Old 04-14-2012, 06:14 AM   #1351
K44rll
K44rll's Avatar
Oddometer: 269
Originally Posted by twinrider View Post
my Djebel is lacking the holes that the DRZ stock bash plate and B&B bash plate screw into.
I had the same problem with my Moose bash plate and used a 5mm strip of metal mounted from the oil cooler guard mount...
Karl
www.vstromadventure.co.uk www.suzukivanvan.co.uk www.suzukiburgman.co.uk
www.flickr.com/photos/k44rll/sets/ www.klassiktrans.co.uk
Suzuki DL650A V-Strom Touring K7... Suzuki Burgman 400 K9...Suzuki Vanvan RV200 K8...Suzuki Djebel 250XC...Suzuki StreetMagic TR50S...Suzuki Choi Nori...
K44rll is offline   Reply With Quote
Old 04-14-2012, 12:54 PM   #1352
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,295
Originally Posted by DRool View Post
Hi, I have the Dr 250, same as the Djebel and have the B&B bash plate. Mine mounts with 4 frame mounted tabs. Steve
Steve, any chance of you snapping a couple piccies of your bash plate and the frame-mounted tabs? My Djebel doesn't seem to have any and I need to figure out a solution.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 04-14-2012, 12:56 PM   #1353
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,295
Karl
Karl, what did you do for the other attaching points?
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 04-14-2012, 04:31 PM   #1354
DRool
Oddometer: 54
Yep, I'll change the oil today and snap some pics. Steve
DRool is offline   Reply With Quote
Old 04-14-2012, 05:28 PM   #1355
DRool
Oddometer: 54
Old 04-14-2012, 05:34 PM   #1356
DRool
Oddometer: 54
Cant post pics anymore for some reason?
Old 04-14-2012, 07:07 PM   #1357
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,295
They've changed the settings so you need to use an online photo hosting site and the img button.
PMed you my email address. Big pics would be great, thanks!
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 04-15-2012, 12:45 PM   #1358
tntmo
Oddometer: 460
No spark....bad CDI?
I got a 2001 DRZ250 for free a few months ago, the engine was pulled out of it and the guy was trying to install it into a street legal DR350 frame. I just built up the DR350 frame from an off road DR350 I had and want to get this DRZ back into one piece.
I got everything bolted back in and have 99% of the parts, missing a carb boot, battery and a few other little bits but figured I could at least try to get it running before chasing down the rest of the parts. I hooked up the battery charger and tried cranking it over but I have no spark. I double checked all the connections and nothing appears to be incorrect. I'm down to suspecting the CDI.
Anyone have one go bad? Anyone have a spare?
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 04-15-2012, 01:25 PM   #1359
tdrrally OP
tdrrally's Avatar
Oddometer: 3,330
check and make sure the cdi is not grounded
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 04-15-2012, 06:51 PM   #1360
tdrrally OP
tdrrally's Avatar
Oddometer: 3,330
went for a ride with some good friends
the mighty drz held its own with the big bores
Old 04-16-2012, 02:23 AM   #1361
JamesK
JamesK's Avatar
Oddometer: 113
Just picked up a used Djebel 250XC and whilst she runs, she's in need of some TLC.
I've been looking at the online parts fiches to find some very standard parts, but just don't seem to be having any luck.
These are the bits I need at the moment:
- throttle cable
- headlight relay
- spark plug - (there are different numbers listed, so not sure which one is right. I'm looking to get an Iridium plug.
- side stand - the one on the bike has been moded so the bike hardly leans over, meaning a light gust of wind can blow it over... Will the DRZ/DRxxx side stand fit the Dejebel?
- side stand switch
(I know a bunch of people say rip it off and chuck it, so maybe some of the inmates here have one lying around gathering dust ). I'm the first to bypass the stupid clutch level switch, but do kind of like the safety aspect of the side stand switch. I mean rigging up a simple on/off switch to bypass the side stand switch when you don't want it to me seems like the way to go...
I've seen some on eBay for a DRZ400 but am not sure if these fit - can anyone answer?
http://www.ebay.com/itm/2006-SUZUKI-...28ce39&vxp=mtr
Also, how common is it to replace the cam chain tensioner on these bikes?
Has anyone used this air filter, did it fit ok?
http://www.motorcycle-superstore.com...250-Parts.aspx
What about this one?
http://cgi.ebay.com/ws/eBayISAPI.dll...=singinformore
2007 FJR1300A 200K Mile Club
If you see my bike on a trailer call 911
TBA 904, IBA 27221
JamesK screwed with this post 04-16-2012 at 02:41 AM
JamesK is offline   Reply With Quote
Old 04-16-2012, 02:47 AM   #1362
JamesK
JamesK's Avatar
Oddometer: 113
Here are all the different spark plugs they list for the DR-Z250, so which one to is it, e.g. there are 3 different NGK parts
17-1 SPARK PLUG (NGK,CR9E) 09482-00458 1 $4.83
17-2 SPARK PLUG (ND,U27ESR-N) 09482-00459 1 $5.51
17-3 SPARK PLUG (NGK,CR8E) 09482-00456 1 $4.59
17-4 SPARK PLUG (NGK,CR10E) 09482-00460 1 $4.83
17-5 SPARK PLUG (ND,U24ESR-N) 09482-00457 1 $5.51
17-6 SPARK PLUG (DENSO,U31ESR-N) 09482-00461 1 $11.23
All I'm after is an Ir NGK plug.
http://www.mrcycles.com/fiche_section_detail.asp
TBA 904, IBA 27221
Old 04-16-2012, 03:39 AM   #1363
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,295
Rough and Road has uni-filters in stock as well as iridium plugs. Probably better off buying those items locally.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 04-16-2012, 06:48 AM   #1364
tdrrally OP
tdrrally's Avatar
Oddometer: 3,330
some years have the same bad cam chain tensioner as the drz400, so it can be common
i put a manual unit for a drz400 on my bike, but plan to replace it inn the near future with a new chain and ect
i think the side stand is the same
Old 04-16-2012, 09:02 AM   #1365
zgfiredude
Oddometer: 823
James, check part #'s on the 250 and 400 side stand switches to see if they are the same, I have a hunch that they are......If you find that they are the same shoot me a PM as I have a couple for the 400's.
zgfiredude is offline   Reply With Quote
Times are GMT -7.   It's 01:01 PM.
