Old 06-21-2013, 11:12 PM   #1996
stumpy-ktm
stumpy-ktm's Avatar
Oddometer: 76
cheers 1zero , but the problem isn't "beyond me " , was just asking if anyone had any better ideas than me , stripped the gear selector down to bare shaft , and straight edged it , bent like a banana , couldn't see that until I took the selector apart , majority of bikes I have worked on have a very short shaft that doesn't go across the whole engine , I guess it must be the first thing to bend in a fall , the guy who owns the bike is happy we have now found the problem , ...so ... if you drop the bike on the left hand side , and the gears will not change , or seems stuck in gear , then it appears the shaft will be the problem , these engines seem quite strong ... the shaft can be removed by simply removing the right side crankcase cover , removing the circlip on the lever side and out she slides ,.... does anyone have a straight selector shaft laying around ? or does anyone know if the drz 400 parts will fit ....
thanks again
" lost a leg .....still riding "
2004 ktm 640 supermoto
stumpy-ktm screwed with this post 06-21-2013 at 11:13 PM Reason: spelling correction
stumpy-ktm is offline   Reply With Quote
Old 06-24-2013, 04:12 AM   #1997
canoli
human
canoli's Avatar
Oddometer: 1,757
Would you?
I am in the market for a cheap, street legal 4 stroke 250 "race bike" that I will use almost exclusively for desert racing. Lots of sand, rocks and endless miles of whoops. Today with the help of a friend of a friend I found this:
It's an 08, has 4000 Km's on it and has been sitting outside for at least 2 months. After we put gas in it, it started right up and all seems good to go (bearings, spokes, forks).
The question is, should I buy it, upgrade the suspension and hotrod the motor ( cams, carb, etc..) or should I keep looking for a bike better suited and purpose built?
Thanks,
Canoli
canoli is offline   Reply With Quote
Old 06-24-2013, 04:14 AM   #1998
tdrrally OP
tdrrally's Avatar
Oddometer: 3,420
wow that is a factory dual-sport. in the usa?
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 06-24-2013, 04:20 AM   #1999
canoli
human
canoli's Avatar
Oddometer: 1,757
Sorry, no... should have said... I'm in OZ.
Old 06-24-2013, 04:28 AM   #2000
tdrrally OP
tdrrally's Avatar
Oddometer: 3,420
no worries still a cool bike
Old 06-24-2013, 04:39 AM   #2001
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,470
Thanks,
Canoli
Very poor aftermarket for these bikes when it comes to performance parts, I reckon you're better off with a WR250R or DRZ400.
twinrider is offline   Reply With Quote
Old 06-24-2013, 07:44 AM   #2002
tdrrally OP
tdrrally's Avatar
Oddometer: 3,420
there is a big bore 300cc kit
the tm33 or 36 carb works well
fmf , yoshi make pipes
there are better air filters out there
i say go for it with the drz250
Old 06-24-2013, 01:15 PM   #2003
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
I agree. I am just staring to appreciate mine now that it running well. The suspension rebuild may be your biggest hurdle though. If you want a stock ready to haul bike then the WR or CRFX would be good choices. Even this weekend in Oklahoma I was bottoming out a lot.
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 06-24-2013, 01:34 PM   #2004
canoli
human
canoli's Avatar
Oddometer: 1,757
Thanks for the feedback guys. Your comments mirror what I'm finding in my search. That is, lots of ways to tune the engine, but no real easy fix for the suspension. Think I'm going to pass.
Thanks again,
Canoli
Old 06-24-2013, 02:03 PM   #2005
tdrrally OP
tdrrally's Avatar
Oddometer: 3,420
racetech has valves for the shock, use springs in the forks for a dr650 . or put an rm or drz400 set of forks on .
race ready and reliable
a bad day on drz is better than a good day on any thing else
Old 06-24-2013, 04:27 PM   #2006
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,907
front hub
looking for a drz250 front hub.
thanks
plugeye is offline   Reply With Quote
Old 06-24-2013, 04:48 PM   #2007
tdrrally OP
tdrrally's Avatar
Oddometer: 3,420
i have a front wheel that is a bit tweaked, but hub is good.
Old 06-24-2013, 07:19 PM   #2008
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,907
pm sent
Old 06-25-2013, 10:09 AM   #2009
ChrisRiedinger
Specialized
Oddometer: 596
I just want to know why the one I've got listed for so cheap has not moved since I originally listed it. I almost want to just keep it now.
ChrisRiedinger is offline   Reply With Quote
Old 06-25-2013, 12:00 PM   #2010
tdrrally OP
tdrrally's Avatar
Oddometer: 3,420
a lack of understanding a great bike and lots of small pee pees!!!!
Times are GMT -7.   It's 10:25 PM.
