Old 02-08-2013, 12:56 PM   #1696
tdrrally OP
tdrrally's Avatar
Oddometer: 3,456
the 400 on the road will be a better
the usd forks are a bolt on
i have a set on my drz250 with a drz400 wheel, money well spent
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 02-08-2013, 01:04 PM   #1697
bobfab
bobfab's Avatar
Oddometer: 1,502
I shot ya a PM Bill!
In reality for wide(r) open roads at elevation i would probably prefer the 400.
The weight is no comparison though. The 400 feels (and probably is) about 50lbs heavier. That isnt an issue when you are moving though only when you have to pick it up!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 02-08-2013, 01:18 PM   #1698
tdrrally OP
tdrrally's Avatar
Oddometer: 3,456
have you looked at a dr350 ?
Old 02-08-2013, 03:42 PM   #1699
mountainduro
hardened rider
mountainduro's Avatar
Oddometer: 56
Originally Posted by twinrider View Post
Have you ridden both back to back? Does the TM28 add a lot of power? Just wondering because a friend with a DR250 with the pumper carb said that offroad he preferred the predictable power characteristics of the CV.
Well as I could feel I can say that its a thing of choices,each carb has their own characteristics,as your friend said the CV is very predictable and I love it very smooth rides,the pumper as I said its a lil' bit more agressive and makes more pulls, it adds a bit more power even my yoshi pipe sounds louder.
mountainduro is offline   Reply With Quote
Old 02-08-2013, 03:54 PM   #1700
Gobby
Trust Me!
Gobby's Avatar
Oddometer: 466
After Market Tail Pipe
Hi Guys,
What after market exhaust tail pipe do you boys suggest I get for my son's 250 (Oz spec - K7).
Then what else is required to get some more power out the engine, without touching reliability?
Thanks Guys
4 Wheels, move the Body, but 2 Wheels, move the Soul
............(3 wheels = cold beer and a comfy bed)............
Lets Ride
Gobby is online now   Reply With Quote
Old 02-08-2013, 04:59 PM   #1701
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
i'm finding the drz400E is 262 lbs
http://www.suzukicycles.org/DR-serie...shtml~isoraami
and the drz250 is 253
http://www.bikez.com/motorcycles/suz...z_250_2002.php
so 9lbs difference. that's nothing.
maybe the 400 is more top heavy?
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-08-2013, 05:00 PM   #1702
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
I have but would go 400 instead. the 350 is heavy.
Alaska
Old 02-08-2013, 11:15 PM   #1703
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,498
i have, and both have a place
i like the pumper better , but it uses more fuel
the cv carb deals with elevation change better
Originally Posted by eakins View Post
i can attest to that on my DR650. I use it to tour and have the CV carb. it's very predictable power and linear in how it build power. for touring with gear and heavier weight and huge elevation changes this is ideal. have ridden ones with a pumper added and they were used as big dirt bikes. it had tons of power now feeling (not on & off switch power, but more I'm giving you all i've got power now. CV carbs take time to build power) and that worked well for more technical riding when you needed to make a move...now.
Thanks for the replies, think I will give the pumper a shot. I can always go back to the CV if I like it better.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 02-09-2013, 04:18 AM   #1704
tdrrally OP
tdrrally's Avatar
Oddometer: 3,456
you will need the intake boot for each carb
Old 02-09-2013, 04:00 PM   #1705
nisda
nisda's Avatar
Oddometer: 20
Hi guys
I am looking for some parts before I would take apart my Djebel as I want to get it ready in 20 days.
I would like to change also the exhaust with an used one and I only found 450RMZ ones.Do you think is going to fit in place and would not alterate the engine output?
Also I am looking for a rebuild kit for the front suspension.
Thank you
nisda screwed with this post 02-09-2013 at 04:09 PM
nisda is offline   Reply With Quote
Old 02-09-2013, 04:25 PM   #1706
tdrrally OP
tdrrally's Avatar
Oddometer: 3,456
Originally Posted by nisda View Post
Hi guys
Thank you
moose racing has a kit for the front suspension, the 450 muffler will need a bit of fitting the work as well as some new jets in the carb
Old 02-09-2013, 05:00 PM   #1707
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,498
Thanks for the heads up, should be good to go.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 02-09-2013, 05:44 PM   #1708
mountainduro
hardened rider
Oddometer: 56
Well TD I dont know why but I put the CV carb at the TM28 boot and it fit a bit looser ,I thought it was the opposite,that the CV had a bigger mouth.
It worked fine just tight it a lil´more.
Old 02-09-2013, 07:49 PM   #1709
tdrrally OP
tdrrally's Avatar
Oddometer: 3,456
the pumper will fit the cv boot but will not seal right
i know i tried it, it will work well enough for a test ride but that's about it
Old 02-10-2013, 03:22 PM   #1710
1zero
1zero's Avatar
Oddometer: 231
Hi guys
Thank you
This may help.
Hopefully these photos will clarify a few questions,
The bush I had made by a friend with a lathe or find something slightly larger that can easily be machined down/up to the required size, you could even use S/S or brass.
06 and 08 RMZ250 tailpipes look very similar, use google images and look at hi-res images of both bikes and although they went from a steel frame to alloy frame the tailpipes look very similar dimensionally.
The tailpipes shouldn't be too hard to find secondhand as these owners love to upgrade to 'performance' pipes
Good luck, any other ? fire away, cheers.
1zero is offline   Reply With Quote
Times are GMT -7.   It's 03:37 PM.
