Old 04-01-2013, 09:25 AM   #1876
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Ok, last stupid question, where do I buy this boot. Can I order it aftermarket, or do I need to stalk ebay.
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 04-01-2013, 10:11 AM   #1877
hudsen8
hudsen8's Avatar
Oddometer: 47
http://www.mrcycles.com/fiche_sectio...6#.UVm-7BzU_ps
Part number 8, is the one I believe he is referring to. I'm not sure which one to order though. You could possibly find it on ebay.
hudsen8 is offline   Reply With Quote
Old 04-01-2013, 10:20 AM   #1878
tdrrally OP
tdrrally's Avatar
Oddometer: 3,390
no that's not it
you need part 18
http://www.ronayers.com/Fiche/TypeID.../CYLINDER_HEAD
from the head to the carb
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 04-01-2013, 12:05 PM   #1879
hudsen8
hudsen8's Avatar
Oddometer: 47
so..if I already have the tm28 pump, is the tm33 a direct bolt on? I'm think about doing the BBK this summer.
Old 04-01-2013, 12:18 PM   #1880
tdrrally OP
tdrrally's Avatar
Oddometer: 3,390
yes the larger 33 uses the same body as the 28, that is the word of jesse at http://www.kientech.com/
Old 04-01-2013, 04:40 PM   #1881
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Part 18-1? not the CA one I am assuming, since that is what I should already have.
2000 KTM 200EXC
Old 04-01-2013, 04:48 PM   #1882
tdrrally OP
tdrrally's Avatar
Oddometer: 3,390
yes
Old 04-01-2013, 08:12 PM   #1883
JDUBinCO
Mass Centralized
Oddometer: 93
Putting this back out there for interested parties...
Originally Posted by JDUBinCO View Post
I was referred here by Hudsen, I sold him some rims and he thought i ought to post some other stuff on here. Parts are from a low hour 2005 that was in pretty good shape - but no motor.
What i have left:
Front forks
Triple clamps with steering stem and bearings
Front fender (yellow)
Battery box with cables attached
Foot pegs, Kick stand, factory skid plate
Swing arm, linkage, rear shock, rear axle
Stock chain, chain guard, chain slider
Black plastic mud guard for shock and rear fender liner
Front and rear brakes complete, throttle tube and cables
Head pipe and muffler without baffle
Other little stuff
I don't have:
Engine, oil cooler, carb, plastics except as noted above, wheels
PM me on here or email me at John.Williams1220(at)gmail(dot) com
JDUBinCO is offline   Reply With Quote
Old 04-05-2013, 06:39 PM   #1884
hudsen8
hudsen8's Avatar
Oddometer: 47
Only one I was able to get before my camera died. That was after riding 1/8 mile down a dirt road to the trail. Wish I would have been able to get one of her at the end of the day; trails were gnarly and muddy as all get out, plus the hill climbs were a little hairy. Loving this bike more and more each ride. Hopefully more to come next ride.
Old 04-05-2013, 07:06 PM   #1885
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Glad you are having a good time. Should consider a go pro or contour. We should spread the word of the DRZ.
Sent from my KFJWI using Tapatalk HD
2000 KTM 200EXC
Old 04-05-2013, 07:40 PM   #1886
hudsen8
hudsen8's Avatar
Oddometer: 47
Thanks redleger, hope you get the kinks worked out of yours. I'm actually (hopefully) ordering the Drift innovations camera next pay check. Gotten to play with them next to the gopro at a local store and just felt better to me personally. Yea spreading the word of the DRz is a great idea, espcially showing off the 400s little brother
Hudsen
Old 04-05-2013, 09:26 PM   #1887
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
I looked at those when I bought the contour. The view screen is nice. Looks a bit lighter than the contour also. I would go with the 1080 version or you will end up with the 4:3 ratio. Make sure you can get 16:9 for the normal look.
Look forward to seeing some riding.
2000 KTM 200EXC
Old 04-06-2013, 05:08 PM   #1888
hudsen8
hudsen8's Avatar
Oddometer: 47
Thanks for the tip mate. How do you like the contour? Seems like a legit little camera with some cool features. I also considered the new sony action cam but seems to bulky, and still just leaning towards the drift. The new Hero3s just have too many problems from what i've read, and I don't like the external case for those. Can't wait to capture these hill climbs on camera
Hudsen
Old 04-07-2013, 01:53 PM   #1889
xsamp86
xsamp86's Avatar
Oddometer: 8
Talking
Sorry to interrupt...I use this thread for a lot of my inspiration & problems & just wanted to chuck on my contribution.
Been tinkering with a bit of 200x200mm 3mm ally plate i got for 99p on e-bay :)
The shapes were cut from the same 200mm plate starting with the right hand side cut in one corner of the sheet using a jigsaw (I did this in cardboard first) and held them on using 3 4x16mm black pop rivets (bridging accross where the frame is welded). The edges I just sanded smooth with 180 grit paper.
This gives just enough clearance on the kickstart and the shapes completely protect the frame when your on with mx boots.
Hope these images can be used by someone for a cool way to spend a couple of hours in the garage.
xsamp86 screwed with this post 04-07-2013 at 01:58 PM
xsamp86 is offline   Reply With Quote
Old 04-07-2013, 02:35 PM   #1890
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Hudsen
I like it. its light weight, the only draw back is I couldn't mount it forward enough to keep the helmet out of the shot. Thats pretty common on side mount cameras. For the price it is perfect and does not require an external case, which is awesome. There are mounting videos by contour on youtube which were very helpful however I use the 360 mount so it makes it really easy. I bought a second mount for my street helmet on I wear on my DR and will soon be getting some nice back road shots hopefully. Let me know how you like the drift if you get it. I need a second camera for back shots.
2000 KTM 200EXC
Times are GMT -7.   It's 12:25 PM.
