Old 03-18-2012, 07:11 PM   #1276
tdrrally OP
tdrrally's Avatar
Oddometer: 3,393
Your the right weight for the stock suspension.
try from the other side. its tite
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 03-18-2012, 09:14 PM   #1277
kknuth
Up Nort!
kknuth's Avatar
Oddometer: 197
Question Best farkles for a 1994?
I just picked up a 1994 DR250S that is bone stock. I get confused in this thread which farkles and mods work with this model. Could someone clear up where to get the following items?
1. Aftermarket exhaust. NOT loud, but performance oriented. Does the DR350 FMF fit?
2. Carb jet kit. Does this help at all in this model?
3. Other carb mods?
4. Rear shock. Mine is totally shot. Is there an aftermarket available? DR350 shock fits or no?
5. Rear rack. Do DR350 racks fit?
6. More modern front fender. DR350 or DRZ400 fender fits???
7. More modern headlight shroud. DRZ400 fits???
8. Oversized tank. Is the Clarke 4.2 gal the biggest?
9. Air/Fuel mix screw. Which one fits?
10. Plastic Side covers. Best source for these. Do DR350 covers fit? Is Maijer the only aftermarket supplier?
Thanks for looking at my "Top 10". I appreciate the help getting up to speed on what is possible with this bike.
kknuth is offline   Reply With Quote
Old 03-18-2012, 11:47 PM   #1278
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
Originally Posted by tdrrally View Post
i have one on my k7 drz250 they will fit
doesn't the drz have 2 carbs options depending?
01-04? pumper
05-06? cv
so it would depend on your year.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 03-19-2012, 03:20 AM   #1279
Loose Goose
Loose Goose's Avatar
Oddometer: 4
Hi looking to take off on the DRZ250 for about a week and needing to sort out some luggage options for it.
Can anyone recommend some off the shelf luggage system? Don't want to have to mess around with building luggage racks.
Loose Goose is offline   Reply With Quote
Old 03-19-2012, 03:49 AM   #1280
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 134
3. Other carb mods?
This is the drZ250 thread, check out the DR350 thread instead! :)
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 03-19-2012, 05:12 AM   #1281
kknuth
Up Nort!
kknuth's Avatar
Oddometer: 197
"This is the drZ250 thread, check out the DR350 thread instead! :) "
Thanks! That was part of my confusion on different models. I will post over there.
Old 03-19-2012, 07:48 PM   #1282
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
giant loop coyote would work great.
don't think anyone was making rack for this bike.
even cycleracks doesn't show one & they make more than most
Alaska
Old 03-19-2012, 08:34 PM   #1283
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,445
Originally Posted by Olexa View Post
You may order this rack on this link: http://mmotoparts.com/en/product/complete_rack-all-welded_reinforced_for_suzuki_dr250
It cost $168.00 (with PayPal deduction and other payment). Shipping cost to Australia need to adjust, but is not expensive.
If you allude to me (Olexa from olexarider.ucoz.ua) - 5% discount guaranteed ;)
Thanks for the info, just placed an order and mentioned your name.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 03-19-2012, 11:13 PM   #1284
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
nice find. you might be able use wolfman's depending on the size the racks
http://www.wolfmanluggage.com/Expedi...ddle_bags.html
or http://www.happy-trail.com/Mojave-So...Bags-Pair.aspx
or http://www.ortliebusa.com/CartGenie/...st.asp?scat=12
or even HT hard luggage and these mounts
http://www.happy-trail.com/Happy-Tra...Mount-Kit.aspx
Alaska
Old 03-20-2012, 01:51 AM   #1285
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,445
Thanks for the links, got a set of Ortlieb drybag saddlebags that should fit nicely.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 03-20-2012, 02:37 AM   #1286
petie
Oddometer: 71
01-04? pumper
05-06? cv
yes which carb have you got the fuel screw on?
petie is offline   Reply With Quote
Old 03-20-2012, 05:22 AM   #1287
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,114
Originally Posted by petie View Post
Anyone know the quickest way to access the rear shock for preload adjustment? I took the airbox cover off and thought maybe that would be enough but didn't want to bust something in the process. Would taking the battery box out help? Or is the airbox easier?
Pete
PS How much to you guys weigh to change springs? I'm about 195-200 pounds fully geared up, the springs seem OK to me (once I get the rear preload sorted, there is nearly none on there!!!)
Remove the battery and box. Very easy to do and gives good access to the preload rings. Spray the threads down with WD40 and wipe them clean, then spray again before attempting. At your weight you should be able to dial in the proper sag numbers with the stock shock spring. The stock fork springs are going to be light for your weight, but you can probably get away with increasing the fork oil height (i.e., decreasing the air gap) by 10mm.
Mark
'11 KTM 250 XC (dual sported)
'05 KTM 450 EXC (dual sported)
OhioPT is offline   Reply With Quote
Old 03-20-2012, 10:09 AM   #1288
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
OhioPT, Can you do a comparison between the DRZ 250 and the 250 EXC? I understand that they are different animals, but just want a hear opinions from somebody who owns both.
The 2T itch is growing stronger and I cannot justify having 2 dirt bikes as per the laws of my HOME land.
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is offline   Reply With Quote
Old 03-20-2012, 12:03 PM   #1289
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,109
i'm guessing the CV carb
Alaska
Old 03-20-2012, 10:38 PM   #1290
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,445
Has anyone here ridden both the TM28 and BSR32 carbed DRZ250s? I'm wondering if the performance difference is significant enough to make it worthwhile swapping out the BSR for the TM28...
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Times are GMT -7.   It's 02:04 AM.
