Old 11-05-2012, 04:11 PM   #1561
tdrrally OP
tdrrally's Avatar
Oddometer: 3,333
the cable is the same basically . i have used a stock dr125/200 speedo with the stock drz250 cable
bolt it on
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 11-05-2012, 07:45 PM   #1562
tntmo
Oddometer: 494
Originally Posted by bobfab View Post
This might have already been covered, but does anyone know of a way to convert the stock trail odometer to a fully functioning speedometer from a DR650 or anything? Just curious could really use a speedometer rather than an odometer. Thanks,
Just about any speedometer designed for a 21 inch front wheel will work. I have a DR350 speedometer on my DRZ250 and an ATK speedometer on my CRF250X.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 11-07-2012, 04:16 PM   #1563
roleyrev
Oddometer: 35
Hi,
Does anybody out there know if DRZ-400 throttle cable/s is the same as the 250?? I can get a 400 cable but not a 250 version
Cheers
John
roleyrev is offline   Reply With Quote
Old 11-07-2012, 04:31 PM   #1564
privateer2010
privateer2010's Avatar
Oddometer: 37
Originally Posted by roleyrev View Post
Hi,
Cheers
John
I am not sure about fitting the cable from a 400, but if you check out the website www.bikebandit.com you can get all of the parts for the 250. I have bought several from levers to a carb for it. Check them out I have been buying parts from them for years.
An adventure is only as far away as the first step out the door.
privateer2010 is offline   Reply With Quote
Old 11-08-2012, 07:44 AM   #1565
tdrrally OP
tdrrally's Avatar
Oddometer: 3,333
more likely a dr250/350 cable , but suzuki likes bin parts
Old 11-11-2012, 06:47 PM   #1566
mountainduro
hardened rider
mountainduro's Avatar
Oddometer: 56
[QUOTE=1zero;19805146]Hi guys, I've been keeping an eye on this forum for a while now and thought it time to jump in !
Heres a couple of shots of my DRZ250, wee bit modded but more 'personalized' for me.
Well, uploading photos isn't that simple, any help would be welcolmed
Got it sussed !!!
Very very nice,BTW somebody knows where can I get those frame guards at the US? Which model is that rear tire? I have a Maxxis MX and its not good for mud in hill climbs.
mountainduro is offline   Reply With Quote
Old 11-11-2012, 07:55 PM   #1567
mountainduro
hardened rider
Oddometer: 56
Hi everyone again,this pics are from the toughest enduro I had been,believe me when I say tough it means,8 hours in mountains.
Before
After the trip
My stop suffered it
From right to left the second Me
Old 11-12-2012, 05:01 AM   #1568
tdrrally OP
tdrrally's Avatar
Oddometer: 3,333
very cool how did you do ?
Old 11-12-2012, 02:14 PM   #1569
1zero
1zero's Avatar
Oddometer: 203
[QUOTE=mountainduro;20022745]
Got it sussed !!!
Hi Duro
I couldn't buy the frame guards either, so I made them .
I started off with a black plastic 20L hydraulic oil container-emptythen measured the area up on the bike I wanted to cover with extra on the sides to form a 90 degeree angle to wrap around the sides of the frame using a heat gun to soften the plastic to form it. Then a few black zip ties in discrete places to hold to frame. Easy !!! and cheap :-)
The rear Mitas is a C-16, really good flexi knobs and seems to suit riverbeds to mud to compacted ground etc.
BTW i'm only 75Kg and I run 9psi front and rear all the time - seems to be the sweet spot for me and gives the right amount of rim-clean.
Keep up the good work on the enduro rides .
If you want to see more detailed photos just let me know.
1zero is offline   Reply With Quote
Old 11-12-2012, 11:39 PM   #1570
mountainduro
hardened rider
Oddometer: 56
Td that was really hard cuz sometimes you had to help the bike pushing her even in 1st gear and unclutched,only courage kept us standing, I realized that you have to be in good shape to do this,next time Ill be prepared.
Old 11-12-2012, 11:46 PM   #1571
mountainduro
hardened rider
Oddometer: 56
[QUOTE=1zero;20028490]
Originally Posted by mountainduro View Post
Hi Duro
Well very good job they look like stock very original,is it normal plastic ( typical motor oil gallon)? I like that tire looks that it can work good for what I need it.
It would be nice some detailed photos.
Old 11-13-2012, 07:37 AM   #1572
tdrrally OP
tdrrally's Avatar
Oddometer: 3,333
you must have been riding in wv on a rainy day
the bike looks good, running and mountain biking will help with you motorcycle racing
keep up the good work
Old 11-13-2012, 01:09 PM   #1573
1zero
1zero's Avatar
Oddometer: 203
[QUOTE=mountainduro;20032171]
OK, this should help - excuse the bike it's a bit dirty at the mo
Old 11-13-2012, 05:18 PM   #1574
mountainduro
hardened rider
Oddometer: 56
[QUOTE=1zero;20035651][QUOTE=mountainduro;20032171]
Thanks 10, I like them they look very nice, I'm gonna try they're very usefull.
Old 11-13-2012, 05:31 PM   #1575
Gobby
Trust Me!
Gobby's Avatar
Oddometer: 435
Frame Guards
http://www.bboffroad.com.au/dr_z_250.htm
Hi guys,
Here in Australia we have these frame guards - and they are avail for international sales.
Cheers
4 Wheels, move the Body, but 2 Wheels, move the Soul
............(3 wheels = cold beer and a comfy bed)............
Lets Ride
Gobby is offline   Reply With Quote
Times are GMT -7.   It's 11:10 PM.
