Old 05-23-2011, 03:39 PM   #781
tdrrally OP
tdrrally's Avatar
Oddometer: 3,380
i bought my drz250 from the suzuki dealer mechanic it has never had the valves adjusted. they have been checked yearly by the dealer
so i would say not very often
one of the top 4 hydro switch would do, check the threads
http://www.rockymountainatvmc.com/se...d=BRAKE+SWITCH
this should be the ground side of the wiring
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k1 i miss that bike
tdrrally is online now   Reply With Quote
Old 05-24-2011, 08:11 AM   #782
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
SUCCESS!
Finally with the help of you guys I was able to get my front brake light working.
I remembered that the PO had given me a switch of some sort, dug it up yesterday and voila... this is what I was thinking of buying...
This is where the switch goes, at the front master cylinder... (these pics are mainly for the technically challenged folks like me). I was looking for a similar pic and couldn't find any.
Remove the old one and replace with the new...connect the wires...new switch installed...
The whole process took less than 10 mins and now the brake lights are working. Good thing was, the bike already had the wiring done by the PO.
And to think that this was the thing that was worrying me the most (in regards to inspection)
Thank you guys.... Now to go get this baby inspected and to do some real riding
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is offline   Reply With Quote
Old 05-24-2011, 02:27 PM   #783
tdrrally OP
tdrrally's Avatar
Oddometer: 3,380
and you lost sleep of this?
looks great
Old 05-24-2011, 02:39 PM   #784
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
looks great
As a matter of fact I did lose some sleep worrying about this, but now feel like
Old 05-24-2011, 03:16 PM   #785
crazyal
dumb ass
crazyal's Avatar
Oddometer: 137
Plate Bracket?
So i got the little yellow tractor registered today!! before i go spend to much time hacking something what have you guys done for a plate bracket?
2001 KLR650 really,I bought another one!
05 weestrom mildly farkled SOLD
02 drz250 the little yellow tractor Sold
crazyal is online now   Reply With Quote
Old 05-24-2011, 03:30 PM   #786
tdrrally OP
tdrrally's Avatar
Oddometer: 3,380
i have used a bit of 1/8 metal bolted to the frame at the stock location
bent slightly and then bolted the tag to it
Old 05-25-2011, 05:35 PM   #787
crazyal
dumb ass
crazyal's Avatar
Oddometer: 137
thanks/ and another ??
Thanks TD I'm going to throw some .090 alum in the break and whip one up.
Does anyone have the suspension setup recommendations for 185 lb rider who has no idea what to do next, to calm this "rocket" down she is twitchy in the front end in a big way.
Old 05-25-2011, 06:28 PM   #788
tdrrally OP
tdrrally's Avatar
Oddometer: 3,380
idk i'm 260 with usd forks
what is it doing?
first thing is change the fork oil
Old 05-26-2011, 09:57 AM   #789
turnenem
TBD
turnenem's Avatar
Oddometer: 1,042
Are the forks at the stock height setting?
Try some preload on the rear?
turnenem is offline   Reply With Quote
Old 05-26-2011, 11:16 AM   #790
GlennF33
Oddometer: 115
I used a Kuryakyn Lighted Licence plate #9167 Dennis Kirk H49023 $41.99. I wired it into the tailight.
GlennF33 is offline   Reply With Quote
Old 05-27-2011, 02:57 AM   #791
crazyal
dumb ass
crazyal's Avatar
Oddometer: 137
The forks are about 5mm up in the tree, my sag is set at 3 1/2" , should i drop the front end a little to get more weight on the front tire?
Old 05-27-2011, 07:54 AM   #792
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
Hi guys, Happy to announce that I got my DRZ inspected and also got it registered as OHV
The emoticons above describe how I feel. Now off to some riding. No more excuses for me.
Thanks for all your support and advice.
Old 05-27-2011, 12:55 PM   #793
turnenem
TBD
turnenem's Avatar
Oddometer: 1,042
Good work fizzer! now ride out here aand we will put that drz to use!
Old 05-27-2011, 04:48 PM   #794
turnenem
TBD
turnenem's Avatar
Oddometer: 1,042
Addind rear pre load would tend to slow your steeing down somewhat.
DRZ 250s are a pretty slow steering bike geometry wise. Do you have much dirt history?
Old 05-29-2011, 04:10 AM   #795
crazyal
dumb ass
crazyal's Avatar
Oddometer: 137
i rode dirt a bit 20yrs ago and more time in sandpits on a YZ, or crashing a klr650 in the woods more recently
it seems to like the DRZ just wants to go pull out of my hands and go left or right after hitting small obstacles?
I guess if i felt confident in the "default" settings i would just say it's me and ride, but with no manual, yet. I'll guessing with the clickers, after finding the rebound on the forks backed all the way down i set every thing to halfway and have started again,
Would a larger rear (tire) effect any handling? something must have happened to the original rear tire it sure couldn't have be wear, it was replaced with a 120/90-18?
crazyal screwed with this post 05-29-2011 at 04:28 AM
Times are GMT -7.   It's 04:51 PM.
