Old 07-31-2008, 10:37 AM   #1
c.b.powell OP
B.i.t.S.
Oddometer: 14
Bluhduh Red fuel bottle by Outbound.ca -- stay away
I have two red aluminum 1-liter aluminum fuel bottles built by Outbound.ca . I use (used) them to carry spare gasoline on long-haul trips. They're quite similar to MSR bottles.
I strongly recommend against this brand, for this purpose. Despite being marked as suitable for all liquid fuels, the plastic caps and seals deform and leak in the presence of gasoline. One of the bottles tipped over in transit just enough to nicely soak the clothing in the case with gasoline. No permanent damage done, but just a warning. IMHO, a sealed fuel bottle should never leak regardless of its orientation.
Stick with MSR, they're reliable, well-known and durable.
Chris
c.b.powell screwed with this post 07-31-2008 at 10:56 AM Reason: Corrected my mistyped URL -- it's OUTBOUND.ca
c.b.powell is offline   Reply With Quote
Old 07-31-2008, 10:45 AM   #2
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,432
Originally Posted by c.b.powell
I have two red aluminum 1-liter aluminum fuel bottles built by Outdoor.ca . I use (used) them to carry spare gasoline on long-haul trips. They're quite similar to MSR bottles.
Chris
Cool.
Thanks for the tip.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 07-31-2008, 11:04 AM   #3
monkeyfez
Enabler....
monkeyfez's Avatar
Oddometer: 4,998
What he said. Good to know.
"When the monkey tells you to give it up, give it up." ~ Bubba Satori
Help save Hank
GO NED!
monkeyfez is offline   Reply With Quote
Old 07-31-2008, 05:42 PM   #4
flux_capacitor
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,478
Do the MSR bottles ever leak if orientated sideways all the time?
flux_capacitor is offline   Reply With Quote
Old 07-31-2008, 06:11 PM   #5
2.0 dogs
Oddometer: 463
The same with the Timber Creek brand sold at Academy stores in Texas. The seals swell and you have leaking fuel everywhere.
2.0 dogs is offline   Reply With Quote
Old 07-31-2008, 06:15 PM   #6
marchyman
Talks to cats
marchyman's Avatar
Oddometer: 5,313
Ever? I suppose the O-ring could degrade such that fuel would leak. I replace the fuel in my bottles about every 2 months and look at the O-rings then. If in doubt I'd replace them. Haven't had to replace one, yet.
// marc
marchyman is offline   Reply With Quote
Old 07-31-2008, 07:07 PM   #7
adaycj
Oddometer: 456
+2. No, unless the oring has died.
adaycj is offline   Reply With Quote
Old 07-31-2008, 08:07 PM   #8
c.b.powell OP
B.i.t.S.
Oddometer: 14
On that note, I plan on visiting REI at some point to see if the replacement MSR caps would fit my Outbound bottles. If the cap and O-ring make a proper fit it will be cheaper than buying all-new bottles.
If not, no big deal. It's worth a look.
Chris
Old 08-01-2008, 09:37 AM   #9
torags
torags's Avatar
Oddometer: 2,347
Just use a Snapple bottle.
Rags
'04 BMW R1150RS/// Gone, but not forgotten
'07 HD XR 883R Sportster "Widow Maker"///Gone!
IBA #17225
Just passing thru, recording the motogeist
torags is offline   Reply With Quote
Old 08-01-2008, 11:09 AM   #10
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,645
Or to make packing easier, Ziplock bags.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 08-01-2008, 04:01 PM   #11
debaisley
debaisley's Avatar
Oddometer: 1,388
Just to let every one know : I once left a full MSR bottle in a black plastic top case on a very hot sunny day. It got so hot inside the case that the O-ring warped and gas leaked out over everything. , So dont leave them inside a case while parked , it could be bad.
debaisley is offline   Reply With Quote
Old 08-01-2008, 04:26 PM   #12
GRBTA
GRBTA
GRBTA's Avatar
Oddometer: 92
Carrying fuel bottles
go to the thread "long way down - How do you carry oil?" some elegant solutions for carying gas outside your bags...
One of the great illusions and fallacies of life is to believe that the present hour is not the critical, decisive hour.
GRBTA is offline   Reply With Quote
Old 08-01-2008, 04:44 PM   #13
torags
torags's Avatar
Oddometer: 2,347
Don't knock it til you tried it. 1500 mile IBA ride no leaks. If left in the sun the plastic expands.
It was tested by some bikers from 10' high drop, no failure.
I think it has a larger mouth than the metal bottles for an easier fill.
If you're deep in the rough camping, put the liter in your tank and use it as a pee bottle to keep away from those critters at nite.
just my .02
BTW I use to use one of the square red 1 gal containers. Until it leaked into my civilian clothes, when I had to isolate myself at an outdoor restaurant in Palm Springs because of Eau De Exxon.
Rags
IBA #17225
Times are GMT -7.   It's 01:46 AM.
