Old 12-31-2012, 03:09 PM   #1621
1zero
1zero's Avatar
Oddometer: 227
Originally Posted by tdrrally View Post
a flood and a spot would be a good rally set up and still use less volts than my current light
what sort of reflective range do you have?
- Pass
1zero is offline   Reply With Quote
Old 01-05-2013, 09:35 AM   #1622
xsamp86
xsamp86's Avatar
Oddometer: 8
Originally Posted by 1zero View Post
Hi Bob, yes the headlight assy, tailpipe and even the black frame protectors transform the looks of the bike to the 20th century
The tailpipe is off a RMZ250 2006 model, all thats needed is a machined up spacer bush(32mm ID-38mmOD) at the header pipe end and a fabricated bracket at the muffler mounting point, I didn't bother with the mid pipe bolt.
The DRZ std tailpipe is approx 3.9Kg, RMZ is approx 2.3Kg - so it's a good 'high weight' saving, quite noticeable when riding.
Cheers, talk soon.
Sorry to drag up an old post but I am looking at fitting a replacement to my old 98 SJ45A DR250XC. Could you possibly post a pic of the exhaust from the other side as Im really struggling to find anywhere who will sell me a bush. What is yours made from? Is it a standard graphite item or did you get it machined from soft metal?
Finally, anyone know if there are any differences other than inl;et diameter between an 06 and an 08 spec RMZ250 exhaust as the 06 ones are really hard to find at reasonable prices.
Many thanks
xsamp86 is offline   Reply With Quote
Old 01-05-2013, 03:16 PM   #1623
1zero
1zero's Avatar
Oddometer: 227
Many thanks
Hopefully these photos will clarify a few questions,
The bush I had made by a friend with a lathe or find something slightly larger that can easily be machined down/up to the required size, you could even use S/S or brass.
06 and 08 RMZ250 tailpipes look very similar, use google images and look at hi-res images of both bikes and although they went from a steel frame to alloy frame the tailpipes look very similar dimensionally.
The tailpipes shouldn't be too hard to find secondhand as these owners love to upgrade to 'performance' pipes
Good luck, any other ? fire away, cheers.
Old 01-05-2013, 03:18 PM   #1624
1zero
1zero's Avatar
Oddometer: 227
Latest LED light setup photo - 36W LED light bar.
Old 01-18-2013, 10:58 AM   #1625
AlexD92
DR-Z 250
AlexD92's Avatar
Oddometer: 78
New seat for my old girl.
Before
After
AlexD92 is offline   Reply With Quote
Old 01-20-2013, 02:16 PM   #1626
mendydrz
mendydrz's Avatar
Oddometer: 343
It's getting there very slowly
Well as my little beast has taken me the best part of 2 years to put back together ( thanks multiple deployments) the motor is together, I just want to get a workshop to double check the timing so it doesn't implode on start up.
I trial fitted the drz400 rear shock.
It will fit with some slight mod to the shock and a little to the bike. The shock mod being the lower mounting piece needs to be shaved a couple of mil easy side to fit the 250 knuckle, and to the bike the right hand side plastic cover metal lug that hold it in place need a gentle tapping with a hammer to allow the shock resivour to fit. I may also grind it back about 10mm so it has no chance to touching.
Also fitted my hand guards and windshield and GPS mount.
I also got brackets made to fit the XR400 17 liter tank so that will be fitted soon
Still to come is a tm33 pumper carb, new exhaust and some soft panniers.
Once it all setup I will run it in then be gifting it the the wife
I've stopped progress this week as I bought a ktm625 so I've been having fun on that instead!
Rear shock Upside down but needs shaving to fit
[IMG][/IMG]
GPS mounted with a ram 1inch ball mount with gizzmovest. Still lets me se the speedo
[IMG][/IMG]
Front of the bike with screens for bikes windshield and hand guards
[IMG][/IMG]
I dont like pinjartas. They promote violence against flamboyant animals
mendydrz is offline   Reply With Quote
Old 01-20-2013, 05:35 PM   #1627
JamesK
JamesK's Avatar
Oddometer: 113
Nice work MendyDRZ, looks like it will be a fun little bike for the wife.
Could you pls let me know where you scored the DRZ400 shock and the TM33 Pumper Carb?
2007 FJR1300A 200K Mile Club
If you see my bike on a trailer call 911
TBA 904, IBA 27221
JamesK is offline   Reply With Quote
Old 01-20-2013, 05:51 PM   #1628
AlexD92
DR-Z 250
AlexD92's Avatar
Oddometer: 78
Keep us posted on the drz400 rear shock mod. I`m very interested in hearing more.
Old 01-20-2013, 06:07 PM   #1629
mendydrz
mendydrz's Avatar
Oddometer: 343
I got the shock for free, brand new!
Lets just say it fell of the back of a truck!
Old 01-20-2013, 07:09 PM   #1630
JamesK
JamesK's Avatar
Oddometer: 113
Can anyone offer some advice on what rear sprocket I would need to give my Djebel 250 more lower pulling power to get up steep hills?
I've read on Thumper Talk that the DRZ400 rear sprocket is a direct swap for the DRZ250, so that should open up the available parts to choose from.
TBA 904, IBA 27221
Old 01-20-2013, 07:13 PM   #1631
JamesK
JamesK's Avatar
Oddometer: 113
This kind of hills:
TBA 904, IBA 27221
Old 01-20-2013, 08:56 PM   #1632
mountainduro
hardened rider
mountainduro's Avatar
Oddometer: 56
[QUOTE=JamesK;20537517]This kind of hills:
how many teeth has your rear sprocket?
mountainduro is offline   Reply With Quote
Old 01-20-2013, 09:03 PM   #1633
JamesK
JamesK's Avatar
Oddometer: 113
[QUOTE=mountainduro;20538323]
Originally Posted by JamesK View Post
This kind of hills:
It's OEM, so not actually sure, will count tonight.
TBA 904, IBA 27221
Old 01-20-2013, 09:06 PM   #1634
mountainduro
hardened rider
Oddometer: 56
Hi again
Hi guys sorry for my absence,nice to see new machines,more good info.
BTW I got a new for me DRZ 250 almost new,I will be posting pictures later on.
Old 01-21-2013, 01:28 AM   #1635
1zero
1zero's Avatar
Oddometer: 227
Depending if you ride on the road or not, go 2x teeth more on the rear sprocket for off road type of riding - this is very good for off roading, but it may make the engine very busy at 100kph or so tho.
Leave the front sprocket standard, cheers.
Times are GMT -7.   It's 07:19 AM.
