rear blinker burnt out from the heat of the exhaust when I took it for my first test run of a few miles a couple weeks ago. Yeah, I know, Stupid on my part.
So this is the replacement blinkers I have now. Not very pretty, but gets the job done. Now I need to just NOT break them.
Where did you find your blinkers? I'm diggin 'em! (Ermmm...not the ones you melted...)
Old 09-27-2012, 07:29 AM   #1522
tdrrally OP
tdrrally's Avatar
Oddometer: 3,349
much better looking
any more pix of that machine of yours?
1997 DR350se
Old 10-01-2012, 11:10 AM   #1523
tdrrally OP
tdrrally's Avatar
Oddometer: 3,349
random dirty drz250 pic
1997 DR350se
Old 10-03-2012, 05:32 AM   #1524
petie
Oddometer: 71
Took mine out for a ride in the mountains (hills really) and did a few little gnarly rutted 4wd hill climbs. Chuck it in gear and just motor up, so long as you pick the right line! I love the little drz!
Todays dogma is tomorrows dog shit.
petie is offline   Reply With Quote
Old 10-03-2012, 02:14 PM   #1525
livo
livo's Avatar
Oddometer: 271
Yeah, I did the same with mine about a month ago. Decided to explore a 4wd track with Dad (he ws on a XT250). Turned out to be heaps gnarlier than we anticipated, but the bikes handled it like a champ. Dad even managed to do an accidental wheelstand at one point, hahahah
I love my little Suzie!
Suzuki DL650 V-Strom 2007
Suzuki DR-Z250 2009
livo is offline   Reply With Quote
Old 10-04-2012, 11:55 AM   #1526
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
http://www.ebay.com/itm/Smoke-Black-...87fdfb&vxp=mtr
Search for "flush mount motorcycle blinkers"
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is offline   Reply With Quote
Old 10-12-2012, 03:28 PM   #1527
1zero
1zero's Avatar
Oddometer: 211
Time I chipped in...
Hi guys, I've been keeping an eye on this forum for a while now and thought it time to jump in !
Heres a couple of shots of my DRZ250, wee bit modded but more 'personalized' for me.
Well, uploading photos isn't that simple, any help would be welcolmed
Got it sussed !!!
1zero screwed with this post 10-12-2012 at 04:29 PM
1zero is offline   Reply With Quote
Old 10-14-2012, 04:47 PM   #1528
tdrrally OP
tdrrally's Avatar
Oddometer: 3,349
looking good , welcome
1997 DR350se
Old 10-14-2012, 09:06 PM   #1529
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,821
http://imageshack.us/
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 10-15-2012, 12:57 AM   #1530
1zero
1zero's Avatar
Oddometer: 211
Quick question for you DRZ riders, who of you run the TM28 pumper carb and if you have re-jetted etc and to what size jets and how many turns out on the fuel screw? mines rejetted and generally 'fiddled' with just curious as to others experiences, cheers guys.
Times are GMT -7.   It's 12:16 PM.
