Old 12-05-2009, 04:48 AM   #181
tdrrally OP
tdrrally's Avatar
Oddometer: 3,422
Originally Posted by Kat00m
Hi guys
Today i got a drz250 for the wife and me to play on so i need a manual to do the valves and shit ....... can anyone point me in the right direction please
more pics please
welcome to the world of drz250/djebel/dr250r
edward
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 12-05-2009, 01:43 PM   #182
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,878
Thanks td
i just had to have it ..... tis a 06 with less than 300ks on it, hence i need a manual coz its not even had the first service yet ..... where should i look must be one online somwhere
b0mb3r is offline   Reply With Quote
Old 12-06-2009, 04:29 AM   #183
RoscoOz
Aprentice Adventurer
Oddometer: 50
I have been scouring the internet and the lads at Suzi have kept it pretty secret.
When you find one let us know.
RoscoOz is offline   Reply With Quote
Old 12-06-2009, 06:28 PM   #184
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,635
Originally Posted by K44rll
If you look at the lower shock mount in the picture you will see it has a second hole...using this lowers the rear of the Djebel
If you undo the pinch bolts on the triple clamps you can slide the forks upwards and you will see they have markings to match the rear ride height
There is an optional side stand for lowered Djebels or you can cut and modify the o/e one
Dunno that you can do that - if you look at the pictures, the bike has handlebar risers fitted AND has the forks pulled up almost to the bars. So the front is already lowered more than is possible with a std bike. You have to be careful about the wheel bottoming out on the triple clamps if you go too radical with pull-through.
That thing will be seriously nose-down if the shock is std, and seriously out of balance front/rear. It will be very quick steering and potentially unstable.
The DR650s have a similar dual-mount for the rear shock, but the forks are adjusted by moving an internal spacer limiting travel. Hence no issues with wheel-to-triple clearance. It would be worth investigating if the XC offers something similar.
Originally Posted by tdrrally
i wonder if that works for a drz250 aswell?
Not on mine, only one shock mounting point. And there was bugger-all room under the handlebars to pull the forks through. It had the usual couple of marks most off-road bikes have for varying the pull-through to suit the terrain, at 2 & 4mm or thereabouts.
Originally Posted by Tancred
This Suspension is awesome.
The DRZ250 somehow improved on this machine? Holy crap.
Let us know...
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 12-07-2009, 01:09 AM   #185
K44rll
K44rll's Avatar
Oddometer: 271
Originally Posted by warewolf
Dunno that you can do that - if you look at the pictures, the bike has handlebar risers fitted AND has the forks pulled up almost to the bars. So the front is already lowered more than is possible with a std bike. You have to be careful about the wheel bottoming out on the triple clamps if you go too radical with pull-through....
Sorry i never noticed the front had already been lowered....and well below the factory markings....in that state it should definately be nose down
Personally i would ditch the risers and put the forks back to standard,you can see the different ride height markings on the forks here..
Karl
www.vstromadventure.co.uk www.suzukivanvan.co.uk www.suzukiburgman.co.uk
www.flickr.com/photos/k44rll/sets/ www.klassiktrans.co.uk
Suzuki DL650A V-Strom Touring K7... Suzuki Burgman 400 K9...Suzuki Vanvan RV200 K8...Suzuki Djebel 250XC...Suzuki StreetMagic TR50S...Suzuki Choi Nori...
K44rll is offline   Reply With Quote
Old 12-08-2009, 01:49 AM   #186
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,878
Hi guys
can anyone help please ...... i removed the seat to see a pink wire with a male bullet type connector hanging loose ...... any ideas please
Old 12-08-2009, 04:08 AM   #187
tdrrally OP
tdrrally's Avatar
Oddometer: 3,422
is it towords the back or front?
edward
Old 12-08-2009, 12:59 PM   #188
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,635
Sounds vaguely familiar. Does the bike have a cut-out switch on the side stand or has it been removed?
Is there something wrong with the bike or are you merely curious?
Cheers,
Colin
The Stable
Old 12-09-2009, 10:19 PM   #189
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,878
edward
Thanks Ed
its just behind the tank when the sets off if that helps
Looks like it goes down to the gear indicator ........ i think
cheers wolf
Old 12-10-2009, 04:25 AM   #190
tdrrally OP
tdrrally's Avatar
Oddometer: 3,422
drz250 wyring diagram
here is what i have for k1-k4s
it looks like the pink wyre is from the neutral switch with just s plug to nowhere
http://i285.photobucket.com/albums/l...0wiringdia.jpg
edward
Old 12-10-2009, 12:51 PM   #191
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,878
Thanks Eddy
Old 12-10-2009, 01:19 PM   #192
RoscoOz
Oddometer: 50
TDR
did you find a Service Manual ?
RoscoOz
Old 12-10-2009, 02:21 PM   #193
gvthnks
gvthnks's Avatar
Oddometer: 553
Well, after wailing and gnashing of teeth (plus cash) I have my DRZ up and running.
Back story: posted an ad in local classified looking for dirtbike. Didn't care if it needed work.
I picked this one up for 300 bucks. mostly complete that supposedly had an electrical problem after PO had tried to jump start it with a truck and motor running.
Long story short, I had to replace the stator. I have had it for a while but just finally got around to replacing the stator yesterday.
It's an '01, all stock but has a Yosh pipe on it. Now I have to do some odds and ends, replace the rear tire pretty soon and recover the seat.
Haven't ridden it yet, but it sounds pretty good on my lift and seems to shift through all the gears well. The top end sounds very quiet but I'm gonna pull the valve cover and check the valves anyway.
I'm excited again about this thing and should be riding before long.
I know these pics stick, but I wanted to share some anyway. don't want to hear it about my messy garage.....I know
Anyone have a sprocket cover they don't want?
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is offline   Reply With Quote
Old 12-10-2009, 02:34 PM   #194
tdrrally OP
tdrrally's Avatar
Oddometer: 3,422
http://www.gutsracing.com/
has some covers for the drz250s
looking good
let me know if you want your $300.00 back
edward
Old 12-10-2009, 04:55 PM   #195
gvthnks
gvthnks's Avatar
Oddometer: 553
looking good
edward
Thanks. If I had it to do over again, I probably would've passed. This thing has been a headache.
Of course, hearing that twin cam rev freely and rap at me makes me think it wasn't so bad.....
By the way, thanks for your help earlier. I now have an extra CDI unit. I'll check out that website.
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Times are GMT -7.   It's 07:16 AM.
